Mid-travel spring under kit?
Discussion in 'Camburg' started by deuceb, Jun 20, 2018.
  1. Jun 20, 2018 at 1:22 PM
    deuceb
    deuceb [OP] Well-Known Member
    Denver | Austin
    2018 Taco BBPDCLBTRDOR | 2006 Jeep LJ | 86 VW GTI
    Hi I'm looking to get the CAMBURG TOYOTA TACOMA PRE/4WD 05-18 KINETIK SERIES 2.5 FOX DSC KIT after reading about how you did in the race, but the site says you use a modified L/T spring under kit to go along with it. I don't see that setup on the website. Do you make/sell it? Thanks!
    ChadsPride likes this.
  2. Aug 10, 2018 at 12:21 PM
    motoxscott
    motoxscott Well-Known Member Vendor
    Scott
    Socal -> Hurricane, UT
    2017 Tundra - 2008 Tacoma
    Camburg, FOX, Method, General Tire, Deaver
    Sorry ... haven't been on here in a while and just read this. On the Mint 400 Tacoma because of the rules of the class the truck raced in, we had to mix and match a few parts. We used the rear shackle and hanger from our spring-under kit with a custom spring from Deaver and used the factory front hanger. If you're gonna go through all that, you might as well just do the full spring-under kit since you're doing 85% of the kit anyways.
    Scott @ Camburg
