Moog aftermarket LCA's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trhs1980, Dec 12, 2014.
  1. Dec 12, 2014 at 12:08 PM
    trhs1980
    trhs1980 [OP] Well-Known Member
    Elliot
    Orange County, CA
    07 Ext Cab Mid Travel on 35's
    Fox 2.5 Ext Travel Remote Resi Coilovers with 650lb Icon Springs, TC UCA, Wheelers Front Superbumps, Icon 2.0 Remote Resi Rears, Allpro Expo Leafs, 35" MTRs, Full Relentless Fabrication Armor, Retrofit Projector Headlights... and more.
    Hey guys,
    I was wondering if anyone has ordered aftermarket LCA's from Moog. Part numbers RK621293 and RK621294. It looks like they come with the bushings and ball joint, and for $108 a side, seems like a pretty incredible deal. My LCA cams are seized into the bushings, so I was considering replacing the OEM control arm with the Moog one and then rebuilding the OEM at my leisure. Anyone ordered these before? I don't really want to "downgrade" the LCA, so I'm wondering if the Moog ones are on par with the OEM LCA. Thanks for any feedback.
  2. Dec 12, 2014 at 5:08 PM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    I used their Cam/Alignment bolts on my 4Runner... Very good product.
    I made the mistake of rebuilding my LCA on the 4Runner. I should have ordered the rebuilt all assembled LCA instead.
  3. Jun 14, 2015 at 8:05 AM
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    I know this is old …Bump.
    OP did you ever go this route? Seems to me like doing a whole assembled LCA will be much less PITA than replacing bushings or Lower ball joints. Not to mention just the bushings are around $89 for poly. I to wonder about the quality of the LCA and lower ball joints and bushings however. I don't want to be doing this again in 40,000 miles.
  4. Jun 14, 2015 at 10:11 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Moog= top quality :thumbsup:
  5. Jun 14, 2015 at 10:28 AM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
  6. Jun 14, 2015 at 11:30 AM
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
  7. Apr 1, 2016 at 7:44 PM
    jibski
    jibski Well-Known Member
    Josh
    Arvada, CO
    2009 Silver 2.7 AC 4X4
    Installed my ECGS today and while I was down there I took a closer look at my LCA cam hardware...and I must say they are royally fuxz0red. Read through the whole "DIY LCA bushing..." thread and am torn between cutting my bushings and replacing with Mevotech or similar, or potentially buying a whole LCA assembly. If I did that, I would probably go MOOG in hopes that their entire assembly together is quality. I understand people have been having problems with the front MOOG bushings fitting properly in OEM LCAs and having too much slop in them.
    I have read very few accounts of people running the complete MOOG LCAs. Did anyone else pick a set of these up recently and give them a try?
    Thanks,
    Josh
  8. Apr 2, 2016 at 3:10 PM
    big j
    big j Member
    Central WI
    08 Taco,TRD OFF ROAD 4x4, d-cab
    Ranch Hand Brush gaurd, Marathon sportsman seat covers, Toyota skid plate, 3"coilovers front , tsb W/aal back
    tmp_3158-edited_1457286386488-740715064.jpg I'm kinda wondering the same . there is some at rock auto for $97 complete LCA with bushings some by Moog and some mevotech. My bushings are seized and I want to get new tires and an alignment. BUT,, I've got a Toytec lift kit 5100 all around with eibachs coil overs set at .85 " which I didn't think they were set that low but anyways that's what they set at" and with AAL in rear and tsb. There is now a 2" drop in front cause I put a ranch hand brush gaurd and warn V8000 winch and CBI hidden hitch on. The question is what to set coilovers at and or add a shock spacer? And if these aftermarket LCA s are any good? I do alot of hunting on rough roads and some offroading. Or go with an LR LCA for big$? Thanks for the input.
  9. Apr 2, 2016 at 3:13 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I did, got them thru Autozone. Lifetime warranty. I anti sieze everything before assembly. If I have to replace them, I got the warranty and things should come apart fairly easy. Not a bad job if you aren't rusted solid.
