MOOG Part #K100128 Problem Solver Caster / Camber Cam Bolt Kit
Discussion in 'RockAuto' started by tcBob, Feb 21, 2014.
  1. Mar 15, 2015 at 12:39 PM
    #201
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Your best bet would be to loosen the other bolt and straighten the tab. If you marked your alignment before you loosen the other bolt you can get it back at least close.
  2. Mar 15, 2015 at 12:53 PM
    #202
    BCTRD
    BCTRD Well-Known Member
    Drew
    Kelowna, BC
    2008 TRD SPORT
    thanks guys! one other thing, Iv been trying to figure out If I should be replacing my LCA bushings while I'm messing around down there... How or when will I know they need replacing? mine are original and my truck is a 2008.
  3. Mar 15, 2015 at 1:59 PM
    #203
    BCTRD
    Drew
    Kelowna, BC
    2008 TRD SPORT
    I don't know I will check when I can, should I have it on jacks and wheel off when checking if it moves around?
    thanks for the link.. why does it say that the Moog grease cam bolts are crap???
    and it would be great if the pics were still there, guess because the member was banned they took them down?
  4. Mar 15, 2015 at 2:53 PM
    #204
    BCTRD
    Drew
    Kelowna, BC
    2008 TRD SPORT
    ok, when I get time I'm gonna jack my truck up and shake the front tires to look for play in the LCA bushings, if no play found Im gonna loosen my one cam/bolt and move it back where it should be. Then I can straighten my cam tabs that are flatened and weld a bead behind them for added strength. then head off to get an alignment.
    sound like I'm on the right path?
    Ohhh I mide as well loosen all my cam bolts pull them out and grease them before the alignment. :)
  5. Mar 15, 2015 at 2:55 PM
    #205
    BCTRD
    Drew
    Kelowna, BC
    2008 TRD SPORT
    with all the back and forth if I find a cam bolt that is seized Im gonna get it out and replace with OEM bolt.
  6. Mar 15, 2015 at 3:35 PM
    #206
    BCTRD
    Drew
    Kelowna, BC
    2008 TRD SPORT
    awesome, i hope this all goes smooth haha...
  7. Mar 15, 2015 at 4:48 PM
    #207
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Sounds good I may reinforce my tabs as well, so post up some pics when ya do
  8. Mar 15, 2015 at 5:06 PM
    #208
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
  9. Mar 15, 2015 at 5:14 PM
    #209
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I'm sure you could. Mine had 3 flattened tabs, I bent them back once only to find them fail again and said F**K it time to solve this for good.
  10. Mar 15, 2015 at 6:15 PM
    #210
    MTopp
    05 SR5 4x4
    Yeah, I'm pretty sure mine are still intact. And welding all those reinforcements up seems like overkill for me. I'd like them, but I don't really know
  11. Mar 15, 2015 at 6:17 PM
    #211
    MTopp
    05 SR5 4x4
    And I'm getting a new frame soon anyway so I'll just have them all reinforced after that.
  12. Mar 17, 2015 at 8:50 PM
    #212
    BCTRD
    Drew
    Kelowna, BC
    2008 TRD SPORT
    I have seen the total chaos tabs. Id love to just do that and be done but its a fair amount of work.
    Im going to straighten my LCA, bend tabs back, pull my cam bolts, do my bushings if needed, replace or just lube cam bolts, get an alignment, then weld the stock tabs and hope that does the trick. I think it will.
    also did I read that when replacing the bushings DONT grease? they are suppose to seize in LCA?
    aaaaand who thinks it would be easier/time/cost effective to pull the LCA off and bring them to a shop to get the bushings pushed out vs messing around at home heating and cutting at everything?
    I will try and remember to take some pics when I get to doing this.
  13. Mar 17, 2015 at 9:11 PM
    #213
    Sandman614
    Tim
    '06 SR5 Off Road
    Another vote for welding stock ones. Well, after I straighten mine.
  14. Mar 26, 2015 at 7:50 AM
    #214
    mistermanny
    mistermanny Well-Known Member
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    Any updates?
  15. Mar 27, 2015 at 7:14 AM
    #215
    Bonomonster
    Bonomonster Well-Known Member
    Albany NY
    2007 FJ Cruiser
    3" lift, Skids, Sliders, 33" tires
    I received all the factory castor and camber hardware. Having held and fiddled with both factory hardware and the Moog parts I would stick to factory stuff. The factory stuff seems much tighter tolerances.. Just my 0.02¢
  16. Mar 27, 2015 at 7:27 AM
    #216
    Purdue Pete
    Purdue Pete Well-Known Member
    Indiana
    07 TRD 4X4, V6, 6 spd.
    Removed Charcoal filter, K&N filter, and that's it until I can save a bit
    Really stinks that none of those pictures are live anymore. This is something I plan on doing here in the next month or so. But still have questions.
    Edit* By none I mean a lot of the instructional photos
  17. Mar 29, 2015 at 6:25 PM
    #217
    BCTRD
    Drew
    Kelowna, BC
    2008 TRD SPORT
    sorry not yet, i just got back from vacation the last 10 days. I'm hoping to jack my truck up tomorrow and see if it seems like I need new bushings or not.
    then I will start taking things apart. I plan to take pics.
    thanks for the info. I plan on ordering OEM. I haven't called the shop yet, how much for the cam/bolts?
    Drew.
  18. Apr 3, 2015 at 9:12 AM
    #218
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Bought some from oreillys, looks like the correct parts
  19. Apr 3, 2015 at 9:14 AM
    #219
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    uploadfromtaptalk1428077550154.jpguploadfromtaptalk1428077593780.jpguploadfromtaptalk1428077616265.jpguploadfromtaptalk1428077661338.jpg
    Can anyone verify if the smaller bolt is suppose to have a sleeve as well?
  20. Apr 3, 2015 at 10:38 AM
    #220
    Sandman614
    Tim
    '06 SR5 Off Road
    My SPC bolts only had a sleeve on the larger bolt.
