Milk shake diff fluid?
Discussion in 'Technical Chat' started by Malcolm3.4, Nov 13, 2011.
  1. Nov 15, 2011 at 3:44 PM
    #61
    98tacoma27
    Ben
    Not Beech Creek
  2. Nov 15, 2011 at 3:46 PM
    #62
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2....Im off to go punch a baby seral......
  3. Nov 15, 2011 at 3:47 PM
    #63
    98tacoma27
    Ben
    Not Beech Creek
    Save one for me
  4. Nov 15, 2011 at 5:57 PM
    #64
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    i don't understand how a axle seal will allow water inside the whole axle assembly...
    explain
  5. Nov 15, 2011 at 7:19 PM
    #65
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    Make sure you have A-Trac when you go to the beach to do it
  6. Nov 15, 2011 at 7:26 PM
    #66
    MonkeyProof
    SoCal- SGV
    paging DavidK, please report to front desk.. instructions needed on how to properly negotiate a sandy environment...
  7. Nov 15, 2011 at 10:36 PM
    #67
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Regarding all this douchebagerry and the need to be right....
  8. Nov 16, 2011 at 12:29 AM
    #68
    SiRMarlon
    SiRMarlon The Photo Ninja!
    Marlon
    Los Angeles
    Canon 5D MarkIII
  9. Nov 17, 2011 at 7:01 AM
    #69
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Oh thats easy. That one way breather lets air out but will not let air inside the housing. Oil seals are .... oil seals. Which means they are designed to keep oil inside the housing and not be a some kind of super seal. Remember those seals are just pieces of rubber riding on surface of axle. There is no way to make 100% seal on something like that. So when there is enough vacuum those axle seals will let air from outside and if you happen to be in the water they will let water in too.
    Its amazing how much vacuum gets created in that thing when seals and breather is new.
  10. Nov 17, 2011 at 8:31 AM
    #70
    MonkeyProof
    SoCal- SGV
    Meh...I was only tolling for replies lol.
    But let me ask you this...would you trust that little thingamigbobber to not let water while traversing through a water crossing?
  11. Nov 17, 2011 at 8:51 AM
    #71
    BlueT
    NorthEast
    That one way valve seals so well it won't let air IN nevermind water.
    Now if it is dirty and that rubber washer can not seal properly or spring is broken then yeah its possible to get water through. If its new and working correctly no way in hell to get water through it. Axle seals will let go before that breather does.
  12. Nov 17, 2011 at 8:54 AM
    #72
    MonkeyProof
    SoCal- SGV
    But would you trust it?
  13. Nov 17, 2011 at 9:05 AM
    #73
    98tacoma27
    Ben
    Not Beech Creek
    You realize that water is smaller than air?
  14. Nov 17, 2011 at 9:22 AM
    #74
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X3........ Why do I continue to read this stuff? :confused:
  15. Nov 17, 2011 at 9:26 AM
    #75
    HBMurphy
    Paul
    So California Coast
    None
    :rasta:
    H20 [​IMG]
    N2 [​IMG]
    H20 vs N2 - There are surface tension associated with - Oh never mind...
  16. Nov 17, 2011 at 1:30 PM
    #76
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    You shouldn't trust it! That is why we do the mod... Not because water gets in there, but because it doesn't break the vacuum, it CAUSES water to suck in AT THE AXLE SEALS.
    Put the true (2 way) breather up high... lets expanding gear oil pressure out, and clean air back in during a dip in water while hot situation.
  17. Nov 17, 2011 at 2:23 PM
    #77
    MonkeyProof
    SoCal- SGV
    Unbelievable
