Misfire (i believe) when I acc.
Discussion in 'Technical Chat' started by DTCVTC, Nov 30, 2010.
  1. Nov 30, 2010 at 6:10 AM
    DTCVTC
    DTCVTC [OP] Member
    Ok Ive got a question for you.
    2005 v6 TRD 6 spd
    when I accelerate it seams to missfire above two grand. Heres the weird part no engine coads or check engine lights coming on. Already changed plugs.
    Ideas?
  2. Nov 30, 2010 at 6:19 AM
    98tacoma27
    Ben
    Not Beech Creek
    Is that supposed to be two grand?
  3. Dec 2, 2010 at 11:26 AM
    DTCVTC
    DTCVTC [OP] Member
    No ideas
  4. Dec 2, 2010 at 11:27 AM
    tarheelfan_08
    tarheelfan_08 Carolina Alliance
    Justin
    North Carolina
    2010 White 4x4 Double Cab Tacoma Short Bed
    Chrome Grill, Chrome accessories(door handles and mirror covers), LEER Super White Cover, Mirrors with Turn Signals, Window Vent Visors, Step Rails, WeatherTech Digital Floor Mats, Mini Maglight Holder, Chrome Bull Bar
    I am not sure I am following you. Are you saying that when you press the gas sometimes the RPM's go up but the truck's speed does not. It only last for a few seconds then the truck goes?
  5. Dec 3, 2010 at 10:11 AM
    DTCVTC
    DTCVTC [OP] Member
    I dont believe there is a rpm drop but the truck hesitates.
    oh and i am lost about 2-4 mpg
  6. Dec 3, 2010 at 10:18 AM
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS, 2017 LAND CRUISER
    I would check to start:
    Air filter
    Fuel injectors
    Spark plug wires
    Fuel filter
    MAFS
    Bad gas
  7. Dec 3, 2010 at 10:34 AM
    RichB
    RichB Well-Known Member
    Rich
    MA
    2023 Nissan Frontier Pro4X
    This happened in my car '01 Grand Am, it would hesitate off and on when climbing a grade. It clears up when I fill the tank with the Shell or Mobil 93 octane gas.
  8. Dec 3, 2010 at 4:45 PM
    tcoe99
    tcoe99 Well-Known Member
    sask
    08 tacoma
    leveling kit
    mine has a similar problem. its very irregular but at 3000rpm it drops to idle for a few seconds, then jumps right back to where it should be. ive had it in a couple shops and no one can figure it out. ? still trying to find a solution.
  9. Dec 6, 2010 at 9:30 AM
    DTCVTC
    DTCVTC [OP] Member
    The RPM's do not drop and the air filter is new
    I have done plugs so next will be trying 93 oct if that doesnt work I am planning on a fuel filter.
    The shop said there was nothing wrong with it
