Mod Wiring!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Breaky0self, Mar 17, 2018.
  1. Mar 17, 2018 at 4:04 PM
    Breaky0self
    Breaky0self [OP] Well-Known Member
    Jupiter fl
    2011 Trd Sport metallic grey 2wd
    I don't have enough room on the terminals to connect the mods im adding. All the harnesses have relays, I don't want to go the Spod route. Suggestions to add these connections?
  2. Mar 17, 2018 at 4:07 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Not sure how much power you need, but if it's small amounts I'd look into fuse taps.
    Breaky0self[OP] likes this.
  3. Mar 17, 2018 at 4:14 PM
    Breaky0self
    Jupiter fl
    All the harnesses have fuses,
    This is everything im trying to have connected to the truck
    Warn 10k winch
    40" led light bar
    20" led light bar
    ditch lights
    rock lights
    and topperezlift
    1bad2k[QUOTED] likes this.
  4. Mar 17, 2018 at 4:19 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
  5. Mar 17, 2018 at 4:26 PM
    wafersmith
    wafersmith Well-Known Member
    Brian
    2017 TRD OFFROAD
    Many
    Switch-pro, I got one and it’s awesome. Dump all the relays and extra wires.
  6. Mar 17, 2018 at 4:36 PM
    Breaky0self
    Jupiter fl
  7. Mar 17, 2018 at 4:40 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    The bleaseas is the main piece. The breaker doesn’t serve any purpose other than protectting the wire from the battery to the blue seas panel. This wire is usually very short so not much to protect.
    You also need to think about relays. Everything you listed will need relays to power them, as well as your switches in the cab to activate them.
    Leave the winch straight to the battery.
  8. Mar 17, 2018 at 4:50 PM
    N128CG
    N128CG Well-Known Member
    2017 Tacoma TRD OR
    Stock
  9. Mar 17, 2018 at 5:01 PM
    Breaky0self
    Jupiter fl
    This is where i get confused, should i go w/the minibus or the 5025 panel. The winch will be connected directly to the batterie, there are 3 harnesses w relays/ and fuses. Rock lights doesn't have a relay- only a fuse.
  10. Mar 17, 2018 at 5:07 PM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    Blue sea fuse block is the only way to go!
  11. Mar 17, 2018 at 5:10 PM
    Breaky0self
    Jupiter fl
    Do you happen to have a pic of your install?
  12. Mar 17, 2018 at 5:29 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Blue seas over the mini bus. The blue seas will handle your fuses.
  13. Mar 17, 2018 at 5:46 PM
    Breaky0self
    Jupiter fl
    Ok, but what about if your fuses are built into the harness? 0D27DBFF-AFA8-421F-A81C-D0F252461EEF.jpg
  14. Mar 17, 2018 at 6:00 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    As much as I hate some people that say this, you should take some time and truly learn a bit about 12v wiring and relays and switches. To do this cleanly and properly, you need to have a decent understanding at what all the parts are actually doing and how they interact with each other.
  15. Mar 17, 2018 at 6:10 PM
    Breaky0self
    Jupiter fl
    I hear this, im taking my truck to the shop monday to have a bumper installed, im gonna have them finish all the wiring, i just need to know which terminal to bring them!
  16. Mar 17, 2018 at 6:12 PM
    Breaky0self
    Jupiter fl
    My basic understanding is. I'd remove the fuse off the harness, connect it directly to the bussmann and then stick the fuse in the bussmann panel, correct. Bussman obv conects directly to the battery + & -
  17. Mar 17, 2018 at 6:13 PM
    Breaky0self
    Jupiter fl
    Or i could just leave all the harnesses the way they are and buy the minibus ?
  18. Mar 17, 2018 at 6:17 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    The blue seas (when properly hooked up) will make everything look clean and professional, and make adding more accessories very easy.
    The mini bus will give you more places to attach ring terminals, and allow you to build a bird nest of wires inside your engine compartment, till something melts or hits a belt and catches on fire.
  19. Mar 17, 2018 at 6:21 PM
    Breaky0self
    Jupiter fl
    Ok so hooking it up properly: Removing fuses off harness's, leaving relays on, sodering/crimping new connections, adding fuses to blue sea panel, correct?
  20. Mar 17, 2018 at 6:22 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    yes
