Missing jack kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by cinla, Aug 24, 2009.
  1. Aug 24, 2009 at 12:47 PM
    cinla
    cinla [OP] Member
    Baton Rouge, LA
    96 Tacoma
    Hello all,
    I have a 96 Tacoma that has a jack, but I am missing the thing that comes in 3 sections that allows you to lower the spare tire and crank the jack. Anyone know where I might find a replacement? I am not terribly savvy, as likely evidenced by my not even knowing what the part is called.
    Thanks for the help folks!
  2. Aug 24, 2009 at 12:48 PM
    cole47
    cole47 Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    ebay possibly????
  3. Aug 24, 2009 at 12:53 PM
    cinla
    cinla [OP] Member
    Baton Rouge, LA
    96 Tacoma
    I have looked on Ebay, but generally they sell the entire kit (including the jack, lug wrench, and the piece I need) for around $75 with shipping. I am trying to avoid paying so much when I only need the one piece. I was hoping I could simply buy the piece at an auto parts store. I really don't know how interchangeable they are.
  4. Aug 24, 2009 at 1:02 PM
    98tacoma27
    Ben
    Not Beech Creek
  5. Aug 24, 2009 at 1:03 PM
    gvidas
    gvidas Member
    western NY & coastal oregon
    essentially stock trd sport
    stock
    My experience is only with an 07, but the mechanism appears to basically be a small hand-cranked winch, and the extension arm only functions to get you up close to the piece. Mine is a eyehook shaped piece of steel that fits into the equivalent of a large slotted screw head.
    So if you found some other segmented jack arm, it's going to probably have a similar 1/4" square end where the segments connect together. So you could probably get a piece of 1/4" square stock, bend a circle or something on it, and then carry that around for the raising and lowering.
  6. Aug 24, 2009 at 1:44 PM
    cinla
    cinla [OP] Member
    Baton Rouge, LA
    96 Tacoma
  7. Aug 24, 2009 at 3:14 PM
    98tacoma27
    Ben
    Not Beech Creek
    My 98 ext had 12, 13 and 14.
