missfire question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hambone155, Mar 15, 2011.
  1. Mar 15, 2011 at 8:38 PM
    Hambone155
    Hambone155 [OP] Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    ok so i did diagnostic.
    compression. 160psi .... other cylanders 158-162. so pretty close
    ohm the injector. 13.8 . spec
    wasnt getting a good spark. replaced plug and coil pack.
    still getting a little misfire
    soooooo i think it is either a vacuum leak or my exhaust is getting shitty and think it might be a back pressure issue.
    its verry minor and only get it untill 1700 rpm then it balances out.
    please let me know what you think
  2. Mar 15, 2011 at 9:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check the vacuuim lines first.
  3. Mar 15, 2011 at 9:16 PM
    Hambone155
    omaha
    how do i check vacuum lines on a supercharged truck?
  4. Mar 15, 2011 at 9:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check for cracks in the lines, you can use carb cleaner, smoke, etc. Be carfull if using carb cleaner, as it can catch fire if an open spark is around. If the engine reves when you spriy a line, then you found the leak.
  5. Mar 15, 2011 at 9:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I had this problem once in the past, similar symptoms, and it turned out to be the large line going to the brake booster. You may want to start there first.
  6. Mar 15, 2011 at 9:26 PM
    Hambone155
    omaha
    thank you very much chris.
    you have allways been very helpful.
  7. Mar 15, 2011 at 9:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dont thank me yet. ;) Let me know what you find
  8. Mar 15, 2011 at 9:28 PM
    Hambone155
    omaha
    i will. im gonna put a new muffler on anyways. sounds like shit right now. and ill do that at the same time
  9. Mar 16, 2011 at 6:14 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Which supercharger do you have, black or grey?
    Aside from the vacuum lines, check the actuator itself. If you look at the bottom of the actuator it's like a rubber diaphram. After time, that rubber wears out. I had this exact problem on the s/c in my Miata. I aquired a tiny hole in the rubber diaphram. If it turns out to be that, you can purchase just the replacement actuator for like 40 bux or so.
    It took me a week to hunt down the vacuum leak. In the end, it was a cigar that found the leak for me. Puff, puff, blow around vacuum lines, pass :D
  10. Mar 16, 2011 at 6:19 PM
    Hambone155
    omaha
    grey and thank you very much
  11. Mar 16, 2011 at 6:41 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Grey, got it. There only boost/vacuum line is the line on the top of the s/c manifold on the back side rightly behind the top of the "T" in TRD. I belive all the rest of the lines are vacuum only. Don't quote me on this cause I have the second gen S/C, but I'm pretty sure that's the line that runs to the vacuum fuel pressure regulator on the back side of the motor.
    If you have the URD 7th injector or a boost gauge, it would be T-ed off this line. I threw a lean code after I did my boost gauge on my Taco because of a mental retardation moment on my part in this area. Give it a once over as well if you have any extra goodies T-ing off this line.
    Also as Chris mentioned, you can use various fluids to listen for a change in RPM on the motor due to vacuum leak. My poison is starting fluid. Again as Chris mentioned, just try to keep it off any exhaust manifolds. Garden hose on standby always a good idea. Good luck ;)
  12. Mar 16, 2011 at 6:50 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Don't forget about faulty/clogged injectors. Run a can of Seafoam.
    Berry, leave the starting fluid alone, it's very dangerous to use as that kind of diagnostic tool. Carb cleaner is harder to ignite.
  13. Mar 16, 2011 at 6:54 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Awww cmon. It was half the adventure! :eek: Granted that idea came up half way through the "cigar," and starting fluide was all I had on hand. But touche...let's go with carb cleaner FTW. :D
  14. Mar 16, 2011 at 6:58 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Cigar???? :rasta:
  15. Mar 16, 2011 at 7:34 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yessir.
    Tradition, valor and victory....
  16. Mar 16, 2011 at 8:33 PM
    Hambone155
    omaha
    ok put it on a lift. found a loose line. plugged it in. didnt really help. looked for others and didnt see any. i think that it could me a lower intake manifold?
    anybody had one or replaced one.
    im going to run a can of sea foam through a quarter tank to make it concentrated. then ill go from their.
  17. Mar 16, 2011 at 9:03 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Correct me if I'm wrong, but doesn't your S/C replace the upper AND lower intake manifold? I know on my black S/C it replaced both halfs.
  18. Mar 16, 2011 at 9:10 PM
    Hambone155
    omaha
    heck if i know. anyone else know? their should still be a lower intake gasket
  19. Mar 16, 2011 at 9:12 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  20. Mar 16, 2011 at 9:12 PM
    Hambone155
    omaha
