Mechic called (wrong Diff Drop bolts?)
Discussion in 'Suspension' started by KingMoo, Oct 18, 2011.
  1. Oct 18, 2011 at 2:16 PM
    KingMoo
    KingMoo [OP] Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    My Tacoma is in the shop right now getting a lift with 5100s all around with Eibach springs and driver side 1/4" spacer.
    The mechanic just called and said the wrong size bolts are in the Diff. Drop package.
    Is this the right Diff. Drop for a 2011 TRD Sport DC/SB?
    Toytec Front Diff Drop Kit (TAC-DR-05)
    *(2) Main diff-drop spacers
    *(2) 6" x 1/2" Bolts
    *(2) 1/2” Nuts
    *(2) 1/2" Flat washers
    *(4) 8mm x 40mm bolts
    *(4) 5/16" Lock washers
    *(4) 5/16” Flat washers
    *(4) Skid-Plate Spacers (1” x 1” x 1/2”)
    *(1) Page instructions
  2. Oct 18, 2011 at 2:27 PM
    KingMoo
    Calgary
    Tacoma TRD Sport
    but I'm going up 2.5" (Eibach 1.6" + 5100's set at 0.85")
    I read a few posts here that said anything 2.5 or above should have a diff drop
  3. Oct 18, 2011 at 2:30 PM
    jandrews
    '09 FourDubDee TRD OR
    I'll repeat: Diff drops don't do anything in 2nd gen Tacomas.
  4. Oct 18, 2011 at 2:32 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I'll quote so I don't have to repeat. :)
  5. Oct 18, 2011 at 2:37 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    See sig quote
  6. Oct 18, 2011 at 2:44 PM
    mjp2
    NJ
  7. Oct 18, 2011 at 2:52 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    How do you post via a sandwich? :crazy:
  8. Oct 18, 2011 at 2:53 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I record all my videos with an orange, so posting with a sammich is within the norm
  9. Oct 18, 2011 at 2:55 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    fixed it for yah
  10. Oct 18, 2011 at 2:58 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Skip it, I have had 2.5" and now 3" lift and it's not needed!
  11. Oct 18, 2011 at 3:22 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Im removing mine, anyone know the oem bolt specs
  12. Oct 18, 2011 at 3:25 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    I never put one on???????
