Mid Travel suspension advice needed!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rider11, Mar 29, 2011.
  1. Mar 29, 2011 at 7:01 PM
    Rider11
    Rider11 [OP] Active Member
    Hope, Arkansas
    06 Dbl cab 4x4 4.0 manual
    33x12.50 Nitto Mud Grapplers- 18in Helo's
    I just bought a 06 dbl cab 6 speed, the truck came with fairly new 33x12.50 grapplers with 60,000mi,(bought from dealership so I wasnt able to talk to prev owner) Looks like a spacer kit was used in the front to clear the tires (which still rub a little) and I cant tell if any lift or leafs added in the rear it looks OE, just the shocks are the only thing aftermarket ( white w/red boots)
    It just doesn't look right and the rear end has almost no travel and rides like a dump truck, which the tires cause some of it.... it is really rough on gravel road. So I want to put a mid-travel suspension in, what are some good options on coilovers and rear setup? Will I have to change upper and lower control arms? Any advice is much appreciated I just want a smooth controlled ride over semi-rough terrain.
  2. Mar 29, 2011 at 7:14 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I think you may have a AAL in the rear, by what you discribe.
    I just got the Ext. Travel Icons, and there amazing! great set-up. And dont forget some TC UCA's... As for the rear you will be good with either a 3 leaf progressive AAL.... Or a new leaf pack like OME or Dakars. Paired with some good shocks like 5125's or the new 2.5 Icon's.... But really it all depends on your budget, (if theres one) :)
    Also, those tires will rub quite a bit with only a 3" lift....
    You may even have to do the Cab Mount chop....
  3. Mar 29, 2011 at 8:01 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    My dream midtravel build would be extended travel icons dakars tc ucas and 5150s in the rear. Misc. Things you may want to keep in mind... Rear brake proportioning valve, carrier bearing drop if needed and for 1st gens a diff drop
  4. Mar 29, 2011 at 8:16 PM
    malander
    max
    01 limited trd 4x4
    Ah maybe on my next truck or when I have the 10 grand worth of other mods done one this one :(
  5. Mar 29, 2011 at 10:55 PM
    Rider11
    Hope, Arkansas
    So to get most out of mid travel def replace UCA and LCA, what does tc and AAL stand for? I dont have much of a budget yet, will probaly have to do in phases want to do as much homework as possible to do it right the first time. So the rear needs new leaf pack and shocks- Front replace UCA and LCA and ext travel coil overs> What are some budget friendly ideas?
  6. Mar 29, 2011 at 11:00 PM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    More like this instead! :D
  7. Mar 29, 2011 at 11:23 PM
    06rubi
    Kenney
    Pueblo West, CO
    TC=Total Chaos. aal=add a leaf. Mid travel only needs UCA not LCA. As far as I know all after market LCA's are for long travel. To do it on a budget is possible, but you get what you pay for. You can piece it together one part at a time to soften the blow on your wallet. Also look at the for sale section, good deals can be found for the patient.
  8. Mar 29, 2011 at 11:37 PM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    Total chaos sells a stock width lca that is boxed and has a uniball, really beefy!
  9. Mar 29, 2011 at 11:46 PM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    To get rid of the dump truck ride in the rear your gonna have to change your shock. When i did the rear Add A leaf, my shocks were to short and had no up travel so every time the decompressed it basically hit its max length and would hop really bad. I went with Bilstein 5125's and it made the ride much much smoother, as for the front... If you want to spend a pretty penny go with a Coilover setup, I went with Icon Ext. travel and they ride 100x's better than my spacer lift.
    I think to be truely Mid-travel you have to change out the LCA but if your just wanting to improve the ride you dont have to. That LCA is like 1500 bucks :eek:
  10. Mar 29, 2011 at 11:48 PM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    X2 most everything i have bought on my truck now has been from group buys and new things people sold. Saving a little with every piece really adds up in the end.
  11. Mar 30, 2011 at 10:15 AM
    Rider11
    Hope, Arkansas
    Ok so I can replace just the UCA (kenny what brand are yours) Did you just do UCA and ext coilover in the front? What are some good leaf brands?
  12. Mar 30, 2011 at 10:38 AM
    Namyo
    Namyo -
    I have a silly question....the Icon ext travel coil over (correct me if I'm wrong) Must be used with a uni ball UCA. Does this mean it gives more travel than the "standard" if you will, Icon coil over?
  13. Mar 30, 2011 at 10:41 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Negative, Im running the light racing and they arent uni-ball. i think the only thing the ext. travel does is give you more down travel, so i dont think you would really even be able to notice it unless you got aftermarket LCA's.
    I may be wrong on that tho
  14. Mar 30, 2011 at 10:46 AM
    Namyo
    Namyo -
    does the light race UCA have any less travel than the uni ball? :eek:
    and is there any travel comparisons for coil overs? Icon is the only one I see with the "ext".
  15. Mar 30, 2011 at 10:52 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Im not sure :eek: All i know is when i sent my Icons back to them to get rebuilt they can make them "ext" for pretty cheap, so i said why the hell not. I plan on getting some new LCA's soon so maybe ill be able to use them then haha.
    Im not sure on the travel, ill have to check my front i havent really flexed it a whole lot yet. The Uca's dont hit the shock at full droop but barely will rub the tire.
  16. Mar 30, 2011 at 10:55 AM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    this is excatly wat i want to do to my truck!!! god sooo sexy!!
  17. Mar 30, 2011 at 11:32 AM
    DevL
    DevL Well-Known Member
    OK lots of misinformation in this thread. Lets clear it up.
    1. Mid travel means more travel than stock, specifically an extended travel coil over up front, a stock length contyrol arm set up (not long travel), and an after market upper control arm, usually Uniball. Yes Light Racing has a non Uniball upper control arm but it has more travel than stock. If its not got an after market upper control arm you wont have more travel (as mit is what limits travel) and you need an after market extndded travel coilover as well (as it limits travel if you replace the upper control arm). If you are missing either its NOT mid travel, as you are still stock travel.
    2. No, a new stock length lower control arm, as in the Total Chaos unit as its the only one, will NOT give more travel, is NOT needed for mid travel, and has NOTHING to do with mid travel. It has integrated skids, a place for second shock mounting or airbump mounting, and has a Uniball for strength (not for travel).
    3. You also want to have a matching mid travel rear. This simply means "more travel than stock" and this means you need both a shock with more travel and a spring that will allow for that travel. This means a new spring as an add-a-leaf will not increase avaialable travel as it is too stiff and inhibits down travel. This would be a whole new spring pack like Alcan, Deaver, etc.
  18. Mar 30, 2011 at 11:37 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Yes, but you really have to modify the bumpstops to notice. If you pull the stock bumpstops and install hydraulic bumps or Light Racing jounce shocks, with the right coilovers you'll be able to compress the suspension farther than the ball joint will allow. Really, it's farther than even a 1" uniball can handle.
    The ideal in this case is to run 1.25" uniball UCAs to handle the travel, but again that's only if the bumpstops are replaced with hydraulic bumps.
  19. Mar 30, 2011 at 12:24 PM
    Fisheez
    Fisheez Built Ford Tough.
    Zack
    So Cal
    Tacomaless For Now
    Cna I backflip my truck with Midtravel?
  20. Mar 30, 2011 at 12:54 PM
    Namyo
    Namyo -
    Sounds like a light race UCA and an Icon will be a good match up like beau has....for more travel than stock.
    How does the toytec coil over compare to the icon (shock Travel wise) pared with a light race UCA?
