Mobtown Offroad Bolt On Tailgate Reinforcement Plate for 2016+ Tacoma
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Mobtown Offroad, Mar 18, 2016.
  1. Jul 16, 2016 at 2:10 PM
    #181
    wudbuchr
    wudbuchr Well-Known Member
    Linnie
    Lexington, TN
    2016 (7128A) BBP 4x2 - TRD Sport Access Cab
    * Clear Bra (full front) * BBP (8T0) Side Body Molding * Tinted Windows with AWS window shades * Romik Running Boards * Color matched Undercover Lux bed cap and BedRug bed liner * MobTown Locking bed storage doors, Tailgate skin and cap * Chrome Tailgate Script lettering * G-Tec Fab Door Sill Protectors and OEM Mud Guards * Fumoto Valve * ScanGauge-II * LED Interior, Stop, tail, Bed, OPT7 LED H11 low beam and fog lights * WeatherTech floor mats * Clazzio seat Covers * Removed jump-seats & rear seat-belts * Sound deadened back wall, rear posts, rear doors and front doors with a layer of RAAMmat, a layer of Ensolite, and a layer of EzCool * Insulated the roof with two layers of EzCool * GT series Image Dynamics speakers (6x9 fronts, 6.5 rears) * Audio Control DQ-61 DSP, 5-channel amplifier and sub woofer. * Redline Tuning Quick Lift Elite hood struts * Thinkware F770 (Dual) Dashcam with Cellink Battery B * Lexus SmartKey Transmitter and Emergency Key
    Thank you Joe! Now I can start saving for that 3rd Gen rear bumper you have
    been bragging about. Oh! before I forget, the Rustolium High Temp BLACK
    spray paint is a close match for anyone needing to touch up their skin or cap's
    shipping scars. I used a little on a queue tip to touch up some edge scrapes
    received in shipment. I also used it to paint the heads of the Metric cap screws
    (M6x1.00.25MM) I used to replace the OEM screws I took out. You can find
    the cap screws at Lowes.
  2. Jul 16, 2016 at 2:16 PM
    #182
    wudbuchr
    Linnie
    Lexington, TN
    While you are at Lowes picking up those Stainless Steel screws, I also suggest
    you buy two packages of 3/16" x 1.0" fender washers (four each) to put on the
    back of the cap (where it meets the skin) those elongated holes in the cap are
    pretty big.
  3. Jul 16, 2016 at 2:20 PM
    #183
    Mobtown Offroad
    Mobtown Offroad [OP] Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Good info. The slots are fairly over sized for two reasons:
    One to compensate for gasket between the underside of the cap and the top side of the tailgate and two to compensate for any slight variation when forming the part on the press brake. You can gain or lose material at each bend depending on the bottom die, how sharp the top die is and the actual thickness of the material. 14 ga steel is typically .0747" thick but can vary a few thousandths here and there. This makes a difference when running the parts. You should mic each piece, or at least the first piece from each sheet when running through the press brake because on a CNC brake you have the field to enter the material thickness for each piece to give you the most accurate results when bending.
    solscooter likes this.
  4. Jul 19, 2016 at 10:35 AM
    #184
    wudbuchr
    Linnie
    Lexington, TN
    Hey Joe! I saw that my cap refund was posted back to my account on Friday.
    Thanks for the quick response. Now, if you'd just be that fast with the Gen3
    rear bumper (ha,ha). The skin and cap mods look GREAT and don't affect the
    tailgate assist that much. Hopefully I will be able to send you some more
    business. These two mods more than pay for themselves in peace of mind
    alone. Thanks again.
    Mobtown Offroad[OP] likes this.
  5. Aug 5, 2016 at 4:30 PM
    #185
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Place your order here: mobtownoffroad.com
  6. Aug 5, 2016 at 10:40 PM
    #186
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    and........ordered
    :broccoli:
  7. Aug 7, 2016 at 5:31 PM
    #187
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    15% off our Tailgate Reinforcement Plates. Use code "skin15"
    Final hours of the sale.....ends tonight.
  8. Aug 8, 2016 at 7:44 AM
    #188
    AFHart
    AFHart I'm just telling ya what I told ya!
    Denver Area
    2017 DCSB TRD OR 4x4 - MGM
    I have got to have the worst luck on catching these deals... !@&% :goingcrazy:
  9. Aug 8, 2016 at 12:56 PM
    #189
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    PM sent...
  10. Aug 11, 2016 at 8:03 AM
    #190
    jowybyo
    Joe
    Baltimore, MD
    We have a fresh batch of these in stock. Order now and we'll get it out asap.
  11. Aug 16, 2016 at 7:08 PM
    #191
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
  12. Aug 16, 2016 at 9:40 PM
    #192
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    with the combined weight of the two, the tailgate falls right down. hydraulic no longer makes for a light tailgate land.
  13. Aug 17, 2016 at 4:07 AM
    #193
    jowybyo
    Joe
    Baltimore, MD
    Hmmm....on our truck it definitely comes down quicker but it's not the same as on the 2nd gen without the easy down. On the 2nd gen it falls so hard it sounds like it might rip the whole tailgate off the truck.
  14. Oct 7, 2016 at 6:02 PM
    #194
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Get a cap at half price with the purchase of this plate this weekend only, use code bogo.
    Place your order at mobtownoffroad.com
  15. Nov 15, 2016 at 3:53 PM
    #195
    ATR55
    ATR55 Well-Known Member
    Aric
    Nor Cal
    2017 TRD pro
    How much will the weight of the reinforcing cap and plate affect the tailgate assist?? can the assist be adjusted?
    EDIT: just read above, my bad.
  16. Nov 15, 2016 at 3:58 PM
    #196
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    On the lock storage box doors can you get all 3 locks keyed alike?
  17. Nov 15, 2016 at 4:02 PM
    #197
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    We key orders alike standard.
  18. Nov 15, 2016 at 4:36 PM
    #198
    IPNPULZ
    going to be fun!
    :thumbsup: Off to order
  19. Nov 15, 2016 at 8:01 PM
    #199
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
  20. Nov 15, 2016 at 8:42 PM
    #200
    hksjza70
    hksjza70 Well-Known Member
    Westminster, CO
    Any chance you guys will make a smooth version of the tailgate plate for the 2016?
