Microfiber Towel Trials & Tribulations - What Has Worked So Far
Discussion in 'Detailing' started by TacoYes, Jun 3, 2016.
  1. Jun 3, 2016 at 8:19 PM
    TacoYes
    TacoYes [OP] Well-Known Member
    2011 Silver 2.5 Door
    Black Wheels, Grill, Running Boards
    I will just start out by saying the Chinchilla is top notch and should be in your arsenal... This is the go to for now.
    The Chinchilla's 600gsm are more plush and soft than higher gsm towels. When using a detail spray, a single pass with the towel will removed the detail spray, no streaks, no moisture. This is crucial because the fewer amount of passes across the paint reduces the chances of putting swirls. You also preserve the wax/sealant you applied, causing it last longer... These are the reasons I have been motivated to write this. Before educating myself I am pretty sure I am responsible for putting swirl/spiderwebs in the surface of the paint.
    Chinchilla's can be purchased from many different sources. In the post below this one I will update websites where I find a good deal at. I have removed links to any company in this initial post to keep it focused. It may be necessary to put the company purchased from so you can track them down... To find good deals look below...
    I just recieved 700gsm Extra Fluffy Microfiber Waterless Wash Cloth towels on Microfibertech. They are very nice but not as a nice of a feel and not as soft as the Chinchilla. The pile is also a little bit longer which is nice. Both have the same texture on both sides (Duo Pile). Anyone newer to this you need to pay attention to the way they are made. Some towels have the same pile/texture on both sides other have two different pile lengths for different jobs.
    It must be said the purpose for this towel is for after the car has been washed and you apply a detailer spray (so many choices with this it will make your head spin). This towel can also be used for drying if you like. Also, this is the towel that will get the most use besides your drying towel, which again could be this one. I purchased enough to be able to create a large enough load to wash, great excuse, I know...
    Other MFT purchased
    Autofiber Elite Plush Microfiber Detailing Towels 16''x16'' 530 gsm. From Microfibertech. Many other companies have this same towel. I like these as many people have mentioned. These are perfect for removing wax or sealant. The side with the shorter pile is best for the initial removal of the wax/sealant. The other side is best for going back over and doing a final wipe (extra courtesy wipe never hurt) to remove any lingering dingle wax berry's:puke:. Using these to specifically remove wax and sealant means you don't need that many. You should only need to apply a sealant 2-3 times a year. If you good about washing the towels, 6 of these would probably do you right. If you only get around to it once a year maybe 12 towels would be good.
    I also purchased;
    Super Plush XL Microfiber Towel, 25 x 36 inches.
    This towel is comparable to the 530gsm, with maybe a slight edge to the 530 elite plush. I have to say I am not impressed espectially for the price. I had higher hopes for this towel I wanted it for drying but realized it has two different sides, this is where I learned to check every towel before you buy to make sure what exactly it is. Some towels are the same on both sides, others have a short and long pile.
    I purchased some towels for the glass. I will be using towels first to remove the surface residue. Then going back with the microfiber to do a final cleaning... more to come.
    I use two mitts for washing. One for the main part of the truck and the second for the tires/wheels.
    Black microfiber towels also for cleaning the tires and wheels.
    I will be updating this soon after I get a couple more and use a few others I have received. No haters because there isn't a lot of information, just getting this started folks...
    Basically what I would recommend is buying;
    12-24 - Chinchilla's - Drying, Detail Spray
    6-12 - Autofiber Elite Plush Microfiber - Wax/Sealant Removal
    2-4 Glass Towels...
    1-2 Wash mitts - Cleaning Vehicle - Tires
    2-4 Black Towels For The Tires & Wheels
    As you use your towels and get scrubby ones you can use these for the doorjambs and crevasses.
    There are others here who know much more than I do, this is just one persons experience.
  2. Jun 3, 2016 at 8:22 PM
    TacoYes
    To get the good deal on the the Chinchillas;
    Will update soon...
    I still highly recommend the 3 for $17 on eBay. I feel they are the best ones I have purchased even when compared to other Chinchillas from these other sites.
    Other companies you can find these at are;
    The Rag Company
    Autogeek - Wolfgang Car Care
    Autotopia
    Groits Garage
    Chemical Guys
    eBay - 3 Chinchilla's for $17 Free Shipping
    Amazon
    I know there are more and will add to the list, just a quick reference for those just starting out the search...
  3. Jun 3, 2016 at 8:23 PM
    Yamaha_TacoR1
    Yamaha_TacoR1 Very slow racer
    NJ/NY, USA
    2015 Black TRD Sport 4x4 Limo
    - 5100/885's, 5100/Icon 3leaf progressive AAL with overload left in, 1/4" Taco lean spacer - ARE Z Series camper shell with Yakima rack system - Tepui Ayer Rooftop Tent - Prinsu Design Cabrac with heavy duty anadized bars - WeatherTech window deflectors/floor liners/bug deflector - Ultragauge MX1.3 - PopnLock codable locking tailgate handle - TRD shift knob - 3M tint - Extang solid fold2.0 tonneu cover - OEM Tacoma muffler tip - OEM Tacoma side steps - OEM Tacoma bed mat - OEM Tacoma roof rack - OEM TRD PRO front grille in matte black - OEM TRD PRO headlights - Fastway FLASH "Solid-Tow" adjustable aluminum ball mount hitch - Reese dual hitch ball covers - Masterlock locking J pin - GoPro windshield mount - Door trim protectors - Side mirror 'fish eyes' - Thule T2 hitch mount 2 bike carrier - LEDs: Map/Dome, 3rd brake, license plate, parking lights, reverse CREE's - SEMA TRD PRO 17" black matte wheels - 265/70/17 BFG A/T KO2s - Black Widow 40" x 95" 3 piece powder-coated folding bed ramp - Mobtown Offroad ribbed tailgate reinforcement skin - GRIDiT center console organizer - Salex center console organizer - Marco Extreme Blast black premium train air horn - 'ImmrYo' Rearview mirror relocate bracket - Mattgecko's Sliding window security bar - Rigid tow rear hitch shackle - Plasti-dipped gunmetal emblems - Blacked out ACEkraut's front license plate relocate bracket - De-flapped (OEM mud flaps gone) - Uniden XL520 CB Radio - Shmellmopwho's CB antenna bed mount - 3ft Firestik II CB antenna - BirdDawg Industries Tech Deck Extreme version w/ 3 Ram 1" ball mounts - Ram Mounts: iPhone6/iPad Mini4 X Grips with 1" dual ball sockets - Garmin GLO portable GPS & GLONASS receiver - Depo LED tail lights with blacked-out inner housing - Various Velcro backed patches on the headliner - 3D-Cell LED Maglite mounted to the driver seat - 4XInnovation DOM weld on sliders with kickouts (welded at 20degree angle) - 4XInnovation Hi Lift bed mounting system - Hi Lift All cast 60" jack with optional handle holder - Lotus Development Hi Lift slider adapter - Relentless Fabrifacfions dual bed rail mounts with dual Quick Fists - Salex glovebox organizer system - YETI vintage bottle opener mounted to the bed - TRD Sport style aftermarket epoxy resin decals for WT front mats - Rigid Industries LED D2 spot lights (Midnight edition) - CBI spot light hood mounts - Air on Board "Zombie Lights" switch - Rebadged WeatherTech floor liners with custom TRD Sport emblems - GoPro Hero 3+ windshield mounted - Mattgecko's cool white LED bedlight kit v2 - 1.25" Spidertrax wheel spacers - Maxsa Escaper Buddy traction boards (mounted on top of Prinsu Cabrac) - 42" Plano Weatherproof gun case (mounted on top of Prinsu Cabrac) - 2gal Rotopax gasoline can, mounting plate, DLX pack mount (mounted on top of Prinsu Cabrac) - Bestek 150W power inverter DC 12V to 110 V - DBPower 600A car jump starter/booster - SOS Off-road Concepts Factory recovery replacement mount - ARB 30' Recovery strap - ARB EZDeflator - Smittybilt receiver hitch D ring with 3/3" shackle - Bosch Icon wiper blades - RCI IFS steel skid plate - Trasharoo trash bag - mounted on tailgate - Lamin X yellow fog lamp covers - Aftermarket illuminated air conditioning/heater/vent knobs - Toyota full frame replacement - Spring 2023 ================================ Future mods: - Rear diff breather relocate - Foglights anytime - Install external speaker for CB - Install mattgecko bedlight kit
    Do you work for them? You pushing these towels real hard....
    ElBlancoTaco and CusterFan like this.
  4. Jun 3, 2016 at 8:26 PM
    TacoYes
    I do not work for any of these companies. I work in the flooring industry, nothing to do with cars. You can buy the Chinchillas from many different companies. Just wanted to pass on where I found the best sale at the moment and what I found worked the best for me...
    I am recommending two different towels from two different companies...
    ElBlancoTaco and Yamaha_TacoR1 like this.
  5. Jun 3, 2016 at 8:33 PM
    Yamaha_TacoR1
    NJ/NY, USA
    In that case thank you sir for sharing your feedback
    moe2o4 and TacoYes[OP] like this.
  6. Jun 4, 2016 at 2:59 PM
    TacoYes
    You can get 3 Chinchillas for $17, free shipping... Copy and paste the following to find the ones I am talking about;
    3-pack Chinchilla Professional Microfiber Detailing Towels 16 x 16 | 600 GSM
    Greenbean and CusterFan[QUOTED] like this.
  7. Jun 4, 2016 at 3:41 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Thanks man.
  8. Jun 4, 2016 at 3:50 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Check out the Rag Company Creature Edgeless on Amazon. 10 for $17. Also a great towel.
    CusterFan[QUOTED] likes this.
  9. Jun 4, 2016 at 5:03 PM
    CusterFan
  10. Jun 4, 2016 at 5:26 PM
    NMTrailRider
    New Mexico
  11. Jun 4, 2016 at 9:24 PM
    TacoYes
    You will be happier with 3 of these very nice towels rather than 6 of the others, try it and you will not be disappointed. I have ordered many different towels and wish I had just bought the Chinchilla's. Do it... do it... do it...
    The towels you already bought will be good for removing wax/sealant.
    If you have a brand new 2016, Black. I would highly recommend buying a couple nice towels so you don't get swirl marks... Also use a dedicated wash mitt with a two bucket washing system with Grit Guards in the bottom of the buckets. Plus a Grit Guard Washboard in the rinse bucket. One bucket with the wash solution and the second bucket for rinsing the wash mitt.:bucket::bucket:
    InfernoTonka and ace96 like this.
  12. Jun 4, 2016 at 9:26 PM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    Costco.
    :anonymous:
    SOSHeloPilot and moe2o4 like this.
  13. Jun 9, 2016 at 4:51 PM
    CusterFan
    You talked me into it. Just popped on the $17.00 deal on ebay. Probably retire my XL Absorber to shower wipe down duty!
    Thanks..
    ace96 likes this.
  14. Jun 13, 2016 at 11:32 AM
    CusterFan
    Hey got the Chinchillas in the mail today. These are freaking nice.
  15. Jun 13, 2016 at 11:39 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    +1 on that, You can get a huge bag (I think 32 to 36) of microfibers at Costco for cheap!
  16. Jun 20, 2016 at 11:42 AM
    CusterFan
    If you ever held a Chinchilla microfiber towel in your hand you would not buy Costco towels. Used mine this morning and nothing compares to them. Reminds me of petting a long haired cats back but softer.
    InfernoTonka likes this.
  17. Jun 20, 2016 at 1:24 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Let the swirl party begin!!! Lol.
    TacoYes[OP] likes this.
  18. Jun 20, 2016 at 1:29 PM
    moe2o4
    Corey
    Pittsburgh PA
    Never had a problem with them ever!
  19. Jun 22, 2016 at 5:05 AM
    ace96
    Western KY
    Let's see some direct sunlight pics of paint. :thumbsup:
  20. Jun 22, 2016 at 5:08 AM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... Ditto. Thought all micro fibers were basically the same too :confused:
    PS... COSTCO microfiber towels make great washcloths too. :)
