Modest Lift Recommendations
Discussion in 'Suspension' started by Surfh2o, Sep 11, 2014.
  1. Sep 11, 2014 at 9:17 AM
    Surfh2o
    Surfh2o [OP] Well-Known Member
    Since I got my truck a year ago I've been looking at suspension options and man it's confusing. So I'm hoping to get some help. I have a 13 DC LB with truck cap. I'm looking for 3" of lift, which is the max I can go and stay within my warranty. I don't want to go the cheapest or the most expensive. I don't plan on tackling the install myself because I'm just not confident in doing so and may not have the tools. I'm looking to spend about $2000-$3000 for everything and hopefully installed too. In reading these forums it seems like you can't just buy a kit, you always need a UCA or some adapter, block, flipped U-bolt or something. I'm trying to figure out exactly what to get so I can have it ready to bring to my installer. Hopefully that will save me money instead of them marking up the materials. Or should I just go there and say I want 3" and have them give me quotes? Also, I don't do any serious off-roading. I would say easy trails, to deep sand. Any recommendations would be greatly appreciated.
    Thanks
  2. Sep 11, 2014 at 9:20 AM
    FatTony415
    FatTony415 Well-Known Member
    Tony
    San Francisco, CA
    '20 DCSB 4x4 TRD Off Road
    Stock for now
  3. Sep 11, 2014 at 9:24 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Full OME kit with 885 coils and Dakar leaf pack.
    Details:
    - top plate spacer needs since you want full 3" lift
    - new Upper Control Arms (UCA's); HIGHLY recommended since you want a full 3" lift. (Light Racing, Camburg, Total Chaos)
    - no diff drop
    - extended brake lines (at least in the rear)
    - recommend All Pro's u bolt flip kit
    - new bumpstops; however, can reuse the old ones
    Check out HeadStrong OffRoad
  4. Sep 11, 2014 at 9:26 AM
    Surfh2o
    Yeah I've been reading some of that. OME sounds nice. 279 pages is still confusing. When I go to OME website, they have this selector tool. When I go through the options the lift barely comes to 2"
  5. Sep 11, 2014 at 9:27 AM
    Surfh2o
    Thanks Geek, really helps!
  6. Sep 11, 2014 at 9:29 AM
    Surfh2o
    I've heard the spacers are bad, no. Does the OME lift get me to 2" and then the spacer adds an inch? I'll check Headstrong...
  7. Sep 11, 2014 at 9:30 AM
    geekhouse23
    It's either a 1/4" or 1/2" spacer. below an inch is nothing.
  8. Sep 11, 2014 at 9:34 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    You need to do a lot of reading OP...
    There are a few threads on warranty as well and still won't answer your question. Each warranty claim will be unique and specific to each person...
    Best advice I can give is be patient and read as much as you can. Lots of good info on here you just have to sift through and find what will suit you.
  9. Sep 11, 2014 at 9:35 AM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    I think its 1/2" for passenger side and 1/4" for driver side to make up for the Taco lean.
  10. Sep 11, 2014 at 9:40 AM
    teneighty
    The taco lean is on the drivers side...
  11. Sep 11, 2014 at 9:41 AM
    shore990
    shore990 Well-Known Member
    Colorado
    2014 TRD Off Road
    OP, check out toyteclifts.com. They have complete OME setups as well as Bistein kits.
  12. Sep 11, 2014 at 9:41 AM
    Fiend13
    Chad
    I may have it backwards, then. Been a few years since I installed my lift.
  13. Sep 11, 2014 at 9:43 AM
    teneighty
    Yeah, you would want the 1/2" on drivers side and 1/4" on pass.
  14. Sep 11, 2014 at 9:47 AM
    teneighty
    OP, go to my build. I have a DCLB and you can see my measurements and what I got post lift... It will answer some questions. I only spent about $500 for all my suspension parts.
  15. Sep 11, 2014 at 11:12 AM
    Surfh2o
    You guys are awesome. I'll continue to try to educate myself and I'll check out all the suggestions so far. Hopefully I can make a decision and pull the trigger soon. I'm waiting to hear back from my mechanic buddy to see if he's done lifts before. If he has I should be able to save some cash and hopefully get the wheels and tires I want without going broke in the process. These stock dunlops look gutless...
  16. Sep 11, 2014 at 11:17 AM
    Fiend13
    Chad
    It's easy as long as you have the tools. If he has a hyd lift then it'll be so easy. I did mine in my driveway. Only pain was putting together the shocks and coils. Had to go to Goodyear and have them do it. Paid him $20 off the books. I had a ratchet style compressor and the coils were too beefy. I will say this though for the AAL. Get 2 c clamps, put one on each end, undo the ubolts and the perch, then undo the center bolt that runs through the leafs, once all undone, loosen the c clamps until there is enough room to slide in the AAL. Tighten c clamps back down and then reassemble everything. Takes maybe 30 minutes to do the rear. Just make sure you put the AAL in correctly. Some people don't know that you can put them in backwards.
  17. Sep 12, 2014 at 9:31 AM
    Surfh2o
    Here's my quote, what you guys think?
    U-BOLTS 4 for $75.96
    ALIGNMENT 89.00
    OLD MAN EMU / DAKAR LEAF SPRING (CS047R) 2 for $599.98
    REAR LEAF SPRING BUSHING 1 for $49.99
    LABOR TO INSTALL 2.5" 7 hours labor $595.00
    2.5 LIFT 2005-2011 TOYOTA TACOMA LIFT LEVELING KIT BILSTEIN SHOCKS $475.00
    Total = $1,957 about perfect for my budget
    I would imagine the Billys are 5100's. I kinda want 3" though, because the 2.5" lifts I've seen look barely noticeable. 2.5 would obviously be cheaper and easier on the vehicle hmmm....
  18. Sep 12, 2014 at 9:35 AM
    teneighty
    Seems expensive for Dakars...
    If you go 3" you will need UCA's (approx $400 for LR)
    Sucks you can't find someone to help install.
    That's a lot of money for Bilsteins...
    Research more... Read MOAR!
    2.5" is very noticeable...
    You can buy a whole OME kit with Dakars for around $1200
    Look at headstrong off-road and Wheelers off-road
  19. Sep 12, 2014 at 9:41 AM
    geekhouse23
    Where are you getting the quote from? Local shop? As stated above, that's pricey.
  20. Sep 12, 2014 at 9:45 AM
    Fiend13
    Chad
    Thats alot! For almost $2k you can get 2.5" of lift with King coilovers which are far more better than Bilsteins. I'd search your area for TW members that could help you install it. I paid $1200 for my toytec 3" lift with LR UCA's and had a friend help install them.
