Mirror Control light
Discussion in 'Off-Topic Discussion' started by blacktoy, Dec 6, 2011.
  1. Dec 6, 2011 at 7:40 PM
    blacktoy
    blacktoy [OP] Active Member
    NB, Canada
    Tacoma TRD
    Side Steps Tonneau Cover
    Hi,
    Just went to the dealer and they told me that there is no light for the electronic mirror control in the truck...pretty inconvenient at night! Is this correct?? I have a 2011 Tacoma TRD
    Thanks all!!
  2. Dec 6, 2011 at 7:43 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    I think he mean's this. OP why do you want it to light up? Not bashing just curious I'm sure you could rig up a led to go behind it.
  3. Dec 6, 2011 at 7:44 PM
    blacktoy
    NB, Canada
    Tacoma TRD
    Inside the truck on the left hand side of the driver's dash, there is a mirror control (for right and left) but it does not light up at night...is this normal?? I have had lights on all my cars...what's up with that??
  4. Dec 6, 2011 at 7:44 PM
    blacktoy
    NB, Canada
    Tacoma TRD
    Just want to know if it is normal or my dealer is BSing me..
  5. Dec 6, 2011 at 7:47 PM
    blacktoy
    NB, Canada
    Tacoma TRD
    Thanks allot, good to know its not only me...
  6. Dec 6, 2011 at 7:47 PM
    Warhorseforever
    Will
    Sand Lapper
    FWIW I don't think that my 1st gen does but it isn't that hard to remember where it's at.
  7. Dec 6, 2011 at 7:49 PM
    blacktoy
    NB, Canada
    Tacoma TRD
    Really appreciate the input and for you not making fun of me:D I have allot of stupid question....I'm a tacoma newbee:)
  8. Dec 6, 2011 at 7:49 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    How often do you have the need to adjust your mirrors? I can't even remember the last time I touched mine.
  9. Dec 6, 2011 at 7:50 PM
    blacktoy
    NB, Canada
    Tacoma TRD
    I'll try to set my mirrors during the day from now on !!
  10. Dec 6, 2011 at 7:52 PM
    blacktoy
    NB, Canada
    Tacoma TRD
    dont ajust often, just new to the truck...was going to the dealer and trying to iron out the little issues such as ticking ac motor, driveline vibrations, 4wd no light, mirror ajust no light...! Still adore the truck!
  11. Dec 6, 2011 at 7:54 PM
    Warhorseforever
    Will
    Sand Lapper
  12. Dec 6, 2011 at 7:57 PM
    Shep6924
    Shep6924 Active Member
    Navarre, FL
    '11 TRD Sport Debadged
    Side steps/nerf bars, iPod interface! Bug/rock deflector (removed!), 3" bilstein coilover 5100 & add-a-leaf, 1" diff drop! 1.25" spidertrax spacers, Light racing UCAs
    What did they say about the ticking a/c motor?? That thing has been driving me nuts...though that clears it up, its not just in my truck.
  13. Dec 6, 2011 at 7:58 PM
    blacktoy
    NB, Canada
    Tacoma TRD
    Thanks for the suggestion...I may buy a flashlight...probably simpler!!.... very low electrical skills:)
  14. Dec 6, 2011 at 8:00 PM
    blacktoy
    NB, Canada
    Tacoma TRD
    for the ticking motor, I found out on this site that there is a TSB out for that...hoping it is covered. My truck is at the dealer right now...I will know tomorrow. that was driving me nuts. I took the service manager out for a drive to make sure they could not say that they could not find it.
  15. Dec 6, 2011 at 8:04 PM
    Warhorseforever
    Will
    Sand Lapper
    It seems simple enough to me but it's your truck man :thumbsup: also try searching to see if there are any other mods you want to do that have a write up for them. In the top right hand corner under your username thing is the search function. Have fun spending all of your money!
  16. Dec 6, 2011 at 8:07 PM
    blacktoy
    NB, Canada
    Tacoma TRD
    Thanks man... I will definitely find more toys...so far...tonneau cover, steps, vent visors, ....lift kit...its the first time I love investing in a vehicle!
  17. Dec 6, 2011 at 8:08 PM
    Warhorseforever
    Will
    Sand Lapper
    Sounds good. Welcome.
  18. Dec 6, 2011 at 8:15 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    Believe me...the link that was posted to light up your 4x4 switch is easy to do and the customer support is awesome...you can't go wrong!! I had the same question when I bought my truck after seeing the mirror, foglight, and 4WD switches didn't light up.
  19. Dec 7, 2011 at 7:57 AM
    blacktoy
    NB, Canada
    Tacoma TRD
    Update....just got back from the dealer. They changed the ac blower motor under warranty...supposedly a problem for many. As for the driveline vibrations, they said that it was due to the lift kit...no luck with getting this fixed.
