Michelin Defender 245/75R16
Discussion in '3rd Gen. Tacomas (2016-2023)' started by darkgohan, Oct 27, 2016.
  1. Oct 27, 2016 at 7:53 PM
    darkgohan
    darkgohan [OP] Well-Known Member
    Will these tires be alright on my 2017 Tacoma 4x4 Accesscab.New truck,and want to trade off Firestone defender LE2s for Michelin. They are p rated,that is why I ask. Got to make a decision before I recieve my truck in the morning I do not leave the pavement except a few logging roads
  2. Oct 27, 2016 at 7:55 PM
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    Do you intend to do any more off-roading??
    P rated tire will have less tread depth and will be less stout of a tire.
  3. Oct 27, 2016 at 8:13 PM
    darkgohan
    I do not off road,but do drive gravel roads. Are there better Michelin than this? I have not looked,simply want a good Mich. in the snow,and mostly pavement. All I see is Michelin Defender 245/75R16 111T
  4. Oct 27, 2016 at 8:15 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    Don't really know about Michelin. Have never had them personally.
    If you do mostly driving on road and just minor gravel, an AT is for you of some sort.
    I've have the wildpeak at3 and love them so far... only about 1k on them tho so still have experience to gain.
    Michelin is a solid tire maker... that much I do know.
  5. Oct 27, 2016 at 8:31 PM
    AdventureKid
    AdventureKid Let's Go Places
    Jake
    Oceanside, CA
    17' DCSB TRD OR 4x4 6MT
    Camper Shell
    If I were you, I'd go with the Michelin LTX AT/2. They were great tires for me. I had them with the Load E rating. My last set lasted me 90,000 miles.
    The Michelin LTX MS/2 will get a smidge better rolling resistance on the road, but the AT/2 makes up for its rolling resistance in its looks and it's offroad performance.
    theredofshaw likes this.
  6. Oct 28, 2016 at 6:09 AM
    Cnd-GB
    Cnd-GB Well-Known Member
    2016 Nissan Frontier King Cab Pro-4X 6sp
    I have a '16 SR5 AC V6 4x4 and have the Michelin Defender LTX M/S in 245/75-16 LT on my truck. Load rating is 120 for 3042 lbs of carrying capacity which is about 600lbs more than the P rated one. This tire basically replaced the LTX M/S2 tire not sure if you are familiar with it, pretty much the same tread pattern but it is suppose to have longer wear. I don't do any serious off road other than gravel roads and some unmaintained roads that could be considered trails. So far no problems in mud or slick conditions, plus I don't care how my tires look to me it is more important how they perform for the conditions I drive in. The LT does come in limited quantities each year so not sure what the availability is now. I have always found the Michelin tires to perform well on all the vehicles I have put them on. A coworker has the P rated version on his Canyon and loves them, I have driven his truck and not a huge difference other than my feel stiffer when going over bumps and cornering. I don't think you would be disappointed if you get them.
  7. Oct 28, 2016 at 6:19 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    I drive a lot of highway and gravel, and Michelins work well for both of them. There's a reason they are considered a/the top tire manufacturer. You won't be dissapointed.
    PROseur, Mush Mouse and AdventureKid like this.
  8. Oct 28, 2016 at 8:28 AM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Gave up on the Coopers huh? Michelin Defender is a great choice for an all-year tire and are unbeatable on pavement, wet or dry. The Michelin AT2 don't perform as well in winter.
    If you go from the 245/75r16 to a 265/75r16 they will be an inch taller overall and look much better on the truck. This will effectively get you 1/2" of lift as well for a little extra ground clearance. Most people bump up to this size.
  9. Oct 28, 2016 at 9:37 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    +1 on the Michelin LTX M/S. Great tires.
    Mush Mouse likes this.
  10. Oct 30, 2016 at 9:40 AM
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    LTX M/S is what the OP should get based on his needs. LTX A/T will be louder and wear quicker. LTX M/S will handle logging roads just fine
    Love mine... 245/75/16 Defender LTX M/S
    JoeManji and timothom like this.
  11. Oct 30, 2016 at 12:32 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Can't beat the Michelins .... As soon as I can wear out those Firestones.. It's Mich all the way.. I've already got Mich X-Ice on for the winter...
    Best ride of ANY tire...
  12. Oct 30, 2016 at 12:40 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    if you truck is a 4 cylinder 2.7l I would stick with the P metric 245/75/16 Michelin ms2 because the little engine looses power the more tire or other weight is put on the truck, the stock Dunflops are 32 pounds each and my truck barely pushes these :eek: so running a heavier larger tire would no be good for me to loose more performance
  13. Oct 30, 2016 at 12:42 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Is it ok to switch 265 and 245 on the same wheels, width wise?
  14. Oct 30, 2016 at 12:43 PM
    PROseur
    Pussy
    Yeah my 2.7L has the 225 on them.
  15. Oct 30, 2016 at 12:46 PM
    over60
    Muskoka, Ontario
    I've heard that the little 4 cyl. motors work best with Motorcycle tires... Why.... less drag...!
    I've got a set on Bridgestones for my Goldwing that I'm willing to let you have... New and "in the box"..!! Worth a try..??
  16. Oct 30, 2016 at 1:17 PM
    Mush Mouse
    mush
    2013 SR5
    PROseur[QUOTED] likes this.
  17. Oct 30, 2016 at 1:17 PM
    Mush Mouse
    mush
    2013 SR5
    no:santa:
  18. Oct 30, 2016 at 1:22 PM
    over60
    Muskoka, Ontario
    Damn... I'm just gonna have to wear them out on my next trip to Texas/Cali/Az and then BC/Yukon...!!
  19. Oct 30, 2016 at 1:25 PM
    Mush Mouse
    mush
    2013 SR5
    [​IMG] :cheers:
  20. Oct 30, 2016 at 1:30 PM
    over60
    Muskoka, Ontario
    I promise... I will not drive over your lawn.. hehe
