metal to metal sound
Discussion in '1st Gen. Tacomas (1995-2004)' started by devilsalmostfree, Dec 18, 2009.
  1. Dec 18, 2009 at 5:46 PM
    devilsalmostfree
    devilsalmostfree [OP] Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    last few weeks ive been hearing a chirping sound coming from the front of my taco. yesterday morning it quite making the chirping sound & started sounding like the brakes were down to bare metal. i had planned on changing the brakes & having the rotors turned on saturday, but when i heard this, i decided to just go ahead & change the brakes. so i did, i noticed the brake pads that i took off didnt really look half wore out, i went ahead & changed them anyways. i didnt notice anything on either rotor, or anything wrong with the calipers. the drivers front is still making a god awful metal to metal sound. im going to take the dust shield off tomorrow or sunday & give it a test drive, thinking maybe the dust shield might be bent or warped & rubbing against the rotor. when i cut the wheel to the left the sound doesnt completely go away, but isnt near as bad. when i cut it to the right is still sounds the same. any help would be much appreciated, its a 99 taco, 4X4, 2.7 ltr, 5 spd, reg. cab! thanks in advance.
  2. Dec 19, 2009 at 6:44 AM
    devilsalmostfree
    Carl
    Loudon, Tn
  3. Dec 19, 2009 at 6:58 AM
    offroadTRD
    offroadTRD Well-Known Member
    Dinwiddie County, Virginia
    2000 Tacoma V6 SR5 4x4 TRD- Fabtech
    Fabtech 3" adjustable coil-over system, Alcan 8-leaf spring pack, Fabtech 3" body lift.
    check your wheel bearing. that chirping sound you hear is usually the god awful sound that a bearing starts to make when it is going bad. that is my guess.... but I have been wrong before. hope this helps.
  4. Dec 19, 2009 at 7:10 AM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    If the brakes are good, and the dust shield isn't hitting the rotor, about all that's left is the wheel bearing. Does it get louder when turning in one direction? Can you grab the top and bottom of the wheel and feel movement?
    Both of those symptoms point to the wheel bearing.
  5. Dec 19, 2009 at 2:04 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    im going to take the dust shields off tomorrow, i didnt get time today. when i have it jacked up tomorrow ill check for wheel movement. when turning to the left it seems to be a slight bit louder, & quieter when i turn to right.
    ive had a wheel bearing to go out on me before, but i never heard a metal to metal sound from that 1.
  6. Dec 20, 2009 at 6:32 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    ok, well i didnt take the dust shield off, i didnt realize i would have to take the whole hub assembly off or whatever its called to do that! we knocked the dust shield back a bit.
    i checked for movement on the wheel & i didnt feel any movement. got it all back together, it sounded great for a few miles, then a lil squeek of the brake maybe. drove right about 10 miles & it did start to marke the chirping sound a lil bit, no sound while i was turning it left or right though! im guessing it the wheel bearing. what would be the best way to replace it, its pressed in right? so should i just buy a new wheel bearing, take the hub & have a machine shop press it back in, or get a new hub assembly or whatever its called? just wondering what would be the best option?
  7. Dec 22, 2009 at 7:02 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    it hasnt made the metal to metal sound the past 2 days, think its good, or should i try repacking the wheel bearings with grease anyways, before i put new ones in?
  8. Dec 22, 2009 at 7:31 PM
    kevhogaz
    SR5 PreRunner
    The wheel bearings are sealed on your truck, and they're pressed in to the spindle. They are a non-serviceable unit, replace only.
  9. Dec 23, 2009 at 3:13 AM
    devilsalmostfree
    Carl
    Loudon, Tn
    thats what i was telling my friend, he still thought we could get some grease in there. thanks for the help!
  10. Dec 23, 2009 at 4:31 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I would check all of your belt pulleys before ripping the wheel bearings out. Noises can be awful decieving, especially when they come from under the hood region.
  11. Dec 24, 2009 at 8:02 AM
    devilsalmostfree
    Carl
    Loudon, Tn
    i replaced all 3 of the belts a few weeks back, checked the pulley's. there no squeeking sound coming from the engine at idle, or when i rev it up! it would do it as i was rollng down the rd, & at 1 st, worse when i applied the brakes. im not hearing the metal to metal sound now, just a squeek once in a while from the brakes, were it sounds like its coming from. i had no play in the wheel when i jacked it up & checked for that. im thinking it was just the dust shield got bent. ive been driving it the past few days & havent heard anything, im going to let it go until i hear it again, i guess!
  12. Dec 24, 2009 at 8:06 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    I had this problem once. I thought it was the dust shield but it was infact where the lower spindle mounts to the LCA. The 2 bolts on the sides were coming loose. I re-torqued em to spec and haven't had a problem since.
  13. Dec 24, 2009 at 11:52 AM
    devilsalmostfree
    Carl
    Loudon, Tn
    cool man, thanx, ill try to take a look at those in a few minutes!
  14. Dec 30, 2009 at 9:12 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    just out of curiousity is it bad to drive or wheel without the dust shields? i have them off right now
