moisture on sills
Discussion in 'Garage / Workshop' started by coffeesnob, Dec 6, 2013.
  1. Dec 6, 2013 at 3:15 AM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    My sons mother n law just built a house. She is getting quite a bit of moisture on the inside of the windows in fact some puddling. She called someone and they told her to get a dehumidifier and I think she got a stand alone but it didn't help. This house is in ohio so it's pretty cold there. What is your opinions on this? Thanks
  2. Dec 7, 2013 at 9:45 PM
    robssol
    robssol Wash Rinse Repeat
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, ACLB
    Fog lights mod, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, Plasti-dip rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED hood lights by tacodane, Rampage 22" LED light bar, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming switch.
    3M window insulator kit. I know it's a new house but beside lowering her heating bill they keep the moisture away from the cold window and preventing it from condensing.
  3. Dec 7, 2013 at 9:52 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    New houses can have a bulk of moisture inside them that takes a while to work itself out as framing lumber , plywood etc dries
    A dehumidifier is a good idea , however making sure that you use a range hood when cooking and especially a bath fan for 10 minutes or so after bathing / showering is important too
  4. Dec 7, 2013 at 9:59 PM
    OZ-T
    Peter North
    British Columbia
  5. Dec 7, 2013 at 10:07 PM
    robssol
    Rob
    S. Wisconsin
    Don't you mean DEhumidifier?:confused:
  6. Dec 7, 2013 at 10:08 PM
    OZ-T
    Peter North
    British Columbia
    Of course , was typing and watching the hockey game at the same time , edited my post
  7. Dec 7, 2013 at 10:12 PM
    robssol
    Rob
    S. Wisconsin
    Just trying to help out:D
  8. Dec 7, 2013 at 10:17 PM
    4lo
    4lo Well-Known Member
    Austin, TX
    2013 DCLB
    Cap, racks, Ironman lift up front with AAL in back
    Crappy windows is most likely the problem. If there is no thermal break built into the window frame then the cold transfers into the warm interior like a freight train mixing with the more humid interior air creates condensation. The cold winter air is going to be more dry than the interior of your home by nature, a dehumidifier may help but its' not the cure.
  9. Dec 8, 2013 at 4:45 AM
    coffeesnob
    VA
    I don't know about crappy windows. She upgraded just about everything in the home. But thanks all for your input.
  10. Dec 8, 2013 at 7:11 AM
    4lo
    Austin, TX
    2013 DCLB
    Crappy was probably a little harsh...Austin is a super progressive building area and people are still installing very expensive aluminum and steal windows without a thermal break. This is actually where the sill pan flashing for windows originated, builders planned on window "sweating" and panned the moisture to the exterior of the house. A good fix is to pull your sills, install a pan that extends to the outside of the framing, reinstall the sill leaving an 1/8" gap between the sill and window allowing the moisture to escape.
    Or this could also be the glass, many companies still use metal spacers which produces the same effect on the glass. You can get the windows reglazed with glass units that have foam spacers.
  11. Dec 8, 2013 at 7:19 AM
    nship
    nship Member
    maryland
    08 4runner
    Check the heater and see if it has a humidifier ,it my need to be turned way back or off. Realize the sweating will take a couple of days to correct it self.
  12. Dec 8, 2013 at 10:25 AM
    OZ-T
    Peter North
    British Columbia
    Or it could just be bulk moisture in the house , our code in Canada requires thermally broken windows as well as sill pan flashing and yet with the right conditions you can still get condensation build up due to excess moisture in the house , poor windows just give the condensation a place to show up but the moisture still needs to be in the air for it to occur
  13. Dec 8, 2013 at 2:45 PM
    coffeesnob
    VA
    I just hope this lady gets it fixed, She is a very very nice person divorced and kind of confused when stuff like this happens. She lives in Columbiana ohio and I know the problem will only get worse as the cold air moves in.
  14. Dec 8, 2013 at 3:14 PM
    OZ-T
    Peter North
    British Columbia
    Air exchange is the best preventative measure
    Is there a builder home warranty program there or anyway she can get assistance from the builder or local building department to at least determine the possible cause of the excess humidity ?
  15. Dec 8, 2013 at 3:25 PM
    coffeesnob
    VA
    She told me that she contacted the builder and they suggested a dehumidifier. This house is new maybe completed 6 months ago so this is the first cold air the house has seen so I think right now everyone is just hoping the problem will go away. She did tell me that the builder is a builder that usually builds real expensive Larger homes but for some reason built her a less expensive smaller home. I don't know if she has a home warranty or not.
  16. Dec 8, 2013 at 3:32 PM
    OZ-T
    Peter North
    British Columbia
    as I said previously , with a house that new I would suspect that the main culprit is bulk moisture in the house as material is drying out as well as the habits of the people living in the house as far as the use of range hoods and bath fans
  17. Dec 8, 2013 at 3:47 PM
    4lo
    Austin, TX
    2013 DCLB
    She most likely has a 1 year builder warranty followed by a 2-10 warranty after. Windows are actually considered part of the structure so she is covered for the full 10 years. OZ-T is absolutely spot on about moisture bleeding on new builds, however, I would continue to raise the issue with the builder and follow up with the insurance carrier right away. Interior condensation is not only a nuisance but destructive and can lead to mold problems as well.
  18. Dec 8, 2013 at 3:50 PM
    OZ-T
    Peter North
    British Columbia
    Interesting , our warranty here is 2-5-10 with the builder carrying the warranty for the whole period
  19. Dec 8, 2013 at 4:07 PM
    4lo
    Austin, TX
    2013 DCLB
    I wish it were that way here! Besides the reputation the builder is off the hook 365 days after closing and usually has a pretty cheap third party 2-10 thereafter. What is the 5 in the 2-5-10 btw?
  20. Dec 8, 2013 at 4:12 PM
    OZ-T
    Peter North
    British Columbia
    2 year / 5 year / 10 year
    Licenced Residential Builders in BC have to have 3rd party warranty coverage as a prerequisite to be able to have the ability to be able to build new homes / pull a permit for a new dwelling , the warranty period is broken down into the 2/5/10 year coverages depending on what the item is , ie cosmetic or structural
