Metal Detecting discussions and finds
Discussion in 'Sports, Hobbies & Interests' started by WileECoyote, Aug 8, 2018.
  1. Jan 8, 2020 at 10:52 PM
    #641
    WileECoyote
    WileECoyote [OP] Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    HAHAHAHA, your typical "stinkin zincoln"!!!
    AWESOME first find though either way!!! :thumbsup::fistbump:
    Hobbs and wilcam47[QUOTED] like this.
  2. Jan 8, 2020 at 11:21 PM
    #642
    WileECoyote
    SoCal
    Btw, @wilcam47 and @samiam it's ALWAYS nice to have different coils, for example, a "sniper coil" for "trashy areas".
    Also, when I hunt parks and such, I like to have a towel with me... roughly the size of a hand towel.
    What I use the towel for is:
    -place the towel next to where I plan on cutting my plug
    -cut my plug after centering in on the object in question
    -flap the plug up and over
    -place whatever excess dirt/soil I am removing from the hole while looking for my find
    -after recovery, pick up the towel with dirt/soil and place back into the hole
    -flap the plug back over the hole
    -stand up and stomp the livin' SHI* out of the plug to pack it back down
    sometimes, I will take my hand and "refluff" the grass to try to make it look like there was never any activity in that spot. :thumbsup:
    excorcist, bucktales, Hobbs and 2 others like this.
  3. Jan 8, 2020 at 11:43 PM
    #643
    WileECoyote
    SoCal
    @samiam Also, silver will typically sound off as a VERY SOLID "dime signal"!!! Okay. :thumbsup::fistbump:
    HH \_
    Btw, wrap your coil cable around the shaft fairly tightly. NOT TOO TIGHT!!! But you don't want too much slack in your cabling!!! Try not to "pull" on the cable or severely kink it also. You want to leave enough slack in the cable so it has freedom of movement, but won't possibly give off false signals because your coil may actually pick up on the cable itself.
    wilcam47 and samiam like this.
  4. Jan 9, 2020 at 7:53 AM
    #644
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Thanks for the advice!
  5. Jan 9, 2020 at 8:50 AM
    #645
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    You're a good man, that's the way to cut a plug clean. Some folks don't and it reflects on all of us.
    TomTwo, excorcist, samiam and 4 others like this.
  6. Jan 9, 2020 at 9:36 AM
    #646
    WileECoyote
    SoCal
    Thanks!!! :thumbsup: I try to do my best to leave it as I found it. Sometimes if the ground is pretty dry, it gets pretty hard to deal with making it look good. :oops: On occasion I will have my canteen of water and use it for the dry dirt situations, but it still doesn't realistically work very well, because I'll run out of water after about 4-5x plugs later. :notsure:
    Anyways...
    samiam and Hobbs[QUOTED] like this.
  7. Jan 10, 2020 at 8:44 PM
    #647
    WileECoyote
    SoCal
    Well, I plan on dry sand hunting some time next week. I finally got my 250 out of storage today and most of my gear.
    I'll be posting pics some time next week. HAHAHAHA, I hope I find some really good "droppings"!!!
    samiam, wilcam47, Hobbs and 1 other person like this.
  8. Jan 10, 2020 at 8:48 PM
    #648
    tcjacado
    tcjacado Well-Known Member
    Happy hunting :thumbsup:
  9. Jan 10, 2020 at 8:57 PM
    #649
    Hobbs
    Yep…
    Good for you! And good luck!
  10. Jan 10, 2020 at 9:31 PM
    #650
    B33
    B33 Well-Known Member
    2017 tacoma TRD Sport
    Mine lab are good I have a Garret ATX its a bit on the heavy side but its what I needed and my buddy has the Mine lab SDC2300
    we mostly look for Gold
  11. Jan 12, 2020 at 11:02 PM
    #651
    WileECoyote
    SoCal
    Doing a "gear and equipment check" tonight. I plan on swinging Tuesday after work as tomorrow I have some errands to do.
    Anyways, I will be posting some pics... garbage or not...
    I've had my GTi-2500 for a number of years now, but haven't been able to use it as much as I've been wanting to. There are a few parks I want to hit with this md'r, but likely will be a couple weeks or more. It's definitely a bit heavier than the 250 and it's been about 1.5-2yrs since I've really done any significant swinging. HAHAHAHA, my legs and arm are gonna be sore. :goingcrazy::bananadead::muscleflexing:
    Btw, the cables are "loose" in the pictures because the tubes aren't extended outward.
    Again, you want the cable to be "snug", but NOT overly tight or pulling of the wire/cable at the housing.
    Hobbs, samiam, tcjacado and 1 other person like this.
  12. Jan 12, 2020 at 11:05 PM
    #652
    wilcam47
    Will
    Bourbon state
    Post pics of what you find. Good luck!
  13. Jan 12, 2020 at 11:15 PM
    #653
    WileECoyote
    SoCal
    Thanks for the good luck!!! :thumbsup::fistbump:
    Yeah, junk or not, I'll be doing that for sure. :thumbsup:
    I'll be dry sand hunting Tuesday after I get out of work. I typically find right around $3, average, worth of quarters, nickels, dimes, and pennies within about a 3hr hunt. It was consistently averaging a $1/hr... HAHAHAHA, almost on the daily. BUT, that was typically a summer time outting. The good thing is is that I was about the only person that was ever dry sand hunting and I've gone both early morning, noon, late evening on various/random days and would almost never see anyone else swinging a coil. You would think being that random I would see someone, but it was pretty damn rare. I DO know of a person that swings on the beach further south, but he surf hunts, which I started doing with my Infinium LS, but MAN, it is definitely technique recovering a find. :goingcrazy: Btw, I LOST whatever it was that I was trying to recover and it was only right around ankle/knee deep surf hunting!!!:annoyed::frusty:
  14. Jan 12, 2020 at 11:40 PM
    #654
    wilcam47
    Will
    Bourbon state
    my goal is to find a mercury dime. It will be cool just to find stuff but thats one i'd like.
    Your $1 an hr reminded me of this..
  15. Jan 13, 2020 at 4:36 AM
    #655
    WileECoyote
    SoCal
    HAHAHA, that's an AWESOME movie!!! :thumbsup::fistbump::laughing::laugh::rofl::rofl::rofl:
    "Vote for Pedro"!!! :oldglory:
  16. Jan 13, 2020 at 5:52 PM
    #656
    wilcam47
    Will
    Bourbon state
    honestly couldnt watch it the first time, but then later watched it over. It was funny the second and multiple times after that I watched it.
    any luck today?
  17. Jan 13, 2020 at 5:55 PM
    #657
    Hobbs
    Yep…
    Good luck to you! Enjoy yourself!
    What brand coil is that on the Garrett Ace?
  18. Jan 13, 2020 at 6:02 PM
    #658
    Hobbs
    Yep…
    I would like to find a Merc myself. That coin is high on my list (after a $20 gold piece :D).
  19. Jan 13, 2020 at 6:11 PM
    #659
    wilcam47
    Will
    Bourbon state
    any gold would be nice;) man that guy that dug a mine shaft under his house is all pissed off now...:rofl:cuz of people ragging on him.
  20. Jan 13, 2020 at 6:12 PM
    #660
    Hobbs
    Yep…
    Sounds like I need to check in on that thread.
    wilcam47[QUOTED] likes this.
