MESO Puddle Light build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Jan 12, 2019.
  1. Feb 14, 2020 at 6:53 PM
    #5041
    brentano
    brentano Well-Known Member
    2017 TRD OR AC SSM
    Cut the 12V Constant and splice in (on the "Y' harness side) a 20A output from your SwitchPros. The SP curcuit should be configured battery active high and the overcurrent for this circuit should be set to 5A.
    With the Meso switch set to "On", you control the puddle on/off directly with the SP panel (or bluetooth).
    With Meso switch set to "Auto", the SwitchPros switch operates as a kill switch for the normal auto operation.
    With Meso set to "Off", the SwitchPros switch has no effect (the puddle remains off because it is ungrounded).
    May be a decent mod if your SP panel is not co-located with the Meso puddle switch or if you like the idea of controlling the puddles via bluetooth.
    Cutting the 12V (Constant) has no effect on the Ultimate LED turn signal operation because the LED turns do not use this circuit. See here for reference.
    Murdoch33[QUOTED] and MESO[OP] like this.
  2. Feb 14, 2020 at 6:54 PM
    #5042
    Tkoma702
    Tkoma702 New Member
    2017 TRD Sport
    MESO[OP] likes this.
  3. Feb 14, 2020 at 7:41 PM
    #5043
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    It's not as bad as you think, if you want, we can go over it in PMs
    I've actually just done it earlier, I can take pictures of it tomorrow morning.
    corgimas and ageisler[QUOTED] like this.
  4. Feb 14, 2020 at 8:22 PM
    #5044
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
  5. Feb 14, 2020 at 8:28 PM
    #5045
    Octaviolg
    Octaviolg Well-Known Member
    Octavio
    Trd pro
    @MESO switch doesnt fit on empty slots... top is a caliraised and bottom oem open slot... any ideas:confused:
  6. Feb 14, 2020 at 8:33 PM
    #5046
    kecknj
    kecknj Well-Known Member
    Nick
    '19 TRD Off-Road
    I have an extra T harness from my DSIM kit if you want to do it plug and play. You can just pay shipping if you want it. Pm me if interested
    stiles88[QUOTED] likes this.
  7. Feb 14, 2020 at 8:33 PM
    #5047
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Yes. He is one of my dealers, so buy with confidence. Another reason I ran out so early :oops:
    I don’t see a small switch hole in that setup. The top is a snap in TALL, and the bottom right hole is a TALL Toyota switch. You need a small slot(like the 400w inverter)
    Rainoffire, BOMBS and Inferno__Taco like this.
  8. Feb 14, 2020 at 8:39 PM
    #5048
    Octaviolg
    Octavio
    Trd pro
    o_O i guess it was not made for mine lol...
  9. Feb 14, 2020 at 8:40 PM
    #5049
    MESO
    State of Jefferson
    I can help. I created a panel just for you ;)
    Rainoffire, Mabel, BOMBS and 4 others like this.
  10. Feb 14, 2020 at 8:41 PM
    #5050
    Octaviolg
    Octavio
    Trd pro
    So that will work for the top right?.. price?..
  11. Feb 14, 2020 at 8:58 PM
    #5051
    Justin_Exploring
    Justin_Exploring Well-Known Member
    2019 BRM Tacoma TRD OR DCSB 4x4
    Stew, you are the man.
    I gotta try and be patient and wait for the second or third drop of something instead of getting the initial run :rofl: I’ll be one of the guys this weekend tapping into something else for switch illumination. I’m going to be installing heated seats as well and would ideally like to tap all three of those switch illuminators to the same source. I’ll shoot you an email tomorrow with what I was thinking if that’s cool
    Inferno__Taco likes this.
  12. Feb 14, 2020 at 9:02 PM
    #5052
    Murdoch33
    Murdoch33 Well-Known Member
    2018 Black TRD Pro
    Thank you kindly. I might need a touch of guidance but this is awesome! I appreciate the time you took to document all this :fistbump:
  13. Feb 15, 2020 at 3:47 AM
    #5053
    ageisler
    ageisler Well-Known Member
    Florida
    2019 Tacoma TRD 4x4 Off Road - Double Cab
    3” front - 2” rear level kit, 285/75/r16 Falken Wildpeak AT3W, Auxbeam LED Headlights and Foglights
    Thanks @CttAznRanger, trying to install the puddle light switch without having to purchase any aftermarket panels. Just don’t know what’s involved with using one of the blank switch spots on the stock center console panel below the radio / AC. I was gonna just try taking a flathead screwdriver to pop out one of the blank pieces, and then sliding MESO switch in its place. For some reason I’m thinking it’s gonna take more than that lol...
    corgimas likes this.
  14. Feb 15, 2020 at 4:54 AM
    #5054
    CttAznRanger
    Brandon
    Boston, MA
    It will require a little bit more, you're right. But it's not as difficult as you may think.
    I ended up using a thin blade to pop out the switch, just as you said. I did end up taking out the center console and QI charger area so I could wiggle the plastic around a bit. Took a wire and fished it to the area above the pedals, then just fished the wire up to the A pillar.
    ageisler[QUOTED] likes this.
  15. Feb 15, 2020 at 4:57 AM
    #5055
    ageisler
    Florida
    Did taking out the center console require removing nuts and bolts etc?
  16. Feb 15, 2020 at 5:08 AM
    #5056
    CttAznRanger
    Brandon
    Boston, MA
    Total of 2 bolts, 3 screws, and a lot of clips.
  17. Feb 15, 2020 at 5:13 AM
    #5057
    ageisler
    Florida
    I’ll attempt it this afternoon if the weather cooperates. Post some pics of how awesome it looks whenever ya can! Of course it wouldn’t be as easy as just sliding the MESO switch in and feeding the harness in from behind while leaving everything in place
    CttAznRanger[QUOTED] likes this.
  18. Feb 15, 2020 at 6:54 AM
    #5058
    kecknj
    Nick
    '19 TRD Off-Road
    Wait are you talking about removing the switch blanks? Those clip in... No screwdriver needed, just squeeze at top and bottom behind the console... I think?
  19. Feb 15, 2020 at 6:59 AM
    #5059
    ageisler
    Florida
    Yes, I’ll give that a shot before using a screwdriver / utility knife. Was hoping it would just be an easy slide new switch in its place and run the puddle light harness behind it up to A pillar. Sounds like you’ve gotta take more apart however, no biggie. Always looking for the easy way out lol
  20. Feb 15, 2020 at 7:01 AM
    #5060
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Look up Meso thread on the pro knob replacement, look for his video. He details the puddle switch swap pretty well in there.
    ageisler[QUOTED], BOMBS and kecknj like this.
