miss during low rpm and WOT
Discussion in '1st Gen. Tacomas (1995-2004)' started by jaymeduty, Oct 15, 2011.
  1. Oct 15, 2011 at 5:30 PM
    jaymeduty
    jaymeduty [OP] Member
    Jayme
    bozeman
    This truck is new to me. 1997tacoma ext cab 5-speed 4X4 v-6 244K the truck has a real bad miss and jerks real hard if you are in lower rpms and try to accelerate. Ex. taking a corner in 3rd and then trying to get back to speed. truck starts and idles perfect sounds great. I am thinking i will replace fuel filter, plugs and wires but wanted to see if anybody had this happen to them and what the fix was. Thank you
  2. Oct 15, 2011 at 5:33 PM
    jberry813
    jberry813 Making TW Great Again Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Welcome to TW.
    You got the right idea.
    I'd put money the plugs are fouled out, but replace everything you mentioned. :thumbsup:
  3. Oct 15, 2011 at 5:48 PM
    jaymeduty
    Jayme
    bozeman
    I have read that the fuel filter is under the drivers seat inside the rail for the v-6's. Is there any good tricks to make this project easier
  4. Oct 15, 2011 at 5:50 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    That's exaclty where it's at, and it's a piece of cake. There's 1 bolt holding the filter to the bracket and it comes right off.
    I'd suggest you use a flair nut wrench on the fuel lines instead of a regular box wrench so you don't strip the heads of the fuel lines. Also do this BEFORE unbolting the bracket.
  5. Oct 15, 2011 at 6:07 PM
    jaymeduty
    Jayme
    bozeman
    that is exactly what i was looking for. Is there a better brand of fuel filter, plugs, wires to buy. I usually get all my parts from oriely's
  6. Oct 15, 2011 at 6:13 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Stick with factory twin electrode factory Denso or NGK for the plugs.
    I personally would stick with the factory Denso wires, but I'm just anal retentive that way. I like the wires not being too long which they always seem to be when you get them aftermarket.
    My fuel filter is from kragen/oriely.
  7. Oct 15, 2011 at 6:21 PM
    jaymeduty
    Jayme
    bozeman
    are the factory parts a dealer only item or are they sold at any major supplier
  8. Oct 15, 2011 at 6:28 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Plugs you can get otherplaces. Kragen/Oreily caries NGK.
    I doubt you'll find Denso plugs or wires locally outside the dealer. My dealer parts I normally order from here:
    http://www.trademotion.com/partlocator/index.cfm?siteid=840
    It's about 1/3 of the price of you're local dealer and no tax if you're out of state and free shipping over $100. They normally have killer deals on 10 packs of OEM oil filters that comes out to less than 4 bucks a filter.
  9. Oct 15, 2011 at 6:36 PM
    jaymeduty
    Jayme
    bozeman
    Great info thank you. I am sure i will be back with more questions sooner than later.
  10. Oct 15, 2011 at 6:42 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    No promises on any more answers...let alone helpful ones. I'm well on my way :drunk:
  11. Oct 15, 2011 at 7:38 PM
    jaymeduty
    Jayme
    bozeman
    cheers to that
  12. Oct 16, 2011 at 12:55 PM
    jaymeduty
    Jayme
    bozeman
    just changed the fuel filter with a new wix, the plugs with new NGK's and I don't remember the brand of wires but the where the expensive ones. The wires said 1997 so i am assuming they where original. the plugs where so burnt up i am surprised it even had spark. truck is running 100% better and i am hoping fuel economy increased too. thanks for the help and the tips.
    Jayme
  13. Oct 8, 2013 at 10:05 AM
    mrraidermann
    mrraidermann Member
    artis
    Phoenix AZ
    98 reg. cab 2x4
    all stock
    U can find Denso plugs at Car quest auto parts.
