MOD - LED Bed Lighting Connected to Cargo Light / Bed Light Circuit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Quicksander17, Jan 26, 2018.
  1. Dec 21, 2021 at 6:49 PM
    #41
    80sforlife
    80sforlife Well-Known Member
    2017 Toyota Tacoma DC TRDOR 4x4
    So what is the consensus can I operate the Matt gecko lights to full capacity by tapping the green wire or is it dim because not enough power?
  2. Feb 6, 2022 at 10:56 AM
    #42
    Lateralus01
    Lateralus01 Well-Known Member
    2018 Cement Tacoma TRD OR DCSB 4x4
    @mrkabc could your method here be used to trigger (not power) a set of rock lights?
  3. Feb 6, 2022 at 11:14 AM
    #43
    caribe makaira
    Caribbean, Puerto Rico
  4. Feb 6, 2022 at 11:18 AM
    #44
    Lateralus01
  5. Feb 6, 2022 at 11:25 AM
    #45
    caribe makaira
    :hattip:
    Lateralus01[QUOTED] likes this.
  6. Feb 6, 2022 at 3:52 PM
    #46
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    @caribe makaira is WAY more qualified to help you than I am! Hat tip sir!
  7. Apr 1, 2022 at 8:03 AM
    #47
    Waxifari
    Waxifari Well-Known Member
    Denver/Boulder Metro
    2021 Pro
    THIS is what I needed to know - thank you. If you want your SwitchPros trigger wire to work with your dome lights you cant actually trigger natively off your dome circuit due to dim function. Also, I learned that if you add-a-fuse off your cargo circuit in the sub panel (fuse panel in cab) it wont work either because that appears to be always hot (meaning its not switched). This little green wire however will trigger your SwitchPro perfectly to sync with Cargo lights which is essentially the same functionally as triggering off your dome circuit. So now, key fob lock, unlock or door open and SwitchPro lights up my UpTop BD rock lights. Very slick. Probably others have figured this out as well but just adding here so that it may be findable if others are looking. Thanks again.
    mrkabc[QUOTED] likes this.
  8. Apr 10, 2022 at 10:44 AM
    #48
    caribe makaira
    If you select your ShitPro gadget to use a negative trigger you can use the violet wire of the cargo switch. And @kmorgan3 has a intercept harness so you don't go cutting into the OEM wires.Plug-and-Play Switch Illumination Harnesses
    kmorgan3 likes this.
  9. May 10, 2022 at 2:16 PM
    #49
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB
    Great idea
  10. Jan 23, 2023 at 4:30 PM
    #50
    Crazy Larry
    Crazy Larry Active Member
    NJ/Phila
    2022 AG Trail Edition
    This thread was very helpful. I just tapped the green wire to trigger relay for some Baja S1 work lights on my roof rack using the cargo light rocker. Worked great! Post #8 was key.
    Lateralus01 likes this.
  11. Jan 23, 2023 at 5:53 PM
    #51
    caribe makaira
    Could've done this also.
    upload_2023-1-23_22-0-50.jpg or this:upload_2023-1-23_22-15-14.jpg
    Parallel to Cargo Lamp circuit.
    Rocket23 and helix66 like this.
  12. Aug 29, 2023 at 5:23 AM
    #52
    Rocket23
    Rocket23 Supreme post overlord.
    Rocket
    Conn.
    2019 sr5
    Forthcoming
    My cargo light connector has no power. Not even switch illumination. (I added an oem switch that connects to the connector for that switch ) that harness has no power.
    There is a 7.5 amp fuse and that has power. So now what can I do? My truck is an access cab with no cargo lamp. I guess I need a color code for the switch. Or start tapping into other cab/ door lighting wires.
    Any thoughts? Sorry for the hi jack.
  13. Aug 29, 2023 at 5:24 AM
    #53
    Rocket23
    Rocket
    Conn.
    2019 sr5
    Forthcoming
    I’m adding my own lights fwiw similar to the you tube video.
  14. Aug 29, 2023 at 3:23 PM
    #54
    caribe makaira
    Was the light stalk at parking lights to verify switch illumination?
    Did you verify there's a fuse in the Cargo Lamp fuse location?
    Did you verify there's a relay for the Cargo Lamp?
    Rocket23[QUOTED] likes this.
  15. Aug 29, 2023 at 3:31 PM
    #55
    Rocket23
    Rocket
    Conn.
    2019 sr5
    Forthcoming
    Yes. I temporarily used the relay right above the cargo relay position in there. Switched on the lights. Nothing.
    I tested the back of the harness. Before the relay was put in the proper place nothing.
    The fuse box has the proper 7.5 fuse in good order. To be sure. That’s the second one in closest to your knee. Not the firewall.
  16. Aug 29, 2023 at 3:35 PM
    #56
    caribe makaira
    OK, let's do one item at a time. Dash switch(s) illumination - 5A Panel fuse. Verify.
    Rocket23 likes this.
  17. Aug 29, 2023 at 4:00 PM
    #57
    Rocket23
    Rocket
    Conn.
    2019 sr5
    Forthcoming
    Sorry. Neighbor came over.
    Check. and All dash lights are operative
  18. Aug 29, 2023 at 4:03 PM
    #58
    caribe makaira
    Multimeter to Cargo Lamp connector pin 1 (green wire), other probe to pin 4. Verify.
  19. Aug 29, 2023 at 4:05 PM
    #59
    Rocket23
    Rocket
    Conn.
    2019 sr5
    Forthcoming
    Voltage or continuity?
  20. Aug 29, 2023 at 4:11 PM
    #60
    caribe makaira
    Voltage with Parking Lights selected.
