Meso V5 turn signals are out!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TwinTaco31719, Sep 20, 2021.
  1. Jan 19, 2022 at 12:42 PM
    #301
    caribe makaira
    Caribbean, Puerto Rico
    @mokeiko, I'm thinking you had halogen DRL's before you swapped to 2020 LED headlamps...
    mokeiko likes this.
  2. Jan 19, 2022 at 12:47 PM
    #302
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I have 2020 OEM LED headlights, yes. I have a 2016 Tacoma, yes. I have MESO v5 mirror switchbacks but have not yet installed them, only bench tested them. With red wire they go full bright, with white wire they go dim. Everything looks and works as expected.
    The DRL T tap I provide in my headlight conversion harness provides the same two signals that the MESO DRL T tap provides, DRL and Park. The only difference with my v5 module vs MESO's is I provide a 5' pigtail with 3/16" pvc tubing to feed through the firewall so you can connect inside the driver side kick panel vs inside the engine bay. Which isn't a significant difference but I tend to prefer keeping my engine bay clean and accumulating clutter in my kick panels.
    Harnesses don't "work differently" when they are just wires connected to terminals. You need relays or circuits to "work differently".
  3. Jan 19, 2022 at 12:50 PM
    #303
    daveeasa
    David
    PNW
    As stated several times, high beams on or off does not affect the DRL signal. DRL is off once low beams are on and stays off with high beams (as low beams are still active). I think you are getting hung up on this piece of information.
    When the parking light signal is active, the v5's will receive +12v on the white wire and will go dim. The only time the v5's are bright is when the DRL (red wire) has +12v and the parking light (white wire) does not.
    I know of no difference in ECU behavior between trucks with halogen headlights and trucks with LED headlights. My OEM LED headlights behave exactly as Caribe has described.
  4. Jan 19, 2022 at 1:02 PM
    #304
    caribe makaira
  5. Jan 19, 2022 at 1:04 PM
    #305
    GreenTexasTaco
    GreenTexasTaco Tiny Member
    Texas
    2022 Army Green TRD OR DCLB
    I thought the harness only worked if you have halogen headlights, and those of us with the factory LEDs were out of luck? The Meso site specifically says, “DRL PNP Harness (Non LED Headlights).”
  6. Jan 19, 2022 at 1:07 PM
    #306
    daveeasa
    David
    PNW
    I do an LED T tap for LED-from-the-factory-boy-aren't-you-lucky Tacos.
  7. Jan 19, 2022 at 1:08 PM
    #307
    caribe makaira
    That's the Halogen Headlight intercept harness.
    daveeasa likes this.
  8. Jan 19, 2022 at 1:10 PM
    #308
    daveeasa
    David
    PNW
    I have to say, I do kind of like the "full bright DRL" mode with high beams idea. Though I might even want that for the headlights themselves. I am not sure on current draw though, so not sure a 1amp diode would be sufficient to combine DRL and High to feed the MX-150 DRL pin.
    I'm not sure anyone could see it though, with all the low and high beam emitters firing.
    That combination works just fine on the bench if I turn on all of the pins except turn (full bright DRL, TRD logo, high beam emitters, low beam emitters).
  9. Jan 19, 2022 at 1:18 PM
    #309
    caribe makaira
    Don't combine, High Beams feeds the relay coil.
    Diode is to prevent DRL going to BRIGHT. (If that is what is wanted) if not, it stays the same, a tap to DRL to V5's.
  10. Jan 19, 2022 at 1:21 PM
    #310
    mokeiko
    mokeiko Active Member
    2017 Tacoma OR 4x4 DCSB SSM AT
    What could the issue? As mentioned before I do not see any difference in brightness in the meso v5 DRL no matter what position my stalk is. The meso v5 DRL has constant light in Auto, DRL (Parking), and On.
  11. Jan 19, 2022 at 1:26 PM
    #311
    daveeasa
    David
    PNW
    Get a meter out and probe. And/or add photos of how you connected things at the headlight and where the v5 harnesses join. If hooked up properly you should see no DRL when stalk is off, bright when on DRL, dim at all other times.
  12. Jan 19, 2022 at 1:29 PM
    #312
    daveeasa
    David
    PNW
    I took a side diversion to this:
  13. Jan 19, 2022 at 1:32 PM
    #313
    caribe makaira
    All high?:rasta:
  14. Jan 19, 2022 at 1:33 PM
    #314
    daveeasa
    David
    PNW
    Rasta mode FTW. It's kind of fun but honestly the full bright C is drowned by the high and low beam emitters so juice not really worth the squeeze.
  15. Jan 19, 2022 at 1:34 PM
    #315
    caribe makaira
    I agree.
  16. Jan 19, 2022 at 1:37 PM
    #316
    mokeiko
    If hooked up properly you should see:
    no DRL when stalk is off - check
    bright when on DRL - can't tell if dim or bright, light just on
    dim at all other times - - can't tell if dim or bright, light just on
    I thought turning on brightness on headlights affected v5 DRL brightness as well and dimming on headlights affected v5 dimming, I was wrong in assuming this, I apologize.
    I have a meter but I don't know what to probe. I will get photos after work.
    Thank you everyone for bearing with me.
  17. Jan 19, 2022 at 1:44 PM
    #317
    daveeasa
    David
    PNW
    Probe red and white where v5 harness meets with headlight feed. Document voltages for each stalk position.
  18. Jan 19, 2022 at 1:49 PM
    #318
    caribe makaira
    Full Bright V5 with High Beams should look nice I think.
  19. Jan 19, 2022 at 1:52 PM
    #319
    daveeasa
    David
    PNW
    Yeah it’s a cool idea.
  20. Jan 19, 2022 at 2:04 PM
    #320
    daveeasa
    David
    PNW
    Another important detail for anyone not familiar. You have to release the parking brake once to activate the DRL signal from the ECU. You can put it back up after.
    th3clara and ktbell444 like this.
