Melting Daylight
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aeon, Mar 31, 2013.
  1. Mar 31, 2013 at 10:42 PM
    Aeon
    Aeon [OP] FOX HOUND
    Puerto Rico
    PreRunner SR5 4x2
    Coming Soon!
    I have tacoma 4x2 2009 Prerunner
    Anyone know how this problem occurs? see pic :confused:
  2. Mar 31, 2013 at 10:47 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
  3. Mar 31, 2013 at 10:58 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    Your thread title is so mysterious...
  4. Apr 1, 2013 at 9:04 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I bet its going to be hard to get a Local Toyota dealer to cover this for you- should have been covered under warranty. :mad:
  5. Apr 1, 2013 at 4:17 PM
    Reeves
    Reeves Well-Known Member
    Colorado Springs, CO
    08 TRD Rugged Trail
    Mine looked the same way. I just disassembled the housing and took the yellow lenses out.
  6. Apr 1, 2013 at 4:18 PM
    Pannell_Trd
    Pannell_Trd Well-Known Member
    Tyler
    Georgia
    2009 Prerunner Double Cab Trd Sport
    Yellow foglights 20% tint
    looks just like mine. very common on 2009-2011. Take it to the dealer if it is still under warranty. There is a tsb on this problem
  7. Apr 1, 2013 at 4:48 PM
    payrow
    payrow Well-Known Member
    Los Santos
    '18 DCSB Sport
    That sucks...Had the same problem with my 2009, luckily I was still within warranty. Took it in and they replaced both headlamps free.
  8. Apr 1, 2013 at 4:50 PM
    Aw9d
    Aw9d That one guy
    Switch up to LED's after you fix it.
  9. Apr 1, 2013 at 4:51 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Lol. First thing I thought was LSD.
    But lens melting seems to happen to some tacomas.
  10. Apr 1, 2013 at 6:12 PM
    joes06tacoma
    Joe
    Central Coast, CA
    The left side one on my work truck (09 with 75k) finally cracked. I disabled the DRL so it doesn't get any worse. Luckily I found out about the problem from reading on here, and decided not to add DRL to my 06. Too bad, it's a good feature to have if properly engineered.
  11. Apr 1, 2013 at 6:18 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Yep, do the DTRL stealth mod, mine look just like that :(
