Moisture Problem
Discussion in '3rd Gen. Tacomas (2016+)' started by gtdad66, Mar 26, 2020.
  1. Mar 26, 2020 at 2:39 PM
    gtdad66
    gtdad66 [OP] Well-Known Member
    Jesse
    West Ga
    2017 Tacoma Limited
    Front window tint, tool box, bed mat
    I’ve noticed some moisture under my floor liner on the drivers side floor. It is only on the drivers side front, and under the floor liner. Any suggestions as to where i should start looking. I am going to have the windshield seal checked tomorrow..... but if not that what? Any help is appreciated. Oh its a 2017 Limited... and never offloaded, no river crossings, or anything like that.
  2. Mar 26, 2020 at 2:41 PM
    heybronicetacoma
    heybronicetacoma Meat Popsicle
    Claro
    PNW
    ‘20 DCSB MT OR SSM
    Mods? Yes.
    Improper roofrack install is the usual culprit. The other is the 3rd brake light.
    NWTacoTime likes this.
  3. Mar 26, 2020 at 2:43 PM
    gtdad66
    Jesse
    West Ga
    2017 Tacoma Limited
    No roof rack, and would the 3rd brake light make the front floor wet? Rear and passenger side all dry.
    shane100700 likes this.
  4. Mar 26, 2020 at 3:04 PM
    Tacospike
    Not the father
    Quarantine A-TX
    1 Owner 16 Attitude BLK TRD Spiked Sport
    Murderface Spike Edition
    Sunroof drain hose leak from the a pillar somewhere?
    Chew likes this.
  5. Mar 26, 2020 at 3:07 PM
    gtdad66
    Jesse
    West Ga
    2017 Tacoma Limited
    Is there such a thing? Ive never heard of that before....
  6. Mar 26, 2020 at 3:16 PM
    jmahad01
    jmahad01 Well-Known Member
    It is definitely possible. Do you have a sunroof?
  7. Mar 26, 2020 at 3:32 PM
    Tacospike
    Not the father
    Quarantine A-TX
    All limited have them, that’s why I though it could be that
  8. Mar 26, 2020 at 3:40 PM
    jmahad01
    Ah did not know that. I purposely picked a truck without a sunroof to avoid this problem.
    Anyway to the OP, you're pretty much down to the windshield (especially if it was replaced), sunroof or third brake light (unlikely to travel all the way up front without affecting anything else). Door seal also seems a bit unlikely.
    shane100700 and Tacospike like this.
  9. Mar 26, 2020 at 3:52 PM
    gtdad66
    Jesse
    West Ga
    2017 Tacoma Limited
    I do have a sunroof..... where is the drain line?
  10. Mar 26, 2020 at 3:53 PM
    gtdad66
    Jesse
    West Ga
    2017 Tacoma Limited
    Kind of what i was thinking, and the windshield was replaced in Dec. going back to have them check it......
  11. Mar 26, 2020 at 4:26 PM
    heybronicetacoma
    Claro
    PNW
    ‘20 DCSB MT OR SSM
    Mods? Yes.
    Since no one that knows has answered this... My only help is that in all other cars I had a sun roof, there were 4 drain tubes that went from each corner down the a-pillars (front) and 2 down the c-pillars. I am not sure on the taco. I'll look around for a doc on it.
    Sorry, I keep forgetting some of these trucks have sunroofs!
    Now that you mention that, I would focus there!
  12. Mar 26, 2020 at 4:36 PM
    heybronicetacoma
    Claro
    PNW
    ‘20 DCSB MT OR SSM
    Mods? Yes.
    This confirms my theory about there being 4:
    https://toyotaparts.mcgeorgetoyota....-7l-l4-gas-engine/electrical-cat/sunroof-scat
    Check each corner of the cab underneath the truck and look for something like this: Again, borked windshield install is where I'd keep my focus, but if not and for anyone who stumbles upon this in the future, I hope this helps.
  13. Mar 26, 2020 at 4:41 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    It took 4 attempts to get the windshield on my truck to seal properly. I chased moisture for ages and basically ruined the truck for me for a long time, because anytime I smell something remotely "off" I immediately assume it's water coming in again.
    gtdad66 [OP] likes this.
  14. Mar 26, 2020 at 4:42 PM
    gtdad66
    Jesse
    West Ga
    2017 Tacoma Limited
  15. Mar 26, 2020 at 4:43 PM
    gtdad66
    Jesse
    West Ga
    2017 Tacoma Limited
    My biggest fear.......
  16. Mar 26, 2020 at 4:46 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    A lot of the shops now use some sort of "foam" to set the windshield rather than the old style glaze / caulking. I had a horrific leak with the generic aftermarket glass (which shouldn't have even gone into the truck given it was less than a year old) and my truck got scratched up. Then I had an OEM windshield put in, leaked, had it re-sealed, leaked. I had a third windshield put in and that sealed for a bit until it leaked where the rear view mirror was. I finally went to another Mom-n-Pop shop who used an FY brand shield that's been in there for about a year and half without issue. I've torn apart the interior of my truck more times than I'm comfortable with. My poor driver's side kick panel doesn't even have clips anymore :(.
    Best of luck.
  17. Mar 26, 2020 at 4:47 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    IIRC the Heater Core is over towards the drivers side also.
  18. Mar 26, 2020 at 4:50 PM
    gtdad66
    Jesse
    West Ga
    2017 Tacoma Limited
    Haven’t lost any coolant, that I’ve noticed
    shakerhood likes this.
  19. Mar 26, 2020 at 4:50 PM
    gtdad66
    Jesse
    West Ga
    2017 Tacoma Limited
    Hoping it is the windshield to be honest.... otherwise i feel like it messed up situation......
  20. Mar 26, 2020 at 6:37 PM
    ICU1
    ICU1 Well-Known Member
    It’s never good if your hose gets clogged
