misplaced Master Key and Fob
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnson8537, Aug 10, 2008.
  1. Aug 10, 2008 at 12:23 PM
    Johnson8537
    Johnson8537 [OP] Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    Ok guys... somehow i have misplaced my keys with the master and the key fob. I backed the truck in the garage thursday night and haven't driven it since... i don't know if they are aroudn my house someplace or if they somehow fell out of my pocket when i was driing my wifes car.
    My Question is what is the differance between the vallet and the master?
    if i buy a new key off ebay or someplace does anyone has the instructions to add it to the system?
    I have and extra Master and FOB and one vallet.
    thanks in advance...
  2. Aug 10, 2008 at 12:35 PM
    rick
    rick `
    i don't think there is a difference in this case. usually the valet key will only lock/unlock the doors. and they wont work for the trunk or locking glovebox. so i dont know
  3. Aug 10, 2008 at 3:54 PM
    camsbored
    camsbored Well-Known Member
    Raleigh, NC
    08 PreRunner DC/Sport/LB
    Kenwood DNX8120, Homelink mirror, Valentine One hardwire
    Yep, valet just doesn't unlock the glove compartment. A friend of mine has been driving around with only the valet key for over a year.
    Do you still have the little metal tag with a number imprinted on it that came with the keys? If so the dealer can create a new master key.
    Blank keys and extra fobs can be had online and cut by anyone that cuts keys... but you'll need to activate them both with the security system. I don't know if this can be done ourselves or if the dealer has to do it.
    Good luck!
  4. Aug 11, 2008 at 10:05 AM
    Johnson8537
    Oregon
    I don't have the tag... but i do have a spare MASTER...
    Here are instructions I found I will let you guys know if it works..
    2002+ TOYOTA, LEXUS
    Requires one working Toyota/Lexus Master Key.
    1. Make sure all doors and windows are closed.
    2. Insert Master key into the ignition cylinder.
    3. Cycle the ignition cylinder from On to OFF five times.
    4. Open and close the driver side door 6 times.
    5. Remove the Master Key and insert the new duplicates key.
    6. TURN THE IGNITION CYLINDER ON.
    7. The new key will be registered after 60 seconds. The THEFT light on the dashboard will go out, indicating that programming has been completed.
    Toyota Techs.... anyone know if this works???
  5. Aug 11, 2008 at 9:19 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    i JUST went through this. So all i had was the gray valet key. you cannot make a copy using that key. you must have your black key to make copies. if you do not have the black key, then you must get the computer flashed and both your gray key and a new black key flashed. The key is about 60 bucks at the factory (Find one on ebay, they go for cheaper there), re-flashing the comp was somewhere around $125-$150. Expensive key, but kind of necessary for me considering all i had was ONE gray key. I have my black key in a very safe spot.
  6. Aug 12, 2008 at 11:27 AM
    Johnson8537
    Oregon
    Like i said in my original post. I still have ONE Master Key and One Vallet Key... I just though about getting another master so i had two Masters and One Vallet Key. ..
    I also had to do what you did on my last truck... (It only came with a vallet key and i wanted a spare key... just in case.)
  7. Aug 12, 2008 at 11:33 AM
    jefferson
    Sex Panther
    05 PreRunner SR5
    oh sorry, i got excited
    haha
  8. Aug 12, 2008 at 3:55 PM
    Johnson8537
    Oregon
    np... (i will let you guys know.. if i decide to get a new key.)
