Millenium Falcon Taco Build
Discussion in '1st Gen. Builds (1995-2004)' started by EB Group, Sep 17, 2015.
  1. Sep 17, 2015 at 4:31 PM
    EB Group
    EB Group [OP] Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    Hello All.
    In 2001 I owned a 88 Toyota 4x4 that was in pretty ruff shape.
    I haven't owned another truck until yesterday. I picked up a 2001 Tacoma 4WD DoubleCab V6 Automatic.
    What I can tell you about it is that it has over 376,000kms on it, it had it's frame replaced by toyota in 2012 (one of the reason's I purchased the truck), it is lifted 3" I think, The Leafs are suppose to be new, the gas tank has been replaced with a used rust free one from Texas, 4wd L and H engages as it should, all the power options work and I don't think the interior of the truck has been cleaned in the past decade (vacuumed yes, but not cleaned).
    :eek:
    I have started pulling it apart and cleaning things up.
    I will be replacing what needs to be replaced and will be improving/fixing what the previous owners have done to it thus far.
    Some of the things I will be doing:
    Things in bold are completed
    Replace the Front Drivers Side Axle.
    Replace AC Compressor
    Recharge AC System
    Replace PS
    and AC Accessory Belts
    Engine Oil Change
    Coolant Flush
    Transmission Fluid Change
    Front and Rear Diff Oil Change
    Transfer Case Oil Change
    Fix holes in the body
    Remove the interior and shampoo it as many times as necessary
    Remove the carpet from the floor and shampoo it
    Remove the door skins and clean the fabric and vinyl
    Clean all the plastic and vinyl not already mentioned in the interior
    Repair and recondition the skid plates and guards
    Remove the bed liner and clean under it
    Clean the inside of the tailgate & spray rust inhibitor in there.
    Recondition the Tow Hitch and install it on on the truck
    Remove all aftermarket wiring
    Replace Defective Heater Control Unit
    Resolve odd vibration while off the throttle at various speeds.
    Replace Front Diff Needle Bearing with ECGS Bushing.
    Replace the crap tires on the truck
    Sell the aftermarket rims and replace them with factory Toyota alloys
    Replace and service the front and rear brakes
    Repair the leaks in the exhaust
    Get the Park Brake working
    Finding out what Codes the ECU have thrown
    Replace the make-shift gas tank strap with an OEM one
    Replace the Door Lock Cylinders
    Replace the Ignition Cylinder
    Replace the Front Fenders
    Service the Exterior Door Handles
    Service/Replace Rusted Bolts
    Clean and reinstall Bed Liner
    Spray Rustcheck on Gas Tank
    Re-torque Driveline Bolts and Nuts
    Grease Propeller Shaft U Joints, Sliding Yoke and Double Cardan Joints
    Replace Rusted Rear Bumper
    Replace Spark Plugs and Wires
    Replace Rear Shocks Again
    Replace Front Strut Assemblies
    Remove Lift
    Replace Leaf Springs
    Replace Leaking PS Rack
    Replace PS Rack Bushings
    Replace Sway Bar Bushings
    Replace UBJ's
    Replace Sway Bar Links
    Repair Exhaust System Again
    Replace Axles Again
    Replace Front Turn Signal Housings
    Replace Drivers Front Turn Signal Harness Connector
    Resolve leak in Fuel Tank
    Redo Rear Brake Lines
    Replace Rear Brake Biasing Unit
    Install Extended Rear Brake Flex Line
    Replace Rear Half of E-Brake Cable
    Touch up Surface Rust on Frame
    Replace Font Bumper
    Service E-Brake Bell Crank Arms & Replace Springs
    Now, for pictures:
  2. Sep 17, 2015 at 6:03 PM
    EB Group
    Rudy
    Halifax
    Shot of the frame, pretty excellent condition for our Canadian climate and salty winter roads
    2002Tacoma4x4 likes this.
  3. Sep 17, 2015 at 6:04 PM
    EB Group
    Rudy
    Halifax
    I scored big with all the loose change I collected while cleaning out the truck!
    because_wumbo-truck and hr206 like this.
  4. Sep 17, 2015 at 6:08 PM
    EB Group
    Rudy
    Halifax
    Make-Shift Gass Tank bracket that needs replacing
  5. Sep 17, 2015 at 6:11 PM
    EB Group
    Rudy
    Halifax
    Perhaps I should explain the name of the thread.
    I am a lover of Star Wars. The Millenium Falcon is my favourite ship in that universe.
    My name for the truck is the Millenium Falcon.
    I presume the Taco does not need explaining.
    So we have a Millenium Falcon Taco Build.
  6. Sep 17, 2015 at 6:12 PM
    EB Group
    Rudy
    Halifax
    Seats Removed
  7. Sep 17, 2015 at 6:13 PM
    EB Group
    Rudy
    Halifax
    Carpet Vacuumed
  8. Sep 17, 2015 at 6:15 PM
    EB Group
    Rudy
    Halifax
    Carpet removed lets me do a thorough cleaning underneath, find and seal sources of water entering the cab and lets me remove areas that have rust buildup and touch up the paint afterwards.
  9. Sep 17, 2015 at 6:16 PM
    EB Group
    Rudy
    Halifax
    Shot of under the bed.
    I will take it in as the spare tire mount recall work has not been completed yet.
  10. Sep 17, 2015 at 6:55 PM
    EB Group
    Rudy
    Halifax
    So this ended up adding up to $21.19. That's a lot of spare change!
  11. Sep 18, 2015 at 9:02 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Nice! Cool to see you're taking care of it and cleaning it up real nice!
    EB Group[OP] likes this.
  12. Sep 19, 2015 at 4:09 PM
    sect0r
    sect0r Well-Known Member
    Oregon
    14 TRD Sport
    King Mid Travel, BAMF w/ 12" King's, ect
    Good job!
  13. Sep 19, 2015 at 4:22 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Awesome. Here's a couple things:
    1. I dyed my interior rug with this: http://www.amazon.com/gp/product/B00098PO3G?psc=1&redirect=true&ref_=oh_aui_detailpage_o07_s00 It took 3 cans for my regular cab. It makes the carpet a little bristly, but after it looks way better than a stained dirty carpet (even a nicely shampooed one lol).
    2. The vibrations could be because of the lift you mentioned. I'm getting ready to lift about 3" with new coilovers and leaf springs so I've been reading up on this too:
    https://www.tacomaworld.com/threads/just-fixed-driveline-vibration-for-free.153050/
    Time to get on that project so you can drive it in its new condition to the new Star Wars movie in December lol :)
    2002Tacoma4x4 and EB Group[OP] like this.
  14. Sep 19, 2015 at 4:40 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    That's some dedication and desire for her(Tacoma)!Very cool!
  15. Sep 19, 2015 at 7:09 PM
    EB Group
    Rudy
    Halifax
    Thanks for reading and for taking the time to suggest practical help.
    The carpet has been thoroughly cleaned and turned out awesome.
    I'll attach pictures of the cleaning and later of the result
  16. Sep 19, 2015 at 7:30 PM
    EB Group
    Rudy
    Halifax
    Seats have been shampooed several times. They turned out a good as possible.
  17. Sep 19, 2015 at 7:34 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Looks good! My truck looked like someone was learning how to hit their spit can while driving when I bought it. Glad you could get it looking new without paying for any products!
  18. Sep 19, 2015 at 7:37 PM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    Keep it up! I kinda want a project like this.
  19. Sep 19, 2015 at 7:40 PM
    EB Group
    Rudy
    Halifax
    I got a lot carried away with pulling things apart. In my defence, it was necessary.
    Front fenders will be replaced, I'm not fixing them.
    The rear fenders are gross but fixable.
  20. Sep 19, 2015 at 7:51 PM
    EB Group
    Rudy
    Halifax
    This is the kind of crap I'm finding
