Meso V5 turn signals are out!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TwinTaco31719, Sep 20, 2021.
  1. Jan 20, 2022 at 10:47 AM
    #341
    mokeiko
    mokeiko Active Member
    2017 Tacoma OR 4x4 DCSB SSM AT
  2. Jan 20, 2022 at 10:51 AM
    #342
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    So does the passenger side feed in somewhere? Is it this piece? Or is this something different?
    Maybe next is photos of the headlight with stalk on drl where we can see the mirror, then switch to park, another shot, then to low beam, another shot. preferably in low ambient light?
  3. Jan 20, 2022 at 10:58 AM
    #343
    mokeiko
    This is the drivers side v5 wire.
    The passenger side feeds through the passenger firewall, which I realized I should have went inside and meet up with the drivers side and then go through driver side firewall. I did check each position in my garage at night without the garage lights on and the DRL brightness does not change.
  4. Jan 20, 2022 at 11:05 AM
    #344
    daveeasa
    David
    PNW
    So a photo of where passenger and driver are embracing perhaps? Still likely a non-issue. I think next step is to observe headlight with mirror light in the frame across the stalk settings, I see no problems so far so I want to understand the behavior you are seeing light-wise.
  5. Jan 20, 2022 at 8:45 PM
    #345
    mokeiko
    I was able to test the v5’s DRL dim and brightness modes by connecting the red wire first then white wire to the positive post of the battery using a 5a. Fuse in between and they work. I’ve now seen the difference in dim and bright settings. So it seems the v5’s are in dim mode no matter what the position is at the stalk except for off position. This also means that the white wire is getting the +12 volts and the red wire isn’t. I was able to confirm this using a meter.
    How is it then possible for +12 volts (white wire) to be present at all stalk positions except off?
    OFF - No current
    AUTO - +12 volts white wire, 0 volts red wire
    DRL - +12 volts white wire, 0 volts red wire
    ON - +12 volts white wire, 0 volts red wire
    The 2020 LED headlight DRL does not change in brightness in any of the stalk positions. They are just on, not sure if it’s bright or dim.
  6. Jan 20, 2022 at 8:56 PM
    #346
    caribe makaira
    Caribbean, Puerto Rico
    Did you confirm that the vehicle was ON, and the parking brake released when you cycled the stalk switch?
  7. Jan 20, 2022 at 9:52 PM
    #347
    mokeiko
    vehicle was off, parking brake off. I will try with vehicle on
  8. Jan 21, 2022 at 6:29 PM
    #348
    th3clara
    th3clara Well-Known Member
    Trevor
    Portland, OR
    2020 TRD Pro - Army Green
    RIDE Shocks 285/75r17
    I have a 2020 and Dave’s T harness. I struggled with figuring this all out. I found that parking brake off isn’t enough, you need to take it out of park and put it in drive/reverse, and then a few seconds later the mirrors signals change brightness.
    I also noticed the behavior changes when I was testing at night, vs daytime. I believe the ECU takes into account whether there is “daylight”, so stalk position in DRL position isn’t the only thing to account for when testing.
    Correct me if I’m wrong on any of that, but those are my observations so far.
    mokeiko[QUOTED] likes this.
  9. Jan 21, 2022 at 6:32 PM
    #349
    mokeiko
    I was driving home thinking about that as well, I’m glad you brought it up.
    Last night I drove forward and reversed, put it in park with no hand brake but nothing changed unfortunately
    th3clara likes this.
  10. Jan 21, 2022 at 6:35 PM
    #350
    caribe makaira
    Since you tested one lamp, I'd say the issue is somewhere in the connection to the headlights.
  11. Jan 21, 2022 at 7:24 PM
    #351
    daveeasa
    David
    PNW
    @caribe makaira the stalk in @mokeiko looks different from the one in my truck. Mine has Off, DRL, park, low and his says “DRL off” then auto then park then low. Is that maybe Canadian style? Or just auto headlights introduced in 2017?
  12. Jan 21, 2022 at 7:37 PM
    #352
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    My 2017 TRD OR had the DRL Off, Auto, etc. So maybe? It had every package if that helps. Does your 16?
    mokeiko likes this.
  13. Jan 21, 2022 at 7:51 PM
    #353
    TacomaGuy7878
    TacomaGuy7878 Mmmm....Tacos
    CO Mountains
    2020 AG Pro
    2020 Pro here and my stalk says DRL off, auto, park then low. If that helps. Seems to me that the new stalk came w/ the auto headlights 2017 as you said:thumbsup:
    mokeiko and daveeasa[QUOTED] like this.
  14. Jan 21, 2022 at 7:57 PM
    #354
    caribe makaira
    There are 3 styles.
  15. Feb 1, 2022 at 3:34 PM
    #355
    Lphonzy09
    Lphonzy09 Well-Known Member
    Texas
    2022 Midnight Black Metallic SR5
    Hello,
    my 2022 SR5 has turn signal mirrors. I don’t need to do the whole DRL install route. Just want to wire them through window switches.
    I looked at the install write up on meso customs website, but can’t figure out which wire to tap into for the window switches. The colors are different and sadly, I don’t have a voltage tester at the moment. Also, My window switch doesn’t have the Auto function, so I have less wires on the connector.
    any help would be appreciated!
    Anyone in the same boat have experience?
  16. Feb 1, 2022 at 5:07 PM
    #356
    caribe makaira
    Passenger's side:
    Lphonzy09 and daveeasa like this.
  17. Feb 1, 2022 at 6:15 PM
    #357
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    No good when ur using one quick connector and have 2. different size wires to tap into
  18. Feb 1, 2022 at 6:32 PM
    #358
    caribe makaira
    No good? No good for you.:jerkoff:
  19. Feb 2, 2022 at 12:05 PM
    #359
    Lphonzy09
    Texas
    much appreciated! I will return my double t connector and get t taps.
    Had some time to properly read the thread. Am I right to assume that:
    Passenger side is the p14 connector and i should wire to pin 2 (bright function-white wire) & what about pin 6 for dim?
    Driver side is the O1 connector and should wire to 7 & 8?
  20. Feb 2, 2022 at 2:26 PM
    #360
    caribe makaira
    Yes on both.
