metallic tings coming from rear end :(
Discussion in '1st Gen. Tacomas (1995-2004)' started by Greensystemsgo, Nov 20, 2011.
  1. Nov 20, 2011 at 3:56 PM
    Greensystemsgo
    Greensystemsgo [OP] 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    sounds just like a flag pole how the rope hits the pole in the wind, its like a ting, i can only hear it while costing as otherwise the motors to loud, ive already changed both wheel bearings and wheel bearings less then 1000 miles ago. im afraid its my r/p or bearing in there, if it is r/p, what total cost am i looking at? :(
    any other possibilities/suggestions?
  2. Nov 20, 2011 at 4:34 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    Have you check u joints and center bearing support?
  3. Nov 20, 2011 at 5:51 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Derp I said wheel bearings twice. All wheel bearings have been changed less then 10k miles, and center carrier bearing less then 500 miles ago. Front ujoint on driveshaft has been changed, but not double cardigan or rear most. Ill check.
    But driving I almost wonder if its the front the sounds coming from :(
  4. Nov 20, 2011 at 5:55 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Maybe something with the rear diff? When is the last time you greased your shackle bushings?
  5. Nov 20, 2011 at 6:07 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Same thing happened to me. Have you done any wheeling lately and where you were noticeably hard on it? My noise got louder and more noticeable with daily driving over speed bumps and up hills etc... I put the axle on two jack stands and then put the truck in gear and put my hand on the pumpkin and could tell it was coming from in there. So i took it all apart and sure enough it was the R & P. Just ordered a new 3rd from ECGS last week. Something like 600 bucks.
  6. Nov 20, 2011 at 6:46 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    not a lot of wheeling, but yes wheeling. my front is missing pieces of teeth, the rear im not aware if it is or not. gawd 600 :(
    i tried to wiggle drive shaft and it has no wiggle, ill jack truck back up and see. man out of all the work ive done to the truck, its all been in the front, i guess now for the rear :(
  7. Nov 20, 2011 at 10:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/URD 2.2" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    A dry slip yoke will make that noise.
  8. Nov 21, 2011 at 8:28 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    hrm, the rear i do believe is good, the front i dont think has one, just ujoints?
    ugh.
  9. Nov 21, 2011 at 8:30 AM
    TacoMX
    Jonathan
    Deltona, Florida
    the front driveshaft does have a slip-yolk
  10. Nov 21, 2011 at 7:54 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I was thinking the rear one. That is the one that takes the most abuse unless you run in 4wd as many miles as on the street. Its easy to check. Pump some grease into it until you start to see the joint expand. If it is dry, that could be a lot of pumps.
  11. Nov 21, 2011 at 8:28 PM
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Dallas, Texas
    03 Prerunner (5VZ-FE)
    OME 2.5", 881, Dakar, Nitrochargers
    The only time I've heard that noise is when I let my girlfriend drive. She was backing out and switched from reverse to drive while the truck was still moving a bit:eek: Needless to say she was never allowed to drive it again! Hope that helps!
  12. Nov 21, 2011 at 8:29 PM
    TacoMX
    Jonathan
    Deltona, Florida
    man, thats grounds to PIITB...
    my girlfriend isn't allowed to drive my truck, because even after several lessons she still doesn't grasp how to use a clutch.
  13. Nov 21, 2011 at 8:35 PM
    MacGyvR
    Tom
    Dallas, Texas
    Wow, I'm impressed you even tried. I drive an automatic, so I figured she could handle it. Naturally moving forward and backward was too difficult for her to comprehend (we're not dating anymore, so it's okay to be bitter , lol).
  14. Nov 21, 2011 at 8:43 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    brakes?
  15. Nov 21, 2011 at 8:49 PM
    TacoMX
    Jonathan
    Deltona, Florida
    wow, I was under the impression that she goofed on a manual...wow, at least my chick can drive an automatic :laugh:
    maybe a good think you parted ways? ;)
  16. Nov 21, 2011 at 9:03 PM
    MacGyvR
    Tom
    Dallas, Texas
    hahaha, right? Strike one was doing that to the truck. Strikes two and three were sleeping with another guy. Shit happens though, and I'm over it.
    Anyway, sorry to thread jack. Just reading that description reminded me of the noise that made. I really hope your problem isn't related to that!
  17. Nov 22, 2011 at 6:08 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    well, after putting up with this for roughly a week now, its gotten worse, specifically after an off road trip, and i also now have a whistling. the whistling is at medium rpm, and gets a hari higher at 4k rpm, then dies off, and the rattling is super noticable when i shit and run at ~300rpm when vehicle shakes.
    father law and i went for a ride and figured it out at same moment. Exhaust/header. Ive also been getting an intermitant CEL, which comes back as the 87, with a possility of being a sensor on the cat. so imma tighten headers tomorrow, and weld the rest of it. ugh.
  18. Nov 22, 2011 at 6:53 PM
    TacoMX
    Jonathan
    Deltona, Florida
    exhaust leak from a cracked manifold will cause to you throw a CEL...maybe time for a new header??
    LCE!!
    Big bucks though because you are a V6
  19. Nov 22, 2011 at 7:17 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    dont know if its cracked, or if the exhaust is loose. I only have one hanger behind rear axle, so i suspect thats been bouncing around sense i bought it, as the trucks had its body lift removed, apparently right before i bought it in july.
    Luckily i have access to a stock header (maybe) for cheap (hopefully).
  20. Nov 24, 2011 at 11:50 AM
    Rebel Taco 22
    At least it isnt the rear end
