MESO V5 DRL incab "connection"
Discussion in '3rd Gen. Tacomas (2016-2023)' started by caribe makaira, Oct 2, 2021.
  1. Oct 2, 2021 at 2:23 AM
    caribe makaira
    caribe makaira [OP] Well-Known Member
    Caribbean, Puerto Rico
    Overall
    Vehicle DRL circuit, connector 1F pin 30 at Main Body ECU
    Bright side
    Dim side
    Relays, coil Low activated (negatively/ground) by DRL 1F_30 tie
    Relays actuated by tie to Unlock/Door Open cab illumination circuit.
    Upon unlock (Most Tacoma versions) Headlight DRL and V5 Bright DRL are ON. Same for when Door Open input (x1~4) is received to main Body ECU.
    Diodes are there to prevent feedback to Main Body ECU.
    For entertainment purposes only, no warranties offered or implied, for Mall use only, void where prohibited, non-commercial use only.
  2. Oct 2, 2021 at 11:53 AM
    caribe makaira
  3. Oct 2, 2021 at 12:19 PM
    caribe makaira
    Simplest:
  4. Oct 2, 2021 at 1:07 PM
    lylefk
    lylefk Well-Known Member
    Maui, HI
    '21 4wd Cement Sport DCSB
    Nothing major
    Nice, but seems simpler to me to just go through the firewall and directly to the headlights. :notsure:
    $yoda$ likes this.
  5. Oct 2, 2021 at 1:14 PM
    caribe makaira
  6. Oct 2, 2021 at 1:15 PM
    lylefk
    Maui, HI
    Nothing major
    That’s fair I guess
  7. Oct 2, 2021 at 2:15 PM
    caribe makaira
    This install provides the V5 a parallel function with the Headlight DRL and all controlled by the DRL select position on the light stalk (if present).
    Also, for those with SR (and contemplating on adding the mirror turn signals), the terminal at 1F_30 is active too, so a wire that can wedge into the space will do (still working on finding correct terminal and source)
  8. Oct 2, 2021 at 3:34 PM
    lylefk
    Maui, HI
    Nothing major
    Same as going to the *led headlight, right?
  9. Oct 2, 2021 at 3:35 PM
    caribe makaira
    Nope
  10. Oct 2, 2021 at 3:37 PM
    lylefk
    Maui, HI
    Nothing major
    That’s a surprise… @daveeasa your harness doesn’t provide the full drl functionality from the stalk? Thought it did.
  11. Oct 2, 2021 at 3:41 PM
    caribe makaira
    read post #7..slowly...
  12. Oct 2, 2021 at 3:42 PM
    lylefk
    Maui, HI
    Nothing major
    I read it, perhaps you can explain the difference?
  13. Oct 2, 2021 at 3:43 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Caribe is saying no to the question of “is it the same”. Perhaps a better question is “does it behave the same?” However the answer is still a bit of a no. The ECU controls the DRL signal such that if you start the truck and leave parking brake engaged, headlight DRL is off even if stalk is DRL.
    For layman’s terms it’s close enough to match expectations. But it’s not “the same”. Adds a relay but eliminates need to run through the firewall.
    ktbell444 likes this.
  14. Oct 2, 2021 at 3:45 PM
    caribe makaira
    Think Te Fiti & Te Ka...
    Difference on headlamp T is the DIM input to V5 happens before Low beams are selected. So you get Bright DRL at the Headlights and DIM at the V5..that is all.
  15. Oct 2, 2021 at 3:46 PM
    daveeasa
    David
    PNW
    Oh but nice move to add the cargo / unlock part! Well done @caribe makaira
  16. Oct 2, 2021 at 3:47 PM
    caribe makaira
    Maui would luv da Taco in Lahaina doing dat...
    lylefk likes this.
  17. Oct 2, 2021 at 3:48 PM
    daveeasa
    David
    PNW
    I will check this on the truck, stalk to parking lights? Pretty sure headlights dim. I suspect you know better than me though.
  18. Oct 2, 2021 at 3:51 PM
    caribe makaira
    Verified many times, that is why the diode is in place for the grill lights. So many crimps and exposure to materials that may cause illness...has its effects on the memory:burp:
    daveeasa[QUOTED] likes this.
  19. Oct 2, 2021 at 3:52 PM
    lylefk
    Maui, HI
    Nothing major
    Just getting to the beach with the fam, I’ll give this a read when I have time to process it lol. Thanks
  20. Oct 2, 2021 at 3:56 PM
    daveeasa
    David
    PNW
    So +1 on verifications. Interesting bit of trivia. I didn’t realize this before today. I though DRL from ECU goes off with parking lights on.
    I suppose the mirrors matching the headlights offers the best symmetry. But not sure I like this behavior for either.
