Metallic "knock" from up front.
Discussion in 'Suspension' started by bigmooze, Mar 21, 2011.
  1. Mar 21, 2011 at 5:02 PM
    bigmooze
    bigmooze [OP] Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Recently (within the last 300 km or so) I have noticed the above ANNOYING sound.
    It normally occurs whenever I am reversing from the street (which has a fairly decent crown in the road) into the driveway (which slopes up toward the garage). I believe the key here is that the suspension is flexing somewhat. During this manouever, the wheels are turned to the left. The knocking sound is a single metallic knock, heard on the driver's side.
    One time, I was reversing onto a down-ward sloping driveway with wheels turned to the right, and the same sound happened on the passenger side.
    The wheels are not at full lock when the noise happens. I am in 2WD.
    Everything seems to be tight. No recent mods to the front end. No fluids leaking from what I can tell. No play in the wheels about the hub (up-down or side-side). Wheels spin in free air without grinding.
    No issues when turning in forward or reverse on flat ground.
    The worst part is, I can't reliably replicate the sound. Has anyone else experienced this?
  2. Mar 22, 2011 at 3:57 PM
    bigmooze
    Richard
    Belle River, ON
    Bump. I have about 93,000 km on the truck, front Bilstein 5100's have been on since about 80,000 km. No issues until recently.
    Any ideas?
  3. Mar 26, 2011 at 2:10 PM
    bigmooze
    Richard
    Belle River, ON
    Took the truck in on Thursday and the tech ended up greasing the steering stops. I thought these only came into play when turning at full lock, but anyway. I haven't heard the knocking since.
    When I was talking to him, he also told me that he has seen sway bar links with dry spots on the joints. He suggested hitting them with some white lithium grease if my noise re-appears.
    While it was there I had the transmisison fluid flushed. Nice to know that the fluid is fresh... next up is an oil change, spark plugs and Ride-Rite install, but I'll wait for the weather to warm up a bit.
  4. Mar 26, 2011 at 2:13 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Good info .
    Thanks
  5. Mar 31, 2011 at 5:55 PM
    bigmooze
    Richard
    Belle River, ON
    Even with the steering stops greased I get a knock.
    Jacked up the front end and inspected everything last night, and everything was torqued properly.
    Attempted to remove the sway bar but decided that I would have to diconnect the tie rod ends so I could maneuver it out, so I quit - didn't feel like doing that. Rubber sway bar bushings and sway bar links were in good order.
    Nothing stands out as being broken, no leaks from the shocks or steering components from what I can tell.
    It definitely happens when turning while the suspension flexes, especially when bumping up or down the small curb at the end od the driveway, but it's not consistent/repeatable.
    I'll continue to keep an eye/ear on things and hope that something non-dangerous shows signs of breakage for repair under warranty (at about 93,000 km now, with extended warranty coverage up to 160,000 km).
  6. Mar 31, 2011 at 6:39 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    You're sway bar may look fine but I suspect it's the part making all the noise. Mine is the same way except that the threads are all jacked up so when it gets warm I'll be cutting that pita out.
  7. Mar 31, 2011 at 11:49 PM
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    Does it sound like some kind of grinding noise when going up a driveway at low speed and at high speed you don't feel or hear it? If so I have the same problem I notice that after my Lt kit but once I got the truck align it went away until I took it offroad and now it's back need to bring it in again to align and see what is loose. You might have the same issue I have. Try getting it align.
  8. Apr 1, 2011 at 6:51 AM
    pAP
    pAP ==========
    NJ
    11 Tacoma SR5
    ARB locker and OBA, All Pro front & rear bumper, All Pro IFS skid & modified t-case skid, Custom Trans Skid., 4x Innovations sliders, Custom tire carrier/bed bars, Warn Winch, Fox 2.5" Front coilover, Walker Evans 2.5" rear Shock, All pro Leaf, All Pro U-bolt flip, Baja Designs lights, PIA 510 lights, TRD exhaust cut back, Doug Thorley Pipe Bomb
    Just an idea...It could be the brake pads. There are pins that hold them in place but still have a bit of room to float. The pads are in a forward position on the pin after parked from going forward. When you go to back up, the pads move back, hit and make a clunk noise. Very common in the toyota trucks, 4-runner and Fj's. Does it only happen after going say forward then backing up? or vise versa. Worth trying to see if thats it.
    Pap
  9. Apr 1, 2011 at 11:06 AM
    bayou_fennec
    bayou_fennec blah blah blah
    Austin
    05' PreRunner
    Kenwood Head Unit, Bed Mat, Weather Tech Floor Mats, Nfab Wheel 2 Wheel Step Bars, LED Bed Lights
    Had the same problem in my '05 double cab for about 3 months. finally found a post on here (somewhere) that suggested tightening the LCA bolts. that was it. the passenger side lca bolt was loose. apparently, when i had an alignment done, they didn't torque it back to specs. no problem since.
  10. Apr 1, 2011 at 1:41 PM
    bigmooze
    Richard
    Belle River, ON
    Thanks, I'll try this. Is there any harm in tightening them? Could I move the cams by just tightening the LCA bolts? Obviously I want to avoid that.
    I had an alignment done a while ago but I'll check anyway.
  11. Apr 1, 2011 at 1:45 PM
    bigmooze
    Richard
    Belle River, ON
    Not a grinding, no. Just a solid clunk sound. I think it's metal-on-metal. Only seems to occur with the wheels turned, not necessairly at full-lock.
    I've experienced that problem before. The current sound is more solid, not the "clack" that the pads were making when they were sticking. I'm going to check the tightness of the caliper bolts though, just to remove them from the equation.
  12. Apr 2, 2011 at 9:09 AM
    bigmooze
    Richard
    Belle River, ON
    All four of my LCA bolts were loose! Tightened them up to 100 ft-lb and will drive it around to see if the problem has been solved.
  13. Apr 2, 2011 at 10:38 AM
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    i was going to suggest the spare tire loose? that one got me once and took forever to find it, hope you have it figured out.
    cheers
  14. Apr 2, 2011 at 11:44 AM
    bigmooze
    Richard
    Belle River, ON
    Thanks for the suggestion. The spare tire is definitely secure.
    Where abouts in ON are you?
  15. Apr 2, 2011 at 11:49 AM
    OZ-T
    Peter North
    British Columbia
    Did tightening your LCA bolts eliminate your noise ?
  16. Apr 2, 2011 at 11:51 AM
    bigmooze
    Richard
    Belle River, ON
    I drove for about an hour between various stores, backing up and bumping up into driveways. So far, so good. No noise when I reverse into the driveway either. Hoping that was the problem...
  17. Apr 2, 2011 at 11:53 AM
    OZ-T
    Peter North
    British Columbia
    That would be cool . I've read on here it is fairly common for the LCA bolts to be seized on , so I found it suprising that your were loose .
  18. Apr 2, 2011 at 11:57 AM
    bigmooze
    Richard
    Belle River, ON
    Yeah it would end the frustration of not knowing the source of the noise.
    No seizing which was nice, I only had an alignment done at 81,210 km (just passed 93,000 these week). The tech (not a dealership guy) likely didn't crank the bolts down to spec.
  19. Apr 3, 2011 at 8:47 AM
    elwood
    Neal
    ont, canada
    2007 SR5 4x4 LB
    just north of guelph area in a small town called Alma.
  20. Apr 10, 2011 at 6:14 AM
    bigmooze
    Richard
    Belle River, ON
    Well it's been a few days with mixed highway/parking lot/side treet driving and the knocking sound has not come back.
    So, I think tighteneing the loose LCA bolts worked like a charm.
    Thanks bayou_fennec (and others) for posting your suggestions.
