missing airbag on/off switch
Discussion in 'Technical Chat' started by HyTrojan, Mar 10, 2007.
  1. Mar 10, 2007 at 10:37 AM
    HyTrojan
    HyTrojan [OP] Well-Known Member
    Jared
    South Louisiana
    2020 MGM Sport AT DCSB
    Nfab running boards, PapaRee Tune, T4R Pro SEMA rims
    Looks like I'm missing the on/off switch (place where the key inserts) for the pass. side airbag. I looked in the book & it shows I have one. I've looked at many pictures of the 2007 Tacoma, automatic trans, reg. cab... but all showed the key switch. I'm almost afraid to ride my kid. Any help you can give would be great as my dealer says I should have one.
  2. Mar 11, 2007 at 6:23 PM
    HyTrojan
    Jared
    South Louisiana
    I think I searched all the forums, but I didn't find anything on this. Anyone?
  3. Mar 11, 2007 at 6:25 PM
    Ldytaco05
    Ldytaco05 it's all about me
    Orlando, Fl.
    2005 PreRunner,Enkei Wheels
    there should be weight sensors on your truck. i have an '05 and when my daughter is riding in front the airbag will not deploy because of her weight. that should apply to you too. not unless you want to bring it back to the dealer and have it checked out to where the location is?
  4. Mar 11, 2007 at 6:50 PM
    HyTrojan
    Jared
    South Louisiana
    Thanks for the reply. I even googled for pictures of Tacoma interiors to see if there was a key switch. I was worried since all the pics I saw had them. I'm glad to hear yours is set up that way as well.
  5. Mar 11, 2007 at 7:23 PM
    jetqc
    jetqc Member
    i have 07 double-cab it's a weight sensor also.
  6. Mar 11, 2007 at 7:40 PM
    coreyredken
    coreyredken Well-Known Member
    North Georgia, Mount Airy
    07 Prerunner SR5
    Westin Stainless Steel Oval Side Bars!
    My o7 has a weight sensor also. its pretty cool.. I read all about it in the owners manual..
  7. Mar 11, 2007 at 7:41 PM
    TACOMATruckin98
    TACOMATruckin98 Carolina Alliance
    if it has a key turn-off, it should be pretty obvious up on the dash. All new cars have "smart air bags" which only deploy when a passenger is detected with a weight over, i believe, 80 pounds, atleast for toyota. Moms new 4runner only has the sensors. There should be some sort of display thing that tells you when it is on or off.
  8. Mar 11, 2007 at 7:49 PM
    coreyredken
    07 Prerunner SR5
    It will say "Off" when it feels something in the seat that is below a certain poundage..
  9. Jun 16, 2007 at 2:46 PM
    robert
    robert Active Member
    I asked the same question on my 07 4 door, and the dealer said that the truck no longer come with a air bag on off switch because it was found that it was unsafe for a child to ride in the front seat of a truck or car in a child seat. you will find that most trucks do not come with the air bag on off switch any more.
  10. Jun 16, 2007 at 2:50 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    The double cabs most definitely do not have the on/off switch, reasoning is the kid will fit in the back seats and there is absolutely no justifiable reason for a child to ride in the front seat of a doublecab.
  11. Jun 16, 2007 at 5:01 PM
    spp
    spp OC, Kalifornia
    OC California
    '07 Access Cabs Most definely have them. The logic for not in the D-Cab is sound but the original post had to do with a regular cab, and that should warrant an off switch or else you would not be able to safely carry a child. Maybe you are supposed to tie them down in the bed?
  12. Jun 18, 2007 at 6:06 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I have an AccessCab, and I have the switch on the dash and the pressure sensor under the seat.
    I would talk to your dealership about that. I would request to see other Regular Cabs to see if they are setup the same...
  13. Jun 18, 2007 at 8:40 PM
    ZonKs
    ZonKs Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    I have a key switch and a pressure sensor as well.
    Ted
