Mixing different Mobil 1 oils
Discussion in 'Technical Chat' started by mws4ua, Oct 25, 2008.
  1. Oct 25, 2008 at 11:09 AM
    mws4ua
    mws4ua [OP] I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    OK... I don't think this question has been answered...
    I just purchased oil for my next oil change. Due to economics, I purchased:
    • One 5-qt jug of Mobil 1 10w-30 "Extended Performance" Full Synthetic
    • One 1-qt container of Mobil 1 10w-30 Full Synthetic (NOT Extended Performance)
    I can't see anything different between the oils except for the "Extended Performance" oil says it will go 15k miles. I only plan to go 5k miles anyway.
    My question is this... Is there any reason I can't mix these two oils? They're both Mobil 1, they're both Full Synthetic. It will be 5qts of Extended Performance, and .5 qts normal.
  2. Oct 25, 2008 at 11:16 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Honestly?
    I think it's all the same oil - it's just marketing. They use that as a tool to see which 'marketing gimmicks' work best.
    I remember a few years back when Excedrin started putting out the Migraine headache version. I compared the ingrediants and they were exactly the same. I asked a Pharmacist about it and even they said "it's the same pill"
  3. Oct 25, 2008 at 11:34 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Put the extended in last....that way the other stuff will drain first. Problem solved!
    Yeah yeah yeah, I know.....
  4. Oct 25, 2008 at 11:38 AM
    mws4ua
    Birmingham
    Thanks. That wouldn't surprise me at all.
    I actually thought I'd do that. It makes sense to me. I figured I'd put the normal stuff in first, then let it settle while I changed the tailgate differential fluid, then put the extended stuff in.
  5. Oct 25, 2008 at 5:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The "extended" oils have more addatives, however, I have had the best oil samples useing the regular "Fully synthetic" Mobil 1 oil.
