MESO Dome light installed. Now my interior lights won’t work right?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Flash1034, Jan 28, 2019.
  1. Jan 28, 2019 at 4:47 PM
    Flash1034
    Flash1034 [OP] Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Ok. Got my Meso ultimate dome light today. After I installed it, the interior lights will work manually, as in when I turn the switches on and off, but they won’t turn on when I open the door or turn off when I close the door. Any ideas?
  2. Jan 28, 2019 at 4:50 PM
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    My first reaction is to ask whether you have the selector in the door position. But I am sure you checked already.
    Recommend you post in Meso thread.
    But a tag to @mesojdm might help as well.
    I haven't had that issue but I am also a 2nd gen. Good luck hope you get it worked out
  3. Jan 28, 2019 at 4:53 PM
    Flash1034
    N/W Montana
    Yep, the switches work in the manual on position but not in the door position. It’s almost as if the truck doesnt know if the door is open or closed. Anybody know what controls that function so I can look there?
  4. Jan 28, 2019 at 4:55 PM
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    You probably blew a fuse. I did the same thing. Check in the driver's side fuse panel
  5. Jan 28, 2019 at 5:13 PM
    Flash1034
    N/W Montana
    Fuses checked and all good. I’m at a loss...what controls the dimmer? Maybe that’s the Problem?
    Alesimo likes this.
  6. Jan 28, 2019 at 6:14 PM
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    Not related to the MESO product per say, but I have read other threads where a short or something during install did something to the BCM (Body Control Module) that controls the dimming. I would put the stock bulb back in, and if it still doesn’t work right take it to the dealer and say NOTHING about putting an LED in the dome light. A buddy of mine had to do this exact thing. Also, even though it’s just a bulb, always remove the negative cable when changing ANYTHING on these trucks.
    SR-71A likes this.
  7. Jan 28, 2019 at 6:24 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Can’t see how it would short anything out. I just installed a second set of these tonight. Turn interior lights off, plug in adapter, turn lights back on to see if it works... if not flip the bulb adapter around and g2g.
    OP, does the light work properly with the standard bulb still?
  8. Jan 28, 2019 at 6:32 PM
    Flash1034
    N/W Montana
    The lights work. They just don’t come on or turn off with an open and closed door anymore. They will go on and off if I switch them manually.
    Where is the BCM?
  9. Jan 28, 2019 at 7:19 PM
    ChrisK7UND
    Colorado
    Not sure where it is at. One other thing to try first is to disconnect the battery for 10 minutes. It should reset everything. IF that doesn’t fix it, it may need a dealer visit and again DO NOT mention the LED’s. Im telling you my buddy had the same thing happen with a simple Sylvania LED from Autozone. He somehow shorted across the socket when taking the old bulb out.
  10. Jan 28, 2019 at 7:30 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Just to rule anything out, try swapping the stock bulb back in. Also disconnect your batter to reset the computer
  11. Jan 28, 2019 at 7:39 PM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    Also, a blown fuse can appear normal. Try putting the stocks back in like Meso said but never trust the appearance of a fuse. You gotta switch the fuse out or test it to see if it’s getting power is the only true way.
  12. Jan 28, 2019 at 7:46 PM
    Flash1034
    N/W Montana
    The lights work so I don’t think it’s a fuse. They just don’t come on when I open the doors or fade off when I close the doors.
  13. Jan 28, 2019 at 9:54 PM
    Flash1034
    N/W Montana
    Arg....so frustrating....
  14. Jan 28, 2019 at 9:54 PM
    Flash1034
    N/W Montana
    I disconnected the negative. Let sit for 30 seconds. No change.....
  15. Jan 28, 2019 at 10:05 PM
    wessyder
    wessyder Enlightened OR Bro who don't need no skewp
    2019 Tacoma TRD OR, basically an off road race truck
    Tied several boat anchors to my truck to destroy MPG.
  16. Jan 29, 2019 at 6:06 AM
    ChrisK7UND
    Colorado
    I hate to say it but that is what happened to my buddy. If you somehow shorted the connection even for a split second it could have damaged the BCM. I would put all the stock bulbs back in and call the dealer and again DONT say a word about changing the lights to LED’s.
  17. Jan 31, 2019 at 7:22 PM
    MESO
    State of Jefferson
    Did you disconnect your battery when changing out lights?
  18. Jan 31, 2019 at 7:36 PM
    ChrisK7UND
    Colorado
    They run $200 to $400 online. Not sure if a dealer has to do any programming etc. my buddy had the dealer replace it and said NOTHING about messing with the LED’s.
  19. Jan 31, 2019 at 7:42 PM
    Flash1034
    N/W Montana
    Ok. They said they replaced the BCM and the dimmer still doesn’t work...any other ideas? What else could it be?
    No, I just turned the dome lights off.
  20. Feb 1, 2019 at 3:47 PM
    ChrisK7UND
    Colorado
    Wow, not sure what else it could be. His was the BCM. Out of ideas. :(
