Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Jul 28, 2016 at 6:18 PM
    #3321
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I'll report back in the spring (after a new England winter) if the uni-ball I hosed down with brake cleaner is worse than the other.
    Adventurer_Alex likes this.
  2. Jul 28, 2016 at 7:14 PM
    #3322
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member Vendor
    Jon
    Gilbert, AZ
    I don't know about you but i love the smell of simple green.
    Home depot had a sale of the gallon plus an empty spray bottle a few months ago. Use that shit all over my house!
    jberry813[QUOTED] likes this.
  3. Jul 28, 2016 at 7:26 PM
    #3323
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    You might have a problem that requires some professional help. :D
  4. Jul 28, 2016 at 7:36 PM
    #3324
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Gallon at a time. Works great as mouthwash too :anonymous:
    Gramps likes this.
  5. Jul 28, 2016 at 7:48 PM
    #3325
    2ndGenJonny
    Jon
    Gilbert, AZ
    I also like the smell of race gas out of an exhaust.
    Arcticelf likes this.
  6. Jul 28, 2016 at 8:09 PM
    #3326
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Simple green is great, been using it since 2004 brah!
  7. Jul 28, 2016 at 8:15 PM
    #3327
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
  8. Jul 28, 2016 at 8:30 PM
    #3328
    YotaLife
    YotaLife Well-Known Member
    Cory
    Seattle
    11 DCLB Sport
    King 2.5 w 700lb coils, bamf rear mount and sliders, alcan rear springs, 12 inch king smoothies, allpro front bumper, allpro uca, 34x10.50 bfg at ko2, total chaos gussets
    Hi all,
    So I'll be installing a lift here in a few weeks and just wondering if anybody thinks I'm missing/forgot anything. All of it is either in a pile at my house, in the mail, or still being built.
    Front:
    Extended travel King 2.5 remote reservoir w/ adjuster 700lb coils
    All pro UCA
    TC coil bucket gussets
    TC cam tab gussets
    TC spindle gussets w/ swaybar mounts
    Wheeler super bumps
    Rear:
    Alcan 3in plus 225lbs and 1/2 in longer on shackle end
    Archive shackle flip
    King 2.0 remote reservoir w/ adjuster
    allpro flip
    BAMF shock relocate
    wheelers super bumps
    extended brake lines front and rear
    I'm running 34x10.50 bfg at ko2 and method double standards w 4.25 backspacking.
    So, think I'll need wheel spacers in the rear or should be good?
    Do I need a carrier bearing drop?
    anything else? I don't have a CMC yet but I might after this we'll see
    thanks
  9. Jul 28, 2016 at 8:41 PM
    #3329
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    You are going to have some very serious front end low rake. The truck stock sits 2"+ lower in the front and since your front end will only have around 2.5" bit you are going a shackle flip which gives lift, a long shackle which gives lift, a 3" lifted leaf pack with extra weight capacity it seems like you are going to end up with 5" of lift in the rear and only 2.5" in the front which means your going to end up looking like a severely raked hot wheel.
    @2ndGenJonny ran into some unexpected major rake due to similiar circumstances so maybe he can add on here too.
    @2ndGenJonny ...it just took me 5 minutes to figure out your current screen name so I could tag you ...bastard
  10. Jul 28, 2016 at 8:48 PM
    #3330
    YotaLife
    Cory
    Seattle
    11 DCLB Sport
    I've been worried about this too...especially since I still have the stock rear bumper. But I figured with a full size spare, 140 lb bumper (when I get it), and some gear in the bed itll be about stock rake....I hope anyway
    Maybe Ill weld the shackle hanger a bit forward and make sure my shackle is 35ish degrees
  11. Jul 29, 2016 at 3:42 AM
    #3331
    Arcticelf
    Gladiator
    You may as well CMC while you're in there welding.
    I'd plan on either a carrier bearing drop, and/or shims to change the axle angle. You'll have to put it all together, measure and see what's needed.
  12. Jul 29, 2016 at 4:51 AM
    #3332
    2ndGenJonny
    Jon
    Gilbert, AZ
    1st off, thats quite a list of work! But one hell of an upgrade! You doing the install or have a shop doing it?
    BFG 34x10.50r17 = 33.5 dia, so yes youre going to need a CMC so go ahead and chop that fucker right away cause its going to rub. Most likely a little bit of plastic as well as the pinch weld
    #StankBugLyfe
    Take my trucks like my woman...
    Face down ass up!
    Probably going to have a little vibs at launch but mine settled once I moved the shackles fwd a hole and added the weight of my rack and bumper.
    Id say hold off at 1st and see what happens when you get it all settled.
    Worst case, you can drop the carrier .5 to 1" if needed but i have a feeling once that bitch settles with all that weight, youll be ok.
    A lot to answer and I probably missed some shit. Ill read more again when i get to work and answer some more. Or just hit me up in my build or PM and we can talk about how much preload you will probably need.
  13. Jul 29, 2016 at 7:04 AM
    #3333
    Gramps
    Gramps
    07 TRD DC 4x4
    ^^he pretty much got you covered. I am running similar Alcan and an extended length shackle. With the weight in the bed now - bed rack with accessories, spare, RTT, and "real" rear bumper it pulled me down to about 4" of lift. I have about 3/4" to 1" of rake on a normal day but when I am fully loaded for camping I sit level.
  14. Jul 29, 2016 at 9:37 AM
    #3334
    YotaLife
    Cory
    Seattle
    11 DCLB Sport
    Shit now you got me worried...I just called alcan and dropped it to 2 inch lift, +200lb and 1/2 longer on shackle end...worst case scenario I'll have like 8 inch shackles to make up the difference lol
  15. Jul 29, 2016 at 9:39 AM
    #3335
    Gramps
    Gramps
    07 TRD DC 4x4
    That should be better. I like my Alcans. He arches the drivers side to help with taco lean. They have been great so far.
  16. Jul 29, 2016 at 9:40 AM
    #3336
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    A lot of people make the same mistake because they forget how severe the front rake is OE. A simple rule of thumb is that roughly :
    2" lift in the front only = level
    3" front / 1" rear = level
    4" front / 2" rear = level
    Etc etc...
  17. Jul 29, 2016 at 9:53 AM
    #3337
    2ndGenJonny
    Jon
    Gilbert, AZ
    So you are rear 2" with a 4 or 5" shackle?
  18. Jul 29, 2016 at 10:07 AM
    #3338
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    I'd set up your bamf shock relocate kit for 2.5 shocks. It'll be far easier to do prior to being installed on the truck. 2.5 is really the shock you want to be running on our trucks
    Gramps likes this.
  19. Jul 29, 2016 at 10:12 AM
    #3339
    2ndGenJonny
    Jon
    Gilbert, AZ
    2.0s work just fine in the rear though..
    he can just leave the cap off the top piece just in case he jumps to 2.5. I did just so I can get a hose in for cleaning.
    Silver02Taco likes this.
  20. Jul 29, 2016 at 10:15 AM
    #3340
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    my rear 2.0s suck so much. Planning on doing a shock relocate on either 10" bypasses or a replacement 2.5 King, unsure which way i want to go.
