missing parts
Discussion in 'Solid Axle Suspension' started by yotanation29, Jun 27, 2012.
  1. Jun 27, 2012 at 8:04 PM
    yotanation29
    yotanation29 [OP] Well-Known Member
    ADRIEL
    CHULA VISTA
    98 TRD
    all pro upper a arms, icon extended travel 3", bumper cb, clarion nav, and much more to come!!
    im doing an sas and am in the need for a new front axle, and rear leaf springs, where i can get these for a decent price? i dont mind used stuff either. i found someone with a 90 4runner thats being parted out, would it fit on my 98?
  2. Jun 27, 2012 at 10:29 PM
    erisman33
    erisman33 Crawlin Over 1 Rock At A Time
    Pismo/Mendocino
    1995 Ton'd Taco
    1 Tons with 4 Wheel Disc
    are you running toyota axle for your swap or what.....:confused: The rear leafs i would go to a junk yard and pull chevy 63 best bang for your buck then go to ruff stuff and order the CHEVY TO TOYOTA spring kit. Thats your rear end. 90 4runners i believe are coiled in the rear. 90 4 runner arnt straight axle either....???? Not sure what you would use off of it but if you need something grab it i guess :D
  3. Jun 28, 2012 at 8:35 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Op has many hours of research left. If people are asking what will work they haven't done enough research. Go read every thread on TTORA and Pirate4x4 twice and then make your decision.
    A 90 4runner has the same suspension as you. There is no SA. Why are you even doing a SAS anyway?
  4. Jun 28, 2012 at 9:11 AM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Cuz its the new fad
  5. Jun 28, 2012 at 9:13 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    whats your budget op?
    and since a solid axel front is custom... you can put anything you want under it, technically.
  6. Jun 28, 2012 at 9:18 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Is the SAS group that tight nit that they don't want to help out by answering questions? Couldn't you just simply answer the question instead of just telling people to do more research? What the hell do you think this person is doing by asking the fucking question? When you read through all of the other threads explaining how to do this it is very informative no doubt but you can simply get lost and confused by the abundance of info, its over whelming. You talk about not wanting people to have bad info but more often than not you respond with do your research. No doubt you know your stuff and have a very well built truck but damn man. The first time you built a truck did you not have questions? I know damned good and well that you didn't read through threads and have all of your questions answered without asking some yourself.
  7. Jun 28, 2012 at 9:20 AM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Because he (SupraTT) did research and then asked educated questions, not dumbfuck ones. Just like if someone asked what 2 plus 2 was...there is a certain level of knowledge expected of an individual before deciding to go in a certain direction with a build, and obviusly the OP has not yet reached that level of knowledge. Reading or researching for five minutes would enlighten him as to how dumb of a question he asked. And why he got the response he did.
  8. Jun 28, 2012 at 9:22 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    When you don't know you ask. Since when is that a crime? And who determines what is a dumbfuck question (You?) When what you decide someone has asked a "dumbfuck" question why not simply answer them and point them in a better direction? Its doesn't take that much longer to type a helpful response than the ones you post. Lazy?
  9. Jun 28, 2012 at 9:38 AM
    erisman33
    Pismo/Mendocino
    1995 Ton'd Taco
    Throw a question my way and i'll try to answer it. I've spent lots of time trying to.a budget build on my.tacoma. Direct question are better than general question because you'll have 10 different ways and answer when asking general question.......
    Alot of good and useful information is on pirate unDder tacoma and also pickup and 4 runners. :D
  10. Jun 28, 2012 at 9:41 AM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Thats what was done. The most helpful response. Search pirate and TTORA. You mad bro?
  11. Jun 28, 2012 at 9:42 AM
    Supra TT
    Eric
    Indiana
    I wasn't really trying to be mean. And I was helping him. I spent 4 weeks straight every day after school 5-8 hours a day reading the forums. The ENTIRE month of January I spent reading. I did ask questions, here and there that I couldn't find specific answers to. But I did research. Even to this day I ask questions...
    These aren't lazy responses, we spent over 100 hours researching and learning information that may not be helpful, and may be helpful. It's time others do there fair share of reading. The best answer we can give you is to research.
  12. Jun 28, 2012 at 9:44 AM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Shit we've done over 40 hrs of research just on Supras full hydro steering alone, and we havent even asked a single question yet. The answers are out there....the lazy thing is not to search and expect everyone to just give you the answers.
  13. Jun 28, 2012 at 9:44 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    No doubt. I wasn't directing that at you.
  14. Jun 28, 2012 at 9:54 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    SupraTT:
    I know for a fact because your truck proves it that you do your research and are one of the better people to answer questions about a SAS. When I frequented Chevelle forums and asked the same old questions about things I felt were novice I would still answer them simply because I was in his/her shoes before and even thought the info is out there it is often times hard to find and even harder to understand because its not always your exact vehicle you are reading up on. So when I came across a member asking a question I posted a link to help them learn and gave them the answer in a simplified way. It left them needing more info yet that to was provided in the link I had provided. This is also the Internet and written words are easy to read yet sometimes hard to interpret.
    I have been in these people shoes before and it is frustrating because I know I do alot of reading (my job allows lots of free time) forums yet I feel even more so lost afterwards, because we all know not everything on the internet is true and that in itself guarantees questions. You have made a great list of parts however I don't know exactly which parts I would need for my own build, the best write ups aren't done on a vehicle such as mine as is likely the case for others.
    Nwitaco:
    Na not mad, also not a bro.
  15. Jun 28, 2012 at 10:10 AM
    Supra TT
    Eric
    Indiana
    Op, to find a front axle, best place to look is on craigslist. They have many used axles. Also, leaf springs. Go with the 63" chevy leaf spring swap. You can find these springs at a junk yard or craigslist as well. For the leaf springs all you need is the rear springs off an 88-2010+ 1/2 ton or 3/4 ton Chevy or GMC truck
  16. Jun 28, 2012 at 10:14 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED), 2006 F350 King Ranch 6.0L
    The irony in this statement is if no one asked questions, what would your research stem from...
    I'm surprised you didn't link your sticky.
  17. Jun 28, 2012 at 11:04 AM
    Supra TT
    Eric
    Indiana
    It is ironic. However, people wouldn't be saying "research more" if this was the first SAS done :D.
    I would like my sticky, but it's in this section and not much he asked would be answered.
  18. Jun 28, 2012 at 11:24 AM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    What would be learned from SupraTT...drop your truck off and ask for a SAS. Drop your truck off and ask for a cage. Find someone to fix it all when you get it back :rofl:
  19. Jun 28, 2012 at 11:31 AM
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    Sounds about right!! It's a lot of info and a lot of it is different so it gets extremely confusing
  20. Jun 28, 2012 at 12:31 PM
    Supra TT
    Eric
    Indiana
    You laugh now, but you're the unlucky soul that gets to fix it :cool:
