mileage
Discussion in '4 Cylinder' started by texascolt45, May 26, 2013.
  1. May 26, 2013 at 5:29 PM
    texascolt45
    texascolt45 [OP] Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    what kind of mileage does the base 4 cylinder 5 lug trucks get?real world city and highway from somebody that has one.i might buy a short bed regular cab for back and forth to work.thanks in advance.
  2. May 26, 2013 at 10:16 PM
    2007 tacoma
    2007 tacoma Well-Known Member
    LEEEEEEROOOYYY JENKINS!
    2007 Access Cab
    16" Alloys, K&N intake, Class III Hitch, US Truck Cap Rack, Carpeted Bed Mat, WeatherTechs, SeatSaver covers, Many more in the works
  3. May 26, 2013 at 10:28 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I drive a no frills base model 2012 STD cab 2WD 5 lug that is presently averaging 24.3 mpg with a mixture of city/rural driving, and no freeway. It's used for work and so is always driven loaded with about 800 pounds of materials and tools.
  4. May 26, 2013 at 10:45 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I get between 23.5 and 25.5
    45 mile each way to and from work. Free-flowing 70mph in the morning, bumper to bumper for 2 hours evening.
  5. May 31, 2013 at 9:53 PM
    nullsignature
    nullsignature Member
    So you get ~24mpg @ 70mph?
  6. May 31, 2013 at 11:28 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    65-70, ya, pretty close.
    70-75 and it dumps to 23 PDQ.
  7. Jun 1, 2013 at 8:29 AM
    tooter
    Greg
    Los Angeles
    24mpg is reasonable. 60mph is 2,000rpm, so even 70mph is still only about 2,300rpm.
  8. Jun 1, 2013 at 1:36 PM
    2007 tacoma
    2007 Access Cab
    Just watch it on the hills, especially if cruise control is enabled. On the hills drive more with RPM in mind. I guess drive in general with RPM in mind more than speed. You may slow a little going up a steep grade but try to keep it around 2000 RPM. You can get back up to speed easily on the other side.
  9. Jun 1, 2013 at 2:29 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The 2.7 is a bit different. A 60mph cruise is probably closer to 1800, but on a grade, there's often no choice but to let it downshift.
  10. Jun 1, 2013 at 2:53 PM
    tooter
    Greg
    Los Angeles
    Hey that's interesting...
    There must be a difference in high gear between a manual and an auto. I have a 5 speed stick and 60mph is exactly 2,000rpm (and 90mph is exactly 3,000rpm). Your automatic must have a higher overdrive if it's only 1,800.
  11. Jun 1, 2013 at 3:47 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Also keep in mind that the speedometers are about 6% off.
    70 indicated on my dash is closer to 65-67 on the GPS.
