Mid travel??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scfirefighter3125, Feb 13, 2015.
  1. Feb 13, 2015 at 6:07 AM
    scfirefighter3125
    scfirefighter3125 [OP] Member
    Abandoned Strip Club aka The Rusty Pole
    DCLB Sport
    Rev Tech lift, Nitto Mud Terrains, Aero Turbine exhaust, DC Blacked out wheels, brush gaurd, Led Bar, Bear Cat 880 CB, custom sound system.
    I am new first post so be gentle! I saw all the mid travel post. I live down south so no dunes or sand but trails and offroad parks. Looking at TC UCAs and Fox coil overs deaver rear springs not sure about shocks. I do pull small trailer with two ATVs. Should I just keep rear stock? Which fox coil overs I need 2" to 3" of lift to clear 285/70/17 super swamper iroks. On DC1 17x9 wheels. $$$ is a budget build! I would like more wheel travel and stability. If I ask anyone around my location about mid or long travel suspension they look at me like I got a third eye. Just not popular everybody is running 6" lifts for looks around me. 2006 TRD sport LB 4x4. Current set up is rev tech 2" spacers and 1" block in the back. Any help or suggestions is much appreciated! First post so if I missed anything or could have done better explaining let me know!
  2. Feb 13, 2015 at 7:36 AM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    Swampers on DC1 17x9 wheels, with fox coilovers and deaver leafs...:eek: Not a budget build!
    That said, I totally think you should still do it. That'll be a huge improvement over ucky spacers/blocks.
    If you're gonna go with Fox Coilovers up front, then go ahead and run Fox Shocks in the rear, the main reason I would do this is I want my brands to match on similar aspects such as shocks due to their engineering department designing them to work well together.
    I am unfamiliar with deaver springs, but I know my Dakars gave me more lift out back than I got in the front, and the only remedy for me to level the truck out was to get adjustable front coilovers... because I did not want to install spacers to try and bring the front of the truck up, and I needed to do so in order to clear my 285's.
    Here is a good thread about the fox coilovers over in the suspension forum:
    http://www.tacomaworld.com/forum/suspension/40191-fox-2-0-vs-2-5-coilover.html
    I call those drag trucks, because they're wearing high heels.
    Anyway, Looking forward to seeing your build. It sounds like you're started off in the right direction (AWAY From spacers).
  3. Feb 14, 2015 at 2:51 PM
    SexyTaco
    SexyTaco Well-Known Member
    matt
    Siloam, North Carolina
    Tacoma TRD 6 speed
    Fox MId-Travel and OME leaf packs with BAMF 12" shock relocation. Relentless Fab front bumper and custom rear bumper custom rock sliders. Other little stuff as well.
    I'm sorta asking for both of us, but he'll need limiting straps too won't he?
  4. Feb 16, 2015 at 7:04 AM
    scfirefighter3125
    DCLB Sport
    Good question
  5. Feb 16, 2015 at 7:43 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    I am pretty sure he won't need limiting straps unless he is jumping his truck and needs them to limit the shocks from dropping completely out.
  6. Feb 16, 2015 at 7:44 AM
    aubi1414
    Justin
    Pensacola, FL
    I would go fox's all around but it won't be a cheap build.
  7. Feb 17, 2015 at 5:53 AM
    scfirefighter3125
    DCLB Sport
    I never said cheap just budget. The only the only thing cheap so far on my truck is the loose nut behind the wheel
  8. Feb 17, 2015 at 12:57 PM
    scfirefighter3125
    DCLB Sport
  9. Feb 17, 2015 at 1:02 PM
    scfirefighter3125
    DCLB Sport
    I'm just trying to get my stuff straight so don't use deaver pack for the rear due to hauling because it preloads the front fox coil overs?
  10. Feb 17, 2015 at 2:11 PM
    scfirefighter3125
    DCLB Sport
    Gotcha! Thanks any suggestions usually only haul a sport atv on occasion so say in going on the heavy side but 600lbs. But mostly pulling a trailer with 3 ATVs.
  11. May 5, 2015 at 1:46 PM
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
    thanks that helped a lot
