Meso V5 turn signals are out!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TwinTaco31719, Sep 20, 2021.
  1. Sep 25, 2021 at 5:51 PM
    #121
    Criera
    Criera Well-Known Member
    South Bay SF, CA
    2020 TRD Pro
    My driver side has 3 leds out also, oh well, first world problems.
  2. Sep 25, 2021 at 5:58 PM
    #122
    caribe makaira
    Caribbean, Puerto Rico
    Or is it this you are referring to:
    RyanDCLB likes this.
  3. Sep 25, 2021 at 7:13 PM
    #123
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    That's it!
  4. Sep 25, 2021 at 7:21 PM
    #124
    caribe makaira
    :thumbsup:
    RyanDCLB[QUOTED] likes this.
  5. Sep 25, 2021 at 8:21 PM
    #125
    caribe makaira
    Passenger's side. No DRL control to ON...
    2 = IGN
    6 = PANEL/TAIL
    Skydvrr likes this.
  6. Sep 25, 2021 at 8:41 PM
    #126
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I hope I remember this whenever I get the motivation to take my stuff apart again haha.
  7. Sep 25, 2021 at 8:44 PM
    #127
    caribe makaira
    Do you have the skills to remove the arm rest where the switches are on the front passenger door?
  8. Sep 25, 2021 at 8:57 PM
    #128
    Silver'16TRDSportDCLB
    Silver'16TRDSportDCLB Well-Unknown Member
    Nate
    South-Eastern PA
    2016 Silver Tacoma 4x4 Sport DCLB
    Lights, stickers, audio, and a grille…
    Got mine today, and installed today! All LEDs working so far! They are bright af! Wired the DRL into the door illumination thanks to @caribe makaira ’s suggestion to avoid the dreaded door boots. Works like a charm! Love my V5’s! Thanks Meso!:D:101010:
    devale and SoCalSport like this.
  9. Sep 25, 2021 at 9:01 PM
    #129
    caribe makaira
    :woot:
  10. Sep 25, 2021 at 10:30 PM
    #130
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Wait.....which arm :eek::confused:
  11. Sep 25, 2021 at 11:01 PM
    #131
    caribe makaira
    Skydvrr[QUOTED] likes this.
  12. Sep 26, 2021 at 1:18 AM
    #132
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Do u not have to remove the whole door panel as well?
  13. Sep 26, 2021 at 3:30 AM
    #133
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    So, recognizing this is embarrassing.....does anyone have a "Wiring Connections For Dummies" version of how to connect the V5s to get the DRL illumination? Is the install video on @MESO 's page for switchbacks the right way to go? I understand how to install them - just don't get how to wire them to get the DRL function.
    Color me embarrassed, but.....
  14. Sep 26, 2021 at 5:10 AM
    #134
    RyanDCLB
    4/19 DCLBOR
    I'll take a stab (please correct me if I'm wrong)...
    By any chance did you purchase the add-on T-harness for the front headlights? This harness makes it easy to match the DRLs "Bright and Dim" function. Otherwise, you'll need to tap into the headlight harness (non OEM LED) to get this function (using the positive wires only). This feature requires removing both door panels, and running wires through the door boot, through the firewall, and into the engine bay.
    Or, you can settle for Bright DRLs only, and tap into either puddle pods (if you have them), or the window switch (as @caribe makaira suggested above). Frankly, you can use just about any "switched positive wire" for full Bright illumination, but the window switch is super convient.
    The Bright and Dim function allows Bright during full sun, or DRL only, and Dim setting at night when the headlights are ON (an unknown function to most).
    @daveeasa makes a T-harness for the new LED headlights in the inrerim found here. This is only until @MESO starts producing his own.
    @daveeasa might catch on, and make a PNP harness to tap into the window switch, similar to the ktjo bowl lights, but without the "interior dimmable dash light" function. Otherwise, you might need vampire clips, or a solid T-tap. That's why the puddle pods are convient because @MESO included an extra lead plug for something like this.
    Hope this helps! :D
    NickyNacks likes this.
  15. Sep 26, 2021 at 5:22 AM
    #135
    Devious6
    Mark
    Thanks! I have LED headlights so I can't use the current MESO T-harness. (Right?) I'll check out @daveeasa 's T-harness..or perhaps wait for MESO to do his. Maybe, I just need to find someone smart enough to wire this up for me. :D
  16. Sep 26, 2021 at 6:10 AM
    #136
    caribe makaira
    In your case, of course. For him, no.
    Skydvrr likes this.
  17. Sep 26, 2021 at 6:13 AM
    #137
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    I would actually like to wire mine so they work with the headlights rather than the drls. Just like my old FJ Cruiser mirror lights.
  18. Sep 26, 2021 at 6:36 AM
    #138
    caribe makaira
    I suggest installing them now, to verify the illumination. Turn select feature of choice and the DRL High & Dim.
    Run the DRL dual wire through the door and either:
    1 - Leave it coiled n taped between the door and door panel.
    2- Run through the door boot and leave it coiled and taped also.
    When the Team is ready everyone will have a few choices for parallel control of the DRL settings of the V5.
    If the choice is only DRL High all the time (Red wire only): Fused IGN source at the door could be the choice.
    If the choice is DRL High then Dim, door is also a source choice.
    The issue with this one is: you loose DRL High at parking light input and no headlights (not OEM style - switch to dim at Low Beam) Canadian version are "special" with the TAIL circuit always ON.
    WhiteTaco20 and Devious6[QUOTED] like this.
  19. Sep 26, 2021 at 6:47 AM
    #139
    caribe makaira
    Passenger's side -
    De-pinning the connector removing the terminal, crimping a new one with dual wires is also a choice.
    V5 DRL would get Bright input on fused IGN source (#2 wire) and they would DIM when the input of the illumination wire source is available (#6 wire)
    Driver's side (Many choices), the remote mirror switch connector:
  20. Sep 26, 2021 at 6:53 AM
    #140
    Tacospike
    Two Trucks
    Duplicate post for anyone if missed or follows this thread rather the BST thread
    Got mine done a little while ago. 20 minute install, maybe a little more taking pics and checking connections
    some noticeable differences in person. Phone might show a little different, lighting, distance, exposure, angle blah blah
    limited editions / V5’s
    LE’s
    V5’s
    a lot more wiring components with the LE’s. Not even showing the drl wiring in the truck. Currently using that.
    **LE’s are SOLD**
