Mirror shake help needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rpeker, Jan 1, 2013.
  1. Jan 1, 2013 at 2:33 PM
    rpeker
    rpeker [OP] Bad guy hunter
    San Angelo, TX
    2005 Tacoma Double Cab
    Morimoto HID Projectors, Weathertech mats, Hardwired radar detector, Flowmaster, Pioneer Nav
    TW,
    The drivers side mirror on my truck shakes like crazy when I drive. I was wondering if anyone else has this issue and more importantly if there is a fix for it?
    Here is a video to see what I am talking about:
    https://www.youtube.com/watch?v=6TDztFtRr6E
    singletrack_ftw likes this.
  2. Jan 1, 2013 at 2:40 PM
    bplppl
    bplppl Member
    TEXAS
    '00 Tacoma PreRunner
    Is it a powered mirror? If so it make have come undone and should snap back in place unless the plastic clasps are broken. If its not power, then I would think some heavy industrial glue like JB weld, Gorilla glue, or Liquid Nails to re attach the mirror to the pegs.
  3. Jan 1, 2013 at 2:42 PM
    rpeker
    San Angelo, TX
    The truck is an SR5 so it does have the power mirrors. I can take another look, but the mirros feels secure to me, it just shakes like crazy when I drive...
  4. Jan 1, 2013 at 2:50 PM
    BARTRD
    BARTRD Well-Known Member
    Brian
    Monroe, Ga
    '07 RR TRD Sport
    Volant CAI with optional skoop, Magna-Flow exhaust, K&N drop-in air filter, WeatherTechs, Wet Okole, kenwood navigation head unit, de-badged, 15% tint all around, factory roof rack fitted with Thule fairing, billy 5100 on all 4 corners, ICON AAL, n-fab light bar with 4 hella 500s, rear lights mounted under bumper
    Mine is the same way. I never really paid it much attention though. But it does shake more than the passenger mirror
  5. Jan 1, 2013 at 2:59 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Pull the "sail" from the inside of the door and check the 3 nuts that hold the mirror to the door.
    The nuts on my '95 Suburban were always coming loose.
  6. Jan 1, 2013 at 3:03 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hmm thats a lot of movement. Mine vibrates but only at highways speeds and high winds.
    Chadley22 likes this.
  7. Jan 1, 2013 at 3:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    He mentions in the vid that the mount to the door is solid.
    OP, You might have to disasseble the mirror, and check the "Fold-away" part, and make sure its not loose inside. You should be able to tighten it up a bit.
    wilcam47 likes this.
  8. Jan 1, 2013 at 3:59 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ahh.. Didn't have sound turned on and couldn't tell from the vid if it was the mount or not.
  9. Jan 4, 2013 at 11:48 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    This is a very simple, 2 minute fix.
    On the bottom of the mirror housing on the outside you will see a very small cover. Use a small flat screw driver to open that cover being careful not to scratch anything.
    Inside that cover you should find a Torx screw. I don't remember what size it is, but tighten that screw and check to see if that does the trick. Remember to close the cover.
    My driver's side mirror vibrated like crazy on my 08 Sport 4x4 DC too, and I found this fix on another website.
    Hope that helps.
  10. Jan 6, 2013 at 9:58 AM
    rpeker
    San Angelo, TX
    I will try this later tonight and let you know how it works out! If this works then YOU ARE THE MAN!!!!
    Rocketball and wilcam47 like this.
  11. Jan 6, 2013 at 11:35 AM
    tagman9111
    tagman9111 Member
    11 TRD Sport
    Same thing happened to mine. Tighten the three torx screws on the outside bottom of the mirror (one is exposed, two are under the plastic cover). Remember to tighten with a T25 torx bit. I tightened mine with the wrong tool and now it is rusted and rounded out--doesn't rattle though. Can't find a new screw because they are not sold separately and no one wants to sell me theirs!
    hiker29 likes this.
  12. Jan 6, 2013 at 1:54 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    He IS the man, cuz he's right and that's the problem :D. Your pivoting hinge is a little loose.
  13. Jan 6, 2013 at 5:13 PM
    rpeker
    San Angelo, TX
    Nope, the three screws are all snugged down nice and tight :( If I can use those same three to take the mirror off then I will take it off when I get a chance and see if something is loose inside.
  14. Jan 6, 2013 at 6:11 PM
    File IFR
    Central MA
  15. Jan 6, 2013 at 8:01 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    My 06 did the exact same thing. Only the mirror and not the housing and it was the drivers side also. It way annoying as hell but I never did anything about it. Only was really bad at night with lights behind me.
  16. Jan 19, 2017 at 10:45 AM
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    I have this same issue. I'll need to try the torx bolts on the bottom. It is super annoying though.
  17. Jan 19, 2017 at 10:55 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Bingo. My passenger side is always coming loose and that's the fix. However, next time I'm going to use Loctite on the tiny threads.
  18. Nov 15, 2018 at 12:34 AM
    knockhanh
    knockhanh Well-Known Member
    SF Bay Area
    2015 Tacoma TRD OR
    kinda bringing this thread back to life since I now have this same issue. I tried tightening the 3 screw underneath the cover on the outside of the mirror as well as removed the glass and tried tightening the screws on the inside, hasn't worked yet :/ hope someone has a solution
  19. Nov 15, 2018 at 4:35 AM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    I have this exact same issue. I tried tightening the torques bit under the drivers side mirror and it was already very tight. It could not be tightened any more. I ordered an aftermarket $34 mirror on eBay. I’m installing it soon. It it fixes my issue I’ll be happy. I’ll report back! Mine is an 08 TRD OR DCSB
  20. Nov 15, 2018 at 10:28 AM
    knockhanh
    SF Bay Area
    2015 Tacoma TRD OR
    tempted to do the same. Saw a mirror on CL for $30
