Monster Valve Install on F5 question
Discussion in 'Stealth Custom Series' started by hoarder23, Mar 16, 2018.
  1. Mar 16, 2018 at 2:27 PM
    hoarder23
    hoarder23 [OP] Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    @SCSPerformance I have a set of Power Tank Monster Valves I am getting ready to install on a set of 16x8 4.5" BS F5s and was wondering if you had any tips for where I should install them. They say to install them opposite the regular step for wheel balancing reasons but I'm wondering if there is a section of the wheel that would be better due to thickness or areas to avoid. My primary concerns are don't have it too far out and rip it off while wheeling or too far in where it gets in the way of the brake calipers.
    Any thoughts or suggestions would be appreciated. Thanks in advance.
    ChadsPride likes this.
  2. Mar 20, 2018 at 4:50 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Shay,
    To be honest, I've never need these valves in person, but they do look pretty cool as far as how they function. I would want to get them away from the outer edge of the lip as possible so you can't accidentally knock them out when you're offroading. I would follow what the valve manufacture recommends doing and do as suggested.
    hoarder23[OP] and ChadsPride like this.
  3. Mar 20, 2018 at 5:21 PM
    hoarder23
    Shay
    NJ
    Scratches
    Thanks for the response. I'm mostly concerned with a section of the wheel that is thicker than the rest that I should avoid or the opposite, where drilling a hole could affect integrity.
  4. Mar 20, 2018 at 5:38 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    how about just using the predrilled valve stem hole? enlarge it if need and tada!
  5. Mar 20, 2018 at 5:47 PM
    hoarder23
    Shay
    NJ
    Scratches
    System needs a Schrader valve to check pressure, monster Valve is just to get air in and out.
