Metric gauge face
Discussion in 'Technical Chat' started by kbp68, Sep 30, 2008.
  1. Sep 30, 2008 at 8:51 PM
    kbp68
    kbp68 [OP] hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
    Anyone know where I can get a set of Metric guage faces(kilometers OUTSIDE, mph INSIDE)? Lots of aftermarket ones available but all in mph. Also, I have heard that the odometer can be re-programmed to read in km instead of mph. Is this true?
  2. Sep 30, 2008 at 8:52 PM
    bcmedic
    bcmedic Well-Known Member
    i too am looking for the same thing...i hear the dealership are the ones that doo it...but i have yet to confirm it.
  3. Oct 8, 2008 at 9:25 AM
    Scooter
    Scooter Canadian Member
    Manitoba, Canada
    08 Double Cab TRD Sport Short Box
    Pop n Lock Power Tailgate Lock, Bak Flip Tonneau Cover, Factory DLR installed, Defrost with A/C Off, EZ Down Tailgate Damper, Code Alarm Security System with Remote Starter, Rear Spring TSB, Ming rust proofing & paint treatment, 3M fabric protector, Cargo Mat, Scanguage II, DYI Illuminated 4X4 Switch, Versa-Gate box extender & cargo divider, Toyota Roof Rails, Grom USB Audio adapter with bluetooth, LED Bed lights, OEM Backup Camera with LCD Display Mirror
    I'm also interested in a metric faceplate for the speedometer.
  4. Oct 8, 2008 at 9:29 AM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    Yours still has KMPH on the bottom, correct?
  5. Oct 8, 2008 at 1:52 PM
    bcmedic
    ^right now yes, mph outside kph inside
  6. Oct 8, 2008 at 2:11 PM
    SLOTaco
    SLOTaco Ultimate Member
    Central Coast, California
    06 TRD Sport
    '06 TRD Sport 4x4 AC, K&N drop in air filter, Magnaflow cat back, Bilstein 5100's with Toytec adjustable front coil over 3" lift, rear TSB, AllPro UCA's.
    look into seeing if the HILUX guages are the same size/style as the tacoma's if so I'm sure they are in KMh
  7. Oct 8, 2008 at 6:49 PM
    bcmedic
    well we could easily get the oem tacoma gauges from a canadian dealership, but its very expensive
  8. Oct 8, 2008 at 7:26 PM
    kbp68
    B.C.
    TRD Off Road DC/SB
    I priced them today at the local dealership. Close to $600 as they say you can't buy just the face, you have to buy the whole gauge cluster. I haven't had my dash apart yet to call BS on that one. I know in my old GM the faces just sat on the gauge and came off when you pulled the needle. Any one know a wrecking yard that specializes in late model Tacos?(In Canada?):canada::canada::canada:
  9. Oct 9, 2008 at 11:15 AM
    Scooter
    Manitoba, Canada
  10. Oct 9, 2008 at 6:18 PM
    kbp68
    B.C.
    TRD Off Road DC/SB
    thanx. Still looking for a CANADIAN wreck to pilfer:canada:
