Mid Travel BS 2.0
Discussion in 'Suspension' started by 2ndGenJonny, Jan 12, 2016.
  1. Jun 5, 2017 at 7:41 AM
    #4821
    jc11taco89
    jc11taco89 Well-Known Member
    jon
    Naugatuck CT
    2011 Tacoma aclb 4wd
    3 inch toytec 5100 SPC uca's Pelfreybilt front plate bumper with center hoop Pelfreybilt rear plate bumper with swing out B.A.M.F. sliders with kick out Mobtown ifs and trans skid. 33's with rims that are to large.
    Hahaha not quite sure what that means. ... acronyms
  2. Jun 5, 2017 at 7:41 AM
    #4822
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    I'm going to try to swing by my shock guy and get his opinion. That's the first thing I asked him, I also asked him if it's possible that the spring isn't seated correctly (which could be providing more lift.)
  3. Jun 5, 2017 at 10:55 AM
    #4823
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    For Fuck's Sake
    as in: for fucks sake, how does a shop screw that up?
    jc11taco89[QUOTED] and NABeast like this.
  4. Jun 5, 2017 at 11:16 AM
    #4824
    jc11taco89
    jon
    Naugatuck CT
    Hahaha yupp that's what I thought it meant. Ya I was pissed to say the least not cause they made a mistake but they totally denied they did anything incorrectly.
    Arcticelf[QUOTED] likes this.
  5. Jun 5, 2017 at 11:52 AM
    #4825
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Post a pic of it at ride height so we can see the UCA and the CO clearly...those two things should be nowhere near each other at ride height that should only happen at full droop...
    Arcticelf likes this.
  6. Jun 5, 2017 at 12:03 PM
    #4826
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    Will do. Thanks for everyone's help. You'll see that I have them preloaded, and the comparison between the driver and passenger springs.
    On a side note, would a bent spindle cause a similar issue?
  7. Jun 5, 2017 at 1:52 PM
    #4827
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    in theory yes but it would be severely bent
  8. Jun 5, 2017 at 5:30 PM
    #4828
    Arcticelf
    Gladiator
    certainly enough that you could tell with a straight edge and comparing the two sides.
    if this is happening at ride height, something is _way_ out of whack between the two sides.
  9. Jun 5, 2017 at 5:55 PM
    #4829
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    I looked after work and it may be due to the preload on the coilovers. The passenger is closer than I thought, so I'm looking in to adjusting the heims and getting it aligned.
    I'll also be adjusting the coilovers back 1 full turn.
  10. Jun 5, 2017 at 6:00 PM
    #4830
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    1 full turn is only 1/4" of difference max...
    If you are preloaded that close to the spring you are insanely too high and it will never align...and you have nearly zero down travel which is really bad for off-road traction. Do you understand that you can't lift these trucks more than 2.5" -3" max with stock length arms ?
    Post a pic so we can see what's the haps
  11. Jun 5, 2017 at 10:18 PM
    #4831
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    Need more deets
  12. Jun 6, 2017 at 8:13 AM
    #4832
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Should have gotten Kings. Both sides mount to the front. :)
    Glueman likes this.
  13. Jun 6, 2017 at 9:16 AM
    #4833
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Good to know. I have some rust on mine mostly due to rubbing
  14. Jun 10, 2017 at 9:05 AM
    #4834
    jc11taco89
    jon
    Naugatuck CT
    Hey fellers so I have yet another? ? So I'm planning on ordering dakars a d the @ARCHIVE shackle flip bumpstops ext brake lines and u-bolt flip. Now I plan on getting 12" travel king's/icons and the @b.a.m.f shock relocation kit. Unfortunately I don't have the finances to do it all at once my ?? Is doing it in 2 parts is not having the 12" travel shock going to limit the travel of the shackle flip? Currently im running 5100's at all corners. Please any help or info is greatly appreciated
  15. Jun 10, 2017 at 10:35 AM
    #4835
    Arcticelf
    Gladiator
    Not having the correct shock will very much limit travel. The solution is to buy as you can, build up a pile of parts, and install all at once.
    LTDSC and stairgod like this.
  16. Jun 10, 2017 at 11:07 AM
    #4836
    Moogle
    Moogle Dyslexic Stanist
    Glen
    Alameda, CA
    07 Silver TRD Sport DCSB 4x4 6-speed
    Blood of virgins
    Maybe just get the dakars with some b110's then save up for the shackle flip and 12" shocks.
  17. Jun 10, 2017 at 11:18 AM
    #4837
    Arcticelf
    Gladiator
    True, yo could do just Dakars with the current shocks, and install the rest when you get it together
  18. Jun 10, 2017 at 6:43 PM
    #4838
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    I agree with the responses so far, the B110's will limit droop with the Archive shackle flip, partly just because you're getting more lift. But they are probably one of the best easy and affordable shocks for droop. Have you seen the forthcoming Archive relocation yet? Fits 2.5" Fox/King up to 14" travel.
    http://archivegarage.com/products/taco-shock-relocation
    Bringing mid travel to everyone
  19. Jun 11, 2017 at 7:01 AM
    #4839
    Boomkanani
    Goldsboro, NC
    Some stuffz
    Couple questions...is there a thread for this relocation? What kind of springs did you use to test out this relocation? Also, do you know the approximate ride height to get close to even uptravel/downtravel numbers with 14" shocks?
  20. Jun 11, 2017 at 10:04 AM
    #4840
    ARCHIVE
    Eric
    No dedicated thread yet, just been sharing updates in the shackle flip thread
    https://www.tacomaworld.com/threads...-premium-shackle-flip-lift-kit.403630/page-49
    I haven't had my Tacoma long, and it's a good way to test bump travel, so still on stock springs currently and stock hangers. I'll be installing the shackle flip next week which will help get the droop travel, and I have Deaver SUA springs U539/540 on order.
    I wanted to know what stock feels like before switching springs so I can speak from experience with customers.
    About 2" lift will allow you to set axle mount for even 7" uptravel/ 7"down travel. At stock ride height, I have 4.5" of shock shaft before the 3/4" tall shock bump touches to shock body.
    IronPeak and Boomkanani[QUOTED] like this.
