Missing part from immobiliser system
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raf-1200, May 28, 2019.
  1. May 28, 2019 at 8:24 PM
    raf-1200
    raf-1200 [OP] Active Member
    2008/2012 Tacoma 2tr-fe rear wheel drive
    Lowered, turboed, haltech, body kit, mags, 3 inch pipe
    after installing a 2012 dash loom in my 2008 Tacoma (hilux here in oz) I have a code coming up P2799. Looking through the manual and checking out the loom it seems that I am missing an important part. Not sure if this is the cause (the key has been coded correctly and the security light goes out) but still won't start.
    https://youtu.be/-iSwDAEf2K4
    Anyone know what the part number I need or can properly identify it?
  2. May 29, 2019 at 6:23 AM
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    This is an engine immobilizer code, the computer does not recognize the key you are using. Make sure you are using the key that always started it before, any other non programmed key will not work, it has to be a key with a transponder chip and it has to be programmed to work with the computer.
  3. May 29, 2019 at 9:09 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Troy
    Las Vegas
    2017 Pro/2015 Tacoma
    Lifted
    This ^
    Stryker420 likes this.
  4. May 29, 2019 at 11:14 AM
    raf-1200
    The security light goes out with this key so I’m assuming the transponder works fine. I’m thinking it is something to do with the security ecu or amplifier that is the problem
  5. May 29, 2019 at 11:34 AM
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Sounds like the transponder isn't giving the ecu the signal... Well good luck!
  6. May 29, 2019 at 10:13 PM
    raf-1200
    Update. I checked the injectors and the spark and they both work temporarily. This is leading me to believe the ecm/security is shutting it down.
    I also realised that if I turn the key completely off and then back on that is when she runs briefly. If I just turn it from accessories it won’t fire at all.
