More Power, Better MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Philms, Sep 14, 2010.
  1. Sep 14, 2010 at 3:37 PM
    Philms
    Philms [OP] Member
    Utah
    '08 Tacoma TRD Sport
    Revtec 3", 285/70/17 More to come
    Hello and glad to be a newbie. Just got my 2008 Sport put 285's and a 3" lift on. My question is how to get more power and better mpg. I have read much about the AFE filter and some exhaust mod's. The filter is cheap and is a no brainer but exhausts? Are there any that make sense and don't cost and arm?
  2. Sep 14, 2010 at 3:46 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do some research on 'regearing' your differentials. THat'll get you back to stock power band. It's expensive to regear.....so it depends on how bad you want it.
  3. Sep 14, 2010 at 3:47 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
  4. Sep 14, 2010 at 3:48 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    AFE Pro DRY S will help your mileage a little. The best choice is regear,probably 4.11
  5. Sep 14, 2010 at 4:00 PM
    Philms
    Philms [OP] Member
    Utah
    And had to post my first pics :')
  6. Sep 14, 2010 at 4:02 PM
    jodiddly33
    jodiddly33 Well-Known Member
    Jonah
    DFW
    2010 Golf TDI
    There's no way to improve power (noticeably) and at the same time get (noticeably) better mileage. It's one or the other
  7. Sep 14, 2010 at 4:04 PM
    Philms
    Philms [OP] Member
    Utah
    Hmm, need to figure out the pics.
    I think regearing will be more than I want to put towards the power. Is there anything else like the filter that will make a difference?
    What is a "Blower"
  8. Sep 14, 2010 at 4:18 PM
    bearing01
    bearing01 Member
    San Diego
    4x4 TRD V6 MT
    A blower is a supercharger. A big unit that sits on top of the engine and has a pulley & belt that runs off the crankshaft pulley. The blower pushes air into the engine, under pressure, rather than just have atmospheric pressure push air into the engine - when the engine tries to suck or breath it in. Because you're force feeding the engine more air you can simultaneously add more fuel to match, without suffering misfire. Burning more fuel makes more pressure in the engine for more power.
  9. Sep 14, 2010 at 4:42 PM
    Philms
    Philms [OP] Member
    Utah
    Great thank you. So not much to do really if I don't want to spend the money. I looked into super charger and was more $ than I wanted. The filter seamed like a possible help at $68 and lots of people raving about them. But you don't think it will do much eh?
  10. Sep 14, 2010 at 4:51 PM
    LuckeyTRD
    LuckeyTRD rIDIN wHEELIEz!!
    Cole
    Evans, GA
    2010 PreRunner ALL TERRAIN
    BHLM, Blacked out tails, window tint 5%, tinted windshield , 8000k hids hi/lo and fogs. Black side badges, debadged tailgate, camburg 1.25" uniball UCA's, Camburg 4" spindles, ext. brake lines, Fox remote resi coilovers. Fox 2.0 Pro series rear piggybacks, 3" Allpro Leaf pack, OEM roof rack, Brush guard. Custom TRD allterrain decals. UWS low profile black toolbox
    Too bad its not a diesel.... power means mpg with a diesel!
  11. Sep 14, 2010 at 4:54 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    My mileage went up from 17 to 19 after I got the supercharger.
  12. Sep 14, 2010 at 5:02 PM
    LuckeyTRD
    Cole
    Evans, GA
    Ok so your telling me when i tuned my 03 7.3 liter powerstroke and was able to add close to 92 hp just off a tune.... and was able to get 3.9mg better than i was.... and then when i added the water methanol injection kit it added another 60hp and boosted my fuel eco another 3.... that im a liar? lol and that was back when i ran the stock turbo!
    oh and i added a k&n to begin with... which isnt that big of a deal on that specific truck.
  13. Sep 14, 2010 at 5:07 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    you can just burn fuel more effectively on a diesel (which is always "WOT") and get more MPG and more power at same time. Example: adding a turbo to a non-turbo diesel engine, whitout adding significantly more fuel.
  14. Sep 14, 2010 at 5:09 PM
    2TRunner
    2TRunner Well-Known Member
    Ohio
    The compression inside the cylinder of a diesel is SO much higher than that of a gasoline engine. The air is compressed so much that it gets wildly hot and anything injected into it instantly ignites. Its why you can use so many different things as fuel for a diesel. Its why a diesel does not need spark plugs, a la the gasoline engine.
    Remember, the 4 stroke cycle. Intake, Compression, Combustion (POWER), Exhast.
    As for the OP.
    Better Power and MPG.
    If you don't want to lose the tires (and lift), you'll have to re-gear to even those things out. All that weight is performace robbing.
  15. Sep 14, 2010 at 5:13 PM
    LuckeyTRD
    Cole
    Evans, GA
    The reason a 1000hp drag diesel motor doesnt hit good mpg's is usually bc they run single turbo's and pump as much fuel as possible through them... however.... a buddy of mine drives a triple turbo setup cummins pushin just over 900 hp and 1760 lbs ft trq drives his truck on a daily basis and gets 29 mpg out of an original 16 mpg truck rated to highway... around town its about 24 and the original was 13... and by saying "running them dirtier" u mean adding hp.... so thanks for proving my point,
  16. Sep 14, 2010 at 5:21 PM
    LuckeyTRD
    Cole
    Evans, GA
    im pretty sure its a kit... i remember seeing a trip turbo setup on a cummins in a diesel mag i get monthly and it really wasnt long after that my buddy got his. hes dropped like 35grand into his truck.
    its bolt on kit... lol to clarify.
  17. Sep 14, 2010 at 6:29 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    :stayontopic:
  18. Sep 14, 2010 at 6:43 PM
    Philms
    Philms [OP] Member
    Utah
    I am reading tons about exhaust and am considering. Also about CAI like the URD. Any other versions than that? The CAI sounds like it help deliver more power and better fuel mpg. Then add the exhaust? But if I only do the CAI will it be worth the $300? Thanks.
  19. Sep 19, 2010 at 2:46 PM
    LuckeyTRD
    Cole
    Evans, GA
    Yea those kits are stupid awesome.
  20. Sep 19, 2010 at 3:19 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    NST crank pulley should help MPG a little.
