Mesh grille + insert?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fenrisulfr, May 14, 2011.
  1. May 14, 2011 at 11:43 AM
    Fenrisulfr
    Fenrisulfr [OP] Well-Known Member
    SW-VA
    Tundra w/ TRD 5,7L V8 4x4
    (As there is not a general 'vendors' board, I put the thread here)
    Do you know of anyone that makes grille inserts? I am wondering if a thin mesh grille to house the horned emblem plus an insert could work to produce something like this:
    I am guessing that if something like a Satoshi grille can be installed, a two-layered system could be done in lieu. Problem is, I have seen inserts for Dodges and Fords, but none for the Toyotas...I see no reason why the rust buckets should have all the fun, after all, we made the wiser purchase [​IMG]
    Thank you for any leads that might result in scaring people at night on the highway.
  2. May 14, 2011 at 11:46 AM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Our grilles are too small for stuff like that probably
  3. May 14, 2011 at 11:49 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Are you sure you want something like that?
  4. May 14, 2011 at 1:30 PM
    Fenrisulfr
    SW-VA
    Why would I make a thread about it if I didn't?
  5. May 14, 2011 at 1:32 PM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    Are you going for the jaws look?
  6. May 14, 2011 at 1:35 PM
    tecate12
    tecate12 Fuuaaaaaaa!!
    Martin
    El Paso,TX
    Tina: The EPT Blue Beast
    K&N Cold Air Intake, pioneer AVH-4200 DVD, WT floorliners, colormatched engine cover, Westin Bull Bar with driving lights, N-FAB step bars, Rear TSB, Bilstein 5100's @ 1.75, 265/70/17 Dick Cepek MUD COUNTRYS on 17" Black TRD sport wheels, Satoshi Grill, Custom TRD tire valve Caps, and still coming...
    idk if anyone makes it BUT im sure its possible... if you make it yourself...
    hit up a local welding shop and show them a pic of a satoshi they petty much just have to cut out teeth and weld them on some how...
    haha come on people answer the question... he's not asking if you like it he's asking if you've seen it ! why do people always do that??
  7. May 14, 2011 at 1:36 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    4.88s w/h rear Powertrax locker, Fox 2.5 Ext. RR COs, Camburg 1.25” ucas, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, 315/75/16 BFG KM2, 16x10" custom beadlocks, BFF front hybrid, GSF rear HC, Relentless Fab ifs skid, BAMF lca skids, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, LCE Dual Comp clutch, URD ss, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, ARB compressor, Grillcraft, FXR TRS, T1 eyelids, 500 hellas w/h 6k hid conv., custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers, Weather Tech
    haha good point, might look kinda funny though
  8. May 24, 2013 at 9:01 PM
    Fenrisulfr
    SW-VA
    It worked on the Tundra [​IMG]
