Mold on Wood Sleep Platform
Discussion in 'Outdoors' started by Inthesoup, Aug 6, 2024.
  1. Aug 6, 2024 at 2:59 PM
    Inthesoup
    Inthesoup [OP] Member
    Is this worth trying to salvage or should I throw it out and make a new one?
    There are multiple spots thats looks like this and I am sure there are some spots under the carpet.
  2. Aug 6, 2024 at 3:15 PM
    Clearwater Bill
    Billy
    Largo Florida
    Bleach it and see what happens.
  3. Aug 6, 2024 at 3:27 PM
    kent50
    kent50 Well-Known Member
    Kent
    Gold River California
    2017 Tacoma Sport DCSB MGM
    3" Lift XD Wheels 33" K02s Predator Steps TRD Oil Cap Backflip Bed Cover Factory All Weather Mats WeatherTech Bed Mat TRD Pro Shift Knob Vinyl Air Bag Decal Covers Vinyl TRD and Tacoma Inserts Factory Mud Flaps Factory Remote Start Factory Door Sill Protectors Console Organizer and Tray Pro Fogs Grill Mounted LED Light Bar TRD Faux Grill DeBadged TRD Sport Door Emblems Factory Bed Lights Pop Lock Tailgate Lock Rear USB Ports DIY Power Panel
    This^
  4. Aug 6, 2024 at 3:34 PM
    GunthorNC
    GunthorNC Well-Known Member
    2017 Tacoma Offroad Access Cab 4x4
    You could also slap some Kilz anti mold over it.
    The thing would look nice with a coat of paint anyways.
    jwctaco likes this.
  5. Aug 6, 2024 at 4:04 PM
    Inthesoup
    Thank you all for the suggestions!
  6. Aug 7, 2024 at 9:13 AM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    I have no specific expertise, but I have heard there are some black molds that are serious hazards to health and you do not "make amateur attempts" with them. Not many, I think, but commercial "environmental remediation" firms know.
  7. Aug 7, 2024 at 9:18 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I'd start over, including new carpet. This time paint the entire plywood sheet with Killz. I did that for my battery box, then spray painted over it a different color. Then, attach the carpet. Any wood in a bed build should be painted to help seal it up, even under a canopy. It'll last way longer, and make it possible to clean it up since everything will be on the surface, and not get into the wood.
  8. Aug 7, 2024 at 9:20 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    x3 on Kilz if you're going to save it.
  9. Aug 7, 2024 at 9:27 AM
    RichochetRabbit
    I used polyurethane on a wooden towel rack for my bathroom back in 2020 (metal on the wall too narrow, wanted rack with multiple towel positions). Despite almost daily use holding wet towels it still shows no sign of mold. Only applied one more coat of poly about 2 years ago mainly because I reinforced one of the joints with dowels and had to seal those anyway and re-covered all.
    The make marine grade "spar urethane" that seals against storm winds and rain. You might make an absorbed-seal by using "Seal-A-Cell" and "Arm-R-Seal" ... those are specific product names from "General Finishes" (https://generalfinishes.com/wood-fi...wood-stains-sealers/oil-based-seal-cell-clear). "Seal-A-Cell" does absorb below the surface preventing deep liquid penetration.
  10. Aug 7, 2024 at 9:31 AM
    RichochetRabbit
    This forum is full of people obsessed with all-things-woodworking ... they discuss "sealing wood" at least once a week ... https://www.tacomaworld.com/threads/any-woodworkers.271012/page-675#post-30044141
    jwctaco likes this.
  11. Aug 8, 2024 at 11:23 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Shoulda sealed it first but that's neither here nor there now but it's no big deal as long as it's not growing into the wood; it appears to be just on the surface at this point. Take it outside and scrub it with a brush and whatever you have that kills mold and mildew without leaving an oily residue (wear an appropriately rated respirator if you're worried about it or depending on the product you're using), after it's cleaned as well as you can get it, set in the sun to thoroughly dry, paint with a mildew rated primer (there are various types including several versions of Kilz but their Mold and Mildew formula works well and is interior/exterior rated) then another coat of appropriate paint if desired.
    Check the seals on your shell for leaks and fix as needed. After sleeping in the back, air it out as best you can in the morning (you ought to be airing out your sleeping bag and bedding if possible anyways), I also open at least the driver's side window on the shell when leaving wherever I camped (since it's easy to see and remember I opened it :homer: and shut it from outside) and it doesn't hurt to carry a can of Lysol or whatever that you can spray in the back (also handy for campground bathrooms).
  12. Aug 8, 2024 at 7:30 PM
    RichochetRabbit
    Given it is mold ... I would use some heat source (hair dryer?) to predry. Use the mask, as you advised. Use a powered sander with dust collection to prevent mold hitting the air. The sander allowed digging deeper under the surface.
    A product that absorbs below the surface to seal deeper will remove air from anything deeper underneath ... I know Seal-a-Cell can absorb without leaving a hard shell, allowing choice of surface sealants. Maybe two coats of Seal-a-Cell.
    Tricky stuff, this.
