Mid Travel
Discussion in 'Suspension' started by ARC, Mar 3, 2011.
  1. Mar 3, 2011 at 8:55 AM
    ARC
    ARC [OP] Well-Known Member
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
    I see the term thrown around a lot on here but I am not sure what exactly a mid-travel set up consists of. What do you consider mid travel?
  2. Mar 3, 2011 at 10:12 AM
    ARC
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
    I see, thanks.
  3. Mar 9, 2011 at 6:31 AM
    ARC
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
    I am reviving this thread for suggestions on how to build a 2nd Gen mid travel rear end.
  4. May 18, 2011 at 4:37 PM
    Nicks4x4LT
    Nicks4x4LT Official Villain
    Nick
    714 Orange county
    2010 4x4 V6
    Custom front bumper, Icon 2.5 ext. travel coilovers, Defined rear long travel King smooties w/ resi. Avid Offroad sliders, Fiberwerx front fenders, Glassworks Shorty TT style rear glass, URD MAF calibrator, DT shorty headers, URD TCAI, Magnaflow catback
    maybe a deaver leaf pack and icon remote resi rear shock.
  5. May 18, 2011 at 8:50 PM
    Nicks4x4LT
    Nick
    714 Orange county
    2010 4x4 V6
    yessir;), how are you liking the Icons?
  6. May 18, 2011 at 8:54 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I am running Fox extended coilovers with Total Chaos Uniball upper arm. Im the back right now I am running Fox (FJ shocks) with a aal....been considering Defineed Engineering SUA, so who knows but the back does keep with the front so I do not really need to change it but ehh
  7. May 18, 2011 at 8:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What would the wheel BS have to do with travel?
  8. May 18, 2011 at 9:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah....the wheels dont have any impact on suspension travel.
  9. May 18, 2011 at 9:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No it wont. Its not lengthening the arms, wich would in turn increase "travel". Regardless of the BS, it will still only go up and down what the suspension components will allow. If you had a BS of -14 feet, the tire would still go up and down whatever amount the suspension will allow.
  10. May 18, 2011 at 9:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I see what your saying, but the wheel is fixed to the hub. The hub goes up and down 8" (random number), and when the tire is attached, it too goes up and down 8"....Regardless of the back space.
  11. May 18, 2011 at 10:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nope. The wheel moves along the same plane the spindle does. Longer CA's = more travel. More BS = no more travel. You can have a wheel 19 feet past the hub, its still gonna go up and down only the 8" the suspension allows. If the wheels moved up and down in an Arc, then Yes. More BS would give a little more travel. But, with a double "wishbone" suspension, the wheel travels straight up and down (for the most part), and follows the movement of the spindle. Now, at extreme droop, the edge of the wheel actually goes UP a little bit, as the Camber goes into the negatives to the tune of about 3*, and twards the extreme compression, it goes into posative about 2*, but thats because the Tacoma doesnt use a parallel CA set up. As the suspension droops, the angle of the UCA is at a much steeper angle than the LCA, thus pulling the top of the spindle in a little more. Then on compression, the oposite happens.
  12. May 18, 2011 at 10:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your arm is connected at one pivot point, and moves in an arc. The Tacoma (and many other vehicles) use CA's to connect the spindle at an upper, and a lower location. They then mount to the spindle in the same respective points. This allows the spindle to move in a vertical plane, while remaining straight up, and not moving in an arc.
  13. Mar 11, 2018 at 1:12 PM
    DieselTech1
    DieselTech1 Active Member
    Doss
    Nampa, Idaho
    2017 TRD OR DCSB
    So how much wheel travel do you get out of your typical mid travel set up? Say an Icon stage 6 under a 3rd gen Tacoma?
  14. Mar 12, 2018 at 9:16 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Wow, this is an old thread. It's hard to find much info on mid travel setups. Try searching for "extended travel" instead. Should get more results. If you're specifically looking for info on Icon, you can check out this thread: https://www.tacomaworld.com/threads/icon-dynamics-stage-lift-thread.438120/
