Mechanically naive woman needs help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sharit11, Apr 5, 2012.
  1. Apr 5, 2012 at 8:43 AM
    Sharit11
    Sharit11 [OP] Member
    PA
    96 Tacoma
    I have a 96 Tacoma Xtra cab. Yesterday it died suddenly about an hr. from home. It died infront of a garage and the guys there spent about an hr. trying to figure out the problem. It turns over but there is no spark at the plugs. They were baffled. Seems to be electrical at least that's what everyone thinks. Mechanic at home can't look at for a week. What can I check? I'm not overly mechanically inclined but I am a pretty serious do it yourselfer when it comes to my house- I have done electrical work and plumbing and I own power tools lol. I have just not ever bothered much to learn about auto mechanics. Any suggestions?
  2. Apr 5, 2012 at 10:35 AM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    what exactly did they troubleshoot. if you tell us what they tried we can narrow it down some.
  3. Apr 5, 2012 at 10:39 AM
    Hot Tamale
    Hot Tamale Well-Known Member
    Pat
    Henderson, NV
    2012 Access Cab 4x2
    I'm confused. Your title says "mechanically naive woman" but you list your gender as male? :notsure:
  4. Apr 5, 2012 at 10:42 AM
    98regstick
    98regstick Well-Known Member
    Maryland
    '11 DCSB SR5
    OME 90021 with 885s and top plate spacer, 2" AAL, OME rear shocks, Camburg Uniball UCAs, OME CB Drop, 285/75/16 BFG AT's on Level 8 Guardian wheels
    x2.
    tranny?? :drevil:
  5. Apr 5, 2012 at 10:43 AM
    Ry1984
    He used that as a ploy to get quicker responses :D
  6. Apr 5, 2012 at 10:47 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    we need to know what you/or other mechanics have tried.
  7. Apr 5, 2012 at 11:27 AM
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    This!
  8. Apr 5, 2012 at 11:40 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    no, first the most important question is what gender are we dealing with:cool:
  9. Apr 5, 2012 at 2:46 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    This thread is awesome
  10. Apr 5, 2012 at 3:52 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Tile says "Mechanically naive..."... that says it all.
    Frank
  11. Apr 5, 2012 at 4:15 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Check your ecu fuse.
  12. Apr 5, 2012 at 4:17 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Mechanically naive WO Man. Man is in woe over this.
  13. Apr 5, 2012 at 4:51 PM
    Highland Logan
    Frank
    Nova Scotia, Canada
    Truck be damned... OP is naive about his/her own mechanics...this was certainly not meant to be disparaging to the fairer sex in the least. I just noted the unintentional pun the OP create. lol
    Frank
  14. Apr 5, 2012 at 6:26 PM
    97yota4wd
    Eric
    Mesa, AZ
  15. Apr 6, 2012 at 6:54 AM
    Sharit11
    PA
    96 Tacoma
    I am a woman! I didn't even notice an option for gender so it must have been preset to male- interesting. I have yet another mechanic coming this morning. I'm told he can fix anything. He is too busy to actually fix it but is going to try to determin the problem. I will post what has been ruled out if he also fails.
  16. Apr 6, 2012 at 7:36 AM
    Afwrestler1986
    Johnstown, NY
    Go out there and check you ecu fuse. it is under the hood in that fuse box.
  17. Apr 6, 2012 at 8:24 AM
    Sharit11
    PA
    96 Tacoma
    The first 3 guys to look at it said that either ecu b had no power or ecu. One did and one did it. It wasn't the fuse- there was no power when they pulled it. I don't remember which one did and which didn't. I'm thinking ecu b had power though.
  18. Apr 6, 2012 at 8:32 AM
    Sharit11
    PA
    96 Tacoma
    By mechanically naive I mean that until wed I have no idea what Ecu was and actually still don't as the most I have ever done to my truck is change the oil and a tire once which is more than most women have done. Oh - I also replaced my battery terminals, but that's about it. I was stating that I was naive so when given ideas on what you check you would all know to use simple terms and realize that if you tell me to check the ecu I would likely not know what the heck that is. And again.... I assure you... I am positively a woman not that that should really matter much as I really just need help to diagnose the problem so I can get someone to fix my truck or if it's something I can do - fix it myself.
  19. Apr 6, 2012 at 10:28 AM
    Sharit11
    PA
    96 Tacoma
    It was my crank shaft sensor. Problem solved!
  20. Apr 6, 2012 at 10:29 AM
    TennesseeFan76
    TennesseeFan76 I intend to live forever. So far, so good.
    Phill Goodfactor
    Georgia
    2005 PreRunner DCLB
    3 inch lift, Debadged, 5% Tint, Custom Stereo, BHLM, Fog Light Mod, Sockmonkey Decals, OEM Bedmat, Plasti Dip Front Valence, Slims 6K HIDs (thanks goes to TheGloryFades), Hyper yellow fog lights, LED interior lights, Satoshi Grille with FJ Emblem, Pro Comp lights behind Satoshi, FatMat
    Good Job and welcome to TW
