Mod: Navigation Hack allowed passenger use GPS while the car moving.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CampGuy, Jan 15, 2014.
  1. Jan 16, 2014 at 4:44 PM
    CampGuy
    CampGuy [OP] Well-Known Member
    Dmitry
    California
    2013 4x4 TRD-Sport
    That's right my friend, so you can just connect that wire to the ON/OFF switch and then you have no issues..! (that' what I did, anytime when you want to "type address" you push that switch off and then switch on back after you done.) :)
  2. Jan 16, 2014 at 4:49 PM
    TRD Toy85
    TRD Toy85 Well-Known Member
    CT
    loaded 2013 TRD sport
    You are the man ! thank you so much for sharing this !
  3. Jan 16, 2014 at 5:55 PM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
  4. Jan 16, 2014 at 11:30 PM
    CampGuy
    Dmitry
    California
    2013 4x4 TRD-Sport
    You right DoorDing, Thanks Done!
  5. Jan 21, 2014 at 10:22 AM
    CampGuy
    Dmitry
    California
    2013 4x4 TRD-Sport
    Hey there,
    The BLACK wire from (Rocker Switch) for blue LED (you don't have to add it) otherwise you can add simple ON/OFF switch.
  6. Jan 31, 2014 at 2:20 PM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    Question: Has anyone that's done this mod noticed if it has an effect on the phone (dialer) operations that are also disabled when the vehicle is moving? (I know you can use voice commands when moving.) Thanks in advance.
  7. Feb 1, 2014 at 8:11 AM
    Cain
    Cain Well-Known Member
    Southern California
    2012 Tacoma
    Chrome don't get you home
    Anyone?
  8. Feb 1, 2014 at 2:24 PM
    CampGuy
    Dmitry
    California
    2013 4x4 TRD-Sport
    Yep, Iv'e done it! no effects on the phone!!!:D
  9. Feb 1, 2014 at 3:35 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    A well earned + Rep to the OP. :thumbsup:
  10. Feb 1, 2014 at 3:47 PM
    1of7627
    Mark
    Post Falls, ID
    Thanks! I appreciate the feedback.
  11. Feb 1, 2014 at 5:16 PM
    imsuperjp
    imsuperjp Well-Known Member
    JP
    San Antonio, TX
    2017 Silver Sky TRD Sport
    i'd avoid this mod. my gps is off by 100 ft now
  12. Feb 1, 2014 at 8:28 PM
    CampGuy
    Dmitry
    California
    2013 4x4 TRD-Sport
    Not possible!
    * Make sure you cut the right wire and connect the ON/OFF switch!
    ** When switch position offthe GPS off approximately 50-100ft.
    Please check this out and let me know..
  13. Feb 2, 2014 at 5:14 AM
    imsuperjp
    JP
    San Antonio, TX
    your original post, before you edited it, made no mention of the switch until I posted that i cut the wire and the GPS could not find my location. Then you posted to add a switch. If you had done this mod, then you would have known it did not work without the switch before i made my post and if you actually did this mod, you would know the off switch means your gps cannot locate you and not that its off 100 ft.
    If anyone else has done this mod with the switch and it worked, i'll shut up and move on, but until then, i would advise not to do this mod
  14. Feb 2, 2014 at 6:34 AM
    yogster
    yogster merkwürdigliebe
    Tom
    Massachusetts
    13 Black DCLB SR5
    DCLB Black 4WD Illumination dial from 4runner, Flyzeyes LED. Hardwire GPS and Valentine1 with BlendMount mirror mount, TRD shift knob, tube steps, swapped out for signal lamp mirrors. Garmin Eco-Route HD for Bluetooth ODBII Diagnostics, 2014 Entune Plus w Navigation, Leer 100XL dome light wired to dome circuit, pop&lock tailgate and cap locks.
    I'm not the OP but, I had previously reported in this thread that the speed sensor wire did more than just disable functions when moving. This is well documented elsewhere. Other vehicles I have had - and some aftermarket radios use the speed sensor wire in conjunction with GPS data to provide accurate tracking. No surprise that is the case here. I posted this so others could make an informed decision to cut or not to (my recommendation is don't). I don't know when the OP changed his original post.
    I did not cut my wire. I pulled out the pin, and put it back. With the pin out full GPS function was enabled. Tracking was off. Tracking was restored after pin was reinserted AND device was rebooted (required more than on/off but could have been a timing thing, it was not instantaneous for me, YMMV)
    I had also previously stated there was no parking brake connection. I was incorrect. On a 2013 with base audio there is NO connection to the parking brake (ie a wire that is grounded when brake pedal is depressed). On a 2014 there IS a parking brake connection shown. Once the weather is warmer I'll test out grounding this pin to see the effect and post my results. I'll use a lead, a pin and simply connect to ground emulating the parking brake pedal being depressed. This will not be connected to the parking brake at all, so no light will come on or anything. Speed data should not be impacted.
    I had previously installed an aftermarket stereo that had both the speed and parking brake inputs. The parking brake wire being grounded was sufficient to enable the disabled functions without impacting functionality even temporarily.
    Without internal diagrams to how the radio works, I can only discern the available TIS wiring diagrams have to offer, which merely shows a ground connection to the parking brake (when depressed).
  15. Feb 2, 2014 at 8:50 AM
    #35
    Cain
    Southern California
    2012 Tacoma
    So confusing?
  16. May 27, 2014 at 4:04 AM
    #36
    jjconkli
    jjconkli Well-Known Member
    Jesse
    Boston
    13 Access TRD OR
    Clazzio Seat Covers w/heaters Fog Light Mod Softopper
    Has anyone else tried the switch on this mod?
    Thinking about doing it but...
  17. Jul 12, 2014 at 7:12 AM
    #37
    SuperDutyDave
    SuperDutyDave Active Member
    Dave
    People's Republic of VT
    ToyTec Boss Syspsension 3"
    Any ideas on how to add navigation to a non-premium Entune head unit?
  18. Jul 23, 2014 at 5:32 PM
    #38
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    any updates?
  19. Mar 1, 2015 at 11:21 AM
    #39
    chubrok
    chubrok Well-Known Member
    Yorkville, Illinois
    TRD Sport W/ Nav
    I would like to say that this mod 100% works on my 2014 entune w/o JBL. I have been looking to do this mod for quite some time and finally did it yesterday without issue. Once the switch is flipped back on it takes my GPS approximately 30 to 45 seconds to correctly locate me again. Thank you OP for posting this mod.
    Revelations likes this.
  20. Mar 1, 2015 at 12:10 PM
    #40
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    thats all i did on my 2013 stock head unit. Removed the pin from the plug, now i can make calls via the head unit while moving.
    I also spliced in to the ignition switch wire and put a 2 position switch on it to a constant 12v so i can turn the radio on without keys in the ignition.
