Missing Transmission cooler.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zingbot, Jun 11, 2020.
  1. Jun 17, 2020 at 7:17 AM
    #441
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Why did ones that were built newer come with it then?
    usmc2msu likes this.
  2. Jun 17, 2020 at 7:32 AM
    #442
    Xplosiv
    Xplosiv Well-Known Member
    Jeff
    Lewisville, TX
    2021 OR DCSB Black 99 Corvette FRC
    265/75/16 AT's, Cali Raised Sliders, BAMF RTT Rack
    I dont know if easy is the word. Thats the only time ive ever had any issue with it and like I said we were out crawling (less than 10mph) for probably 4-5 hours before the issue arose. I daily drive the truck in Texas (typically 100*+ in the summer) without issue along with towing with the truck.
    But an additional cooler couldn't hurt.
  3. Jun 17, 2020 at 7:36 AM
    #443
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Hot is different than cooked to the point of failure. You probably experienced some severe oil breakdown. Did you happen to know the temp when the issue started?
  4. Jun 17, 2020 at 7:46 AM
    #444
    Xplosiv
    Jeff
    Lewisville, TX
    Nope. My trucks all stock so I dont have a way to monitor the trans temp.
  5. Jun 17, 2020 at 7:59 AM
    #445
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  6. Jun 17, 2020 at 10:04 AM
    #446
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    That's a pretty sophisticated system if it allows for colder fluids and hotter fluids to flow at the same rate. I like it! Is the additive Sea Foam? I think I am going to price around now for a complete flush and fill with something synthetic, and I might add an additional cooler like you did.
    I found another thread that gets kudos from @gearcruncher started by @Lord Humongous
    This is an excellent thread in just the first page. I plan on reading through that entire thread as well.
  7. Jun 17, 2020 at 10:14 AM
    #447
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    The additive is lubeguard. This is the stuff for 2nd gen. Not sure for 3rd gen.
    https://smile.amazon.com/dp/B002MB57UI/ref=cm_sw_r_cp_apa_i_96K6EbZK4AJGA
    I just used Toyota WS fluid. Figured I'll change it often enough it should be fine, especially at the lower temps. That being said, I'm overdue. I will say mileage was affected by lower daily temps, but I don't drive this with all the mods for high mileage.
    RobP62[QUOTED] likes this.
  8. Jun 17, 2020 at 10:25 AM
    #448
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    If they eliminated the ATC and changed the radiator a bit couldn't you compare the two radiators looking for any differences ?
  9. Jun 17, 2020 at 10:30 AM
    #449
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    It's looking like they didn't change anything but remove the cooler. So the only difference in the tow package trucks being made now compared to the pre 2/2020 trucks will be the cooler itself.
  10. Jun 17, 2020 at 11:07 AM
    #450
    TacomaN8
    TacomaN8 Well-Known Member
    Nate
    tbd
    Cause it was a production phase out decision and not a hard MY change decision... they stopped putting them on as the parts ran out.
  11. Jun 17, 2020 at 11:22 AM
    #451
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I guess we’ll see!
  12. Jun 17, 2020 at 11:33 AM
    #452
    4x4spiegel
    4x4spiegel Well-Known Member
  13. Jun 17, 2020 at 11:35 AM
    #453
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    Initially the Long Tru Cool 4589 but later upgraded to the Long H7B for 20% more capacity.
    The Long 4590 as has been mentioned also fits the space and has the same dimensions as the H7B.
    The H7B just allows you to choose your hose connection size with 1/2” National Pipe Thread inlet and outlet.
  14. Jun 17, 2020 at 11:54 AM
    #454
    Xplosiv
    Jeff
    Lewisville, TX
    Bleep100 likes this.
  15. Jun 17, 2020 at 12:16 PM
    #455
    jetfishn
    jetfishn Well-Known Member
    If I go in to the local Toyota dealer in the near future to buy and the Offroad model I choose doesn't have the aux trans cooler, I will just walk. I tow a lot, and I offroad quite a bit as well, and there is supposed to be a tow package on these trucks. That includes a auxillary trans cooler. I might end up buying a lightly used OR but its hard to save money, I am still not ready to buy due to the noisy rear diff problem. Quality control seems to be getting out of hand with Toyota Tacoma production.
    JNG likes this.
  16. Jun 17, 2020 at 1:11 PM
    #456
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Do you have anything showing that it is needed or is just because that's what you're used to and that's what been there in the past? I assume Toyota looked into it and decided it wasn't and they could save money by eliminating it. If it worries you that much you can always add an additional aftermarket cooler that will be better anyway.
  17. Jun 17, 2020 at 1:18 PM
    #457
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Definitely a disappointing situation for those that ended up without the cooler unknowingly. For those looking to buy, their is the option to negotiate adding the OEM setup at the time of purchase.
  18. Jun 17, 2020 at 1:21 PM
    #458
    mydogsmonkey
    mydogsmonkey Well-Known Member
    Ernest
    Burbank, CA
    2020 White TRD OR AT V6 4x4
    Do you have something from Toyota showing that?
  19. Jun 17, 2020 at 1:38 PM
    #459
    Xplosiv
    Jeff
    Lewisville, TX
    I would be interested in something from Toyota regarding how the cooler install is going to affect the powertrain warranty.
  20. Jun 17, 2020 at 2:25 PM
    #460
    Zingbot
    Zingbot [OP] Well-Known Member
    Thanks for the info. It will be a more difficult install for me because of the lack of lines to the front of radiator.
